Question about Canon PowerShot S3 IS Digital Camera
If i push the zoom out button to far to the edge the camera shuts of, as long as I use the zoom out button slow and don't push it to the edge its fine
    Novelist:
  • 164 Answers
This is the beginning of the common E18 or Lens error problem in such PowerShot family cameras.
It may be a minor issue caused by dust or samd particles, which requires to have blowing in compressed air inside the camera, mainly in front of the lens area.
Also, it may be a major problem in the lens mechanism, where the internal gears (three of them) or the USM motor (Ultrasonic motor) are damaged.
If after blowing in compressed air the problem didn't dissapear, then you will need to have a qualified camera repair service in evaluate and quote the repair of the camera.
Other option is that if you are good or want to attemp the own repair fo the camera, you can find a broken camera (won't power on, broken LCD screen) in ebay or other online places, and swap parts. This requires some tools to open the camera, and a lot of precaution to see how the screws and parts are assembled.
I hope this helps you.
Best regards,
Posted on Jul 22, 2009
My camera is zooming in and one edge of the lenses is higher than the other one
Due to regular dropping it internal parts seem to have become loose and thus are not in control. Try getting it checked it at the service center to change the loose parts
May 16, 2017 | Fuji Cameras
I like to get up close pics of objects especially plants and scenery. The problem is when I zoom in the picture is always blurry and cannot focus on objects that are not far away. Is there anyway setting...
most cameras come with an option called macro,this setting is for close up shots.on your camera it needs to set at wide angle.when choosing the shooting mode move left or right and choose the icon of a flower.if you adjust the zoom, a zoom bar will appear at the top of the lcd.if you try to use a zoom not intended for macro shots the flower icon will gray out and the bar will appear yellow,if you take a picture with the yellow bar it will be blurry.if you zoom out a little until it stops you should be ok. if you use a flash in macro mode the images edges usually will darken.hope this helps.
Jan 08, 2011 | Canon PowerShot SX100 IS Digital Camera
How to zoom in ...make subject bigger...less far away?
to zoom in on a subject you push the t button you can get the manual at this link http://shop.ebay.com/i.html?_kw=Canon&_kw=PowerShot&_kw=A95&_kw=Digital&_kw=Camera it will be gone in one day 99cents good luck have a nice day!! :)
Apr 02, 2010 | Canon PowerShot A95 Digital Camera
How do I activate digital zoom on my canon S3IS
I believe there is a ring around the button the shutter button (the button you press to take the photos. Your sort of push it left or right (near or far). The digital zoom should activate after it goes past its optical zoom range. Push it only slightly to slow down the zoom process.
Aug 12, 2009 | Canon PowerShot S3 IS Digital Camera
Zoom
Hey bello205,
This camera does not allow the user to actually turn off the optical zoom, but does allow the user to shut off the digital zoom. If you are talking about the digital zoom make sure it is turned on in through the menu system. As far as the optical zoom goes make sure you are not in playback mode. If this doesn't work you can try having the camera reset to the original settings every time you shut off the camera by choosing this option under the setup menu in playback mode. If none of this works have the camera looked at by an authorized service technician.
Sincerely,
Allan
Go Ahead. Use Us.
May 01, 2008 | Olympus Camedia C-720 Ultra Zoom Digital...
Zoom malfunction
I had exactly the same problem. You just need to smash once with your hand on the bottom of your camera (it looks that this works for all canon cameras).
Jan 08, 2008 | Video Cameras
Zoom error
when the lens comes out, gently pull it as far as it will go, wiggle it a bit and it should right itself. just tried it with mine and it's sorted.
nice
Nov 07, 2007 | Fuji FinePix A600 Digital Camera
Zoom error message
Press the power button on and hold it down while extending and twisting the telescopic zoom lens. It might fix your problem. In any case it could not make it worse Good luck!
Aug 07, 2007 | Olympus SP-350 Digital Camera
Zoom malfunction
the zoom control button is malfunctioning. try to clean the contact. check the resistant of the variable carbon. if it is not open, try to adjust the contact point away from the damaged area.
Oct 18, 2006 | JVC Handycam GR-DX77 Mini DV Digital...
Canon PowerShot S3 IS Digital Camera Logo
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
