Question about Briggs & Stratton 66set Panzer Tractor Decal 6hp 1960s
2.5 year old, 15.5 hp Briggs cranks but wont fire
Was shown how nuts holding valves had worked themselves loose, very loose. after adjusting tried starting without spark plug and had no compression at all. repairman said loose valves had probably burnt the piston, or knocked a hole in it. so now I have a two year old $1000 mower thats worthless. this comes 7 months after warranty expires. bought in november 06, I was told Briggs changed design from horizontal valves to an angled valve. is my Briggs dead from poor design and who do I see about getting a new motor, a free new motor.
  • mark groves
    mark groves May 11, 2010
    This was a common problem for some models, I would ring briggs and explain the situation and how many hours it has done. You may have to take it to your local dealer for assesment and he should contact them about it. Hopefully they will come to the party.Either way let me know how you go.Just remember the bigger the noise you make about it the more likely they will do something about it.
    Problem Solver:
  • 3 Answers
Make shore that the valves are not rideing no tappet clearance back both roccers of and try for comp there has to be a tappet clearance for there to be comp or set the inlet at 5 thou and the exhaust at 10 thou on the comp stroke .horizontal b/s have a very good past very good engine in the past
Posted on Sep 02, 2009
Craftsman mower with 19 horse Briggs engine will not start/crank
Sounds like the automatic compression release on the cam has gone bad.
May 06, 2017 | Craftsman Garden
11.5 hp briggs and stratton wont start
check the air gap on the coil and resistance of the lead.
Jul 17, 2012 | Briggs & Stratton Garden
Have a 15.5 hp craftsman riding mower been running great tryed to start today and all it does is backfires through carb and muffler,,,ive cleaned the carb twice now and still doing it. could it be a...
I feel after reading the symptoms that the valves may need adjusting. Is this a Briggs OHV motor. The valve train is sensitive on these and requires periodic (once a year) adjusting. It is not very difficult. A sticking valve or an ignition timing problem could be the cause of the backfiring. Some good, stong fuel system cleaner (like Berryman B-12 Chem Tool )in a heavy dose mixed with the gas you use can readily clean gum and varnish off a sticking valve. The timing problem is a bit tougher nut to crack. If the flywheel key has sheared and the flywheel has moved even slightly on the crankshaft, timing will be affected (with the symptoms you describe). The intake valve not closing all the way can cause this too. To check the valves, remove the bolts holding the OHV cover on the front of the engine. Don't worry, lots of oil won't pour out. It is stored at the other end of the motor. Pull the plug out and rotate the engine by hand. You will see the valve train in motion and be able to readily tell if the valves are seating. If adjusting the valves doesn't fix this, then you will have to remove the engine cover and examine the area of the crank where the flywheel rests. It is slotted and lines up with the slot on the crank. A metal key helps hold the flywheel in place initially (the crank is tapered there and would hold it anyway)....but the key prevents the engine from trying to continue to run if the mower blades strike an immovable object. Instead of the crank breaking, the metal key does. Post back if needed. I am here to help.
Jan 26, 2011 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Craftsman lawn tractor 917.271060w/kohler 15.5 hp engine cranks but backfires thru carb and wont start.
my 15 hp kohler engine backfired while i was using it, now it wont crank and backfires thru carb
Oct 10, 2010 | Craftsman Garden
I have a 24 hp briggs, model 445777, type
I believe this does have comression release. Make sure you're rotating the motor in the correct direction, as I think the compression release only works in one direction. Adjust the valve to .004 with the piston at TDC make sure it's on the power stroke. Turn the motor till intake opens, then when you continue to rotate crank, unitl valve closes and piston gets back to TDC. Adjust both valves to .004. Then do the other cylinder the same way.
Jul 21, 2010 | Briggs & Stratton Garden
7 hp oh valve sears frame
Remove the cover for the valves by the spark plug and adjust both valves at .008 gap
That will end the back firing. They have locking nuts (double nuts) at each valve to adjust
Jun 10, 2010 | Briggs & Stratton Briggs Stratton Intek V...
I have a 17hp briggs and stratton vertical intek engine that needs the valves adjusted again. What are the adjustments for the valves?
adjustment with 4000 feeler gauge
adjust top valve when the bottom valve is fully compressed and than with the top valve fully compressed adjust the bottom valve the same way.
very easy But remember to losen the center tork screw before adjusting the rocker arm nut
Apr 01, 2010 | Parks Optical Briggs And Stratton Engine...
17HP Briggs Intek engine ran good then quit. Now
Intake and exhaust valves need adjustment. Intake .004, exhaust .012.
look for wear or loose rocker arm bolt before adjusting valves.
Nov 22, 2009 | Briggs & Stratton Garden
My lawnmower cranks up but do not start. Oil and gas are full, air filter is clean>
I had the same problem with mine and I had to adjust the valves, it is easy to do you take the spark plug out then remove the valve cover and rotate the engine until the lower valve is completely depressed, then you loosen the adjusting nut on the top valve using a star wrench and a #10 box end wrench, use the star wrench to loosen the lock nut inside the adjusting nut then tightening the nut until a .004 feeler guage sildes snugly between the spring and valve, lock the nut down and rotate the enging until the top valve is depressed and adjust the lower valve the same way, reinstall the valve cover and plug and it should start right up.
May 31, 2009 | Poulan 38-Inch Steel Deck 15.5 HP Briggs &...
Briggs and Stratton 28N700 series 15 hp mower motor
do you have spark at the plug - remove it and ground it while you crank the engine . is this an overhead valve engine ? have you checked compression .
Oct 24, 2008 | Garden
Briggs & Stratton 66set  Panzer Tractor Decal 6hp 1960s Logo
301 people viewed this question
Top Briggs & Stratton Garden Experts
Phil Walker
Phil Walker
John Trevino
donald boissonneault
Are you a Briggs & Stratton Garden Expert? Answer questions, earn points and help others
