Question about Linksys Wireless-G WPC54G 802.11g/b
Do I have to configure my WPC54G to accept a signal from a wireless-b router...I cant get it to connect
  • 126 Answers
You may have to login to your router and verify that it is broadcasting in 802.11b and 802.11g for the card to see the router.
Otherwise it should connect without a problem
Posted on Jul 13, 2009
2wire270 wireless settings, how to configuring from a wireless g to wireless n signal
The wireless N (IEEE 802.11n) standard includes the wireless G (IEEE 802.11g) standard as a fall-back mode of operation. A wireless N router will normally accept connections from wireless G devices if any configured authentication is correctly set up. A wireless G router should accept connections from wireless N devices as well. In both cases the connection will use the wireless G protocols.
Note that pre-shared keys and authentication must succeed. You can't connect to a secure network unless you prove that you are allowed to with the correct passkey.
Sep 13, 2012 | Computers & Internet
Windows not reckonise my netgear so cant connect to internet although my router has strong signal any ideas
You computer's wireless card needs to be configures with the router's wireless settings ie. SSID, encryption key etc.
To configure your wireless card and to secure your wireless network from unauthorized accwss, please click on this link and follow my instructions :-
http://www.fixya.com/support/r3559128-wireless_router_security
Dec 10, 2010 | NetGear DG834G Router
Cant grt xbox360 wireless adapter conected to wireless router on pc down stairs
I assume the wireless router is configured correctly and the PC can connect to the wireless router and the Internet.
The problem could be that the signal is too weak upstairs for the XBox especially if you have a concrete floor between the XBox and the wireless router. Try moving the wireless router around to increase signal strength to the CBox.
The other problem could be the XBox is not configured correctly.
Follow these instructions to configure the XBox.
  1. In the Xbox Dashboard, go to My Xbox and open System Settings.
  2. Select Network Settings, Configure Network.
  3. On the Basic Settings tab, select your wireless settings.
  4. Select the name (SSID) of your wireless network. If your router isn't broadcasting your network's name, select Specify Unlisted Network and enter the name.
  5. If your network has wireless security, enter your WEP or WPA key.
  6. Try to connect to Xbox LIVE again.
Dec 23, 2009 | Microsoft Wireless Network Adapter Xbox...
How can i connect to enternet f i have a linksys wireless g notebook adapter with model no. WPC54g ver. 2
hi
this is a connector to the laptop and now you'll need a source...
a source can be a service provider with wireless connection or a free hotspots or
a home based wired internet connection with wireless router
if you have a wireless router then you may have to call the ISP for the DNS server settings if any required but for others i think the auto IP configuration settings should work fine
cheers
pls rate if this was any help
Jul 07, 2009 | Linksys WPC54G Wireless-G Notebook Adapter...
Laptop driver needed
You dont need a driver for the wireless router. If your laptop can recieve wireless signal(from a wireless router) all you need is an active internet connection, configure the laptop and router to distribute the internet, you're good to go.
If your laptop cant recieve a wireless signal from a wireless router then you might need a USB Wifi Dongle.
Apr 06, 2009 | Linksys Wireless-G VPN router with...
My Linksys Wireless-G Notebook Adapter V2.0 is no longer working
Try un-installing the wireless adapter, and then reinstall it back. If this does not work, check out the configuration in both the router and in the computer. You will have to connect the computer directly to the router to check out the router's configuration.
It is also possible that the wireless adapter has failed. The only way to verify that is to try another one.
Jerry G.
Jan 22, 2009 | Linksys WPC54G Wireless-G Notebook Adapter...
My wireless card is asking for a passphase 8 - 63
WPA requires an group of alpha numeric sequences for encrypting data between the wireless card on the computer and the wireless access point/router.
These sequences are hard to remember when setting up the wireless Access point/router soa passphase is used to generate these alpha numeric sequences, just use any english phrases such as "I love you 2 pieces", then this can be used to configure your wireless card on your computer.
Jan 13, 2009 | Linksys WPC54G Wireless-G Notebook Adapter...
Compaq Evo with wpc54g v.1 wireless adaptor
hello!
-- make sure that the wireless settings of your router match the wireless settings if you are using the utility of the linksys adapter
-- make sure also that you dont have any firewall or any security on your computer
-- you may also try disabling the adapter wireless utility and use the wireless xp zero configuration instead.
Apr 12, 2008 | Linksys WPC54G Wireless-G Notebook Adapter...
My laptop cant find my wireless connection but finds other connections in range.I can only connect using ethernet cable from router.spoke to sky who said I need to contact acer as my laptop is not...
you might be blocked your SSID broadcast in your wireless router make it broadcat enabled then it will find your connection.
Your lap is ok and settings are well, b.coz it gets other signales. So just check your wireless AP settings.
Thanks
Iqbal
Apr 09, 2008 | Computers & Internet
Linksys Wireless-G WPC54G 802.11g/b Logo
57 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
