Question about NRS CANTAR GLOW BUOY FLOATING POOL LIGHT 92000
My Glow bouy does not hold a charge also have no idea where to get it fixed.
  • 640 Answers
If it is failing to hold a charge, the rechargable batteries have probably worn out. As far as I know, you are not able to replace the batteries in this light. You can call backyardcitypools.com, which sold this particular light, and they might be able to tell you how to do it. If not, they can give you some options for replacing the swimming pool light.
Posted on Jun 15, 2010
3 Suggested Answers
jharwell668
  • 640 Answers
SOURCE: my glow bouy won't hold a charge.
According to the owner's manual that I have for this swimming pool light (troubleshooting section), a blinking red light is definately a charging issue. The manual recommends that you unplug and replug in the light several times. If the flashing continues, they recommend that the batteries need to be replaced. Unfortunately, you cannot replace the batteries yourself. They specifically state that you cannot open the housing yourself. If you did, you would risk electrocuting yourself AND void any warranties that you have. You will have to take it into the retailer that you got it from or an autorized pool supply/repair shop or replace the whole light.
Posted on Jun 16, 2010
my glow bouy just keeps flashing on and off after recharge, had it about 2 years hardly been used
Posted on Jul 13, 2009
How can i fix my dell venue 8 pro? It won't turn on at all.
Seems to be a common problem.
You are on the right track with holding down power button.
1. Hold down for 20 secs, Wait 5secs, hold down for up to 10 secs, it may turn on before then.
2. Does the screen have a dim glow, even though there is nothing on it?
Let it discharge itself so the glow is gone, may take some hours.
Plug it into charge for at least 30 mins.
Try to turn it on.
More info here
http://answers.microsoft.com/en-us/windows/forum/windows8_1-performance/why-wont-my-dell-venue-8-pro-windows-tablet-turn/50573983-8cb7-4770-bf5c-478e63ec5cf8
Jun 07, 2014 | Tablets & eReaders
Batteries keep going flat
No it does not, there is no connection.
If the alternator was not charging, your charge light should glow to tell you that. If the charge light is NOT glowing while driving, then you simply have a dying battery which cannot hold a charge for long.
The oil light not glowing when the ignition is turned on shows only that the globe has failed.
Jan 25, 2014 | 1997 Mitsubishi Montero
A65 unit does not indicate proper position. When alongside a buoy it shows the buoy ahead by about 50 feet. When the buoy is 50 ft behind the sail boat, the A65 shows it abeam. Even my handheld Garmin does...
You may be aware that the system is "detuned" for security reasons. With GPS, repeatability is the key. A bouy is NOT a stationary item, especially at low tide, I suggest that you test your accuracy with stationary objects. A map (chart) cannot know which way the tide is moving a bouy, only the approximate anchor location, the bouy floats and moves....
Mar 04, 2011 | Raymarine A65 GPS Receiver
Battery will not hold a charge. can i replace the battery
As far as I know, you cannot change the batteries on these swimming pool lights. If the rechargeable batteries are no longer holding a charge, you will probably have to replace the entire light.
Jun 04, 2010 | NRS CANTAR GLOW BUOY FLOATING POOL LIGHT...
Grand Cherokee a non-starter
Check the glow plug rail, Its easy to do, get a thick electric cable and hold it on the positive side of the battery and then onto the Rail connecting the glow plugs, do this for 20-30 seconds and try to start the engine, or better still get a friend to start the engine while you hold the cable on.
Diesel engines work on heat and compression, so if your glow plugs are weak then you wont get the heat needed to create combustion.
Sep 05, 2009 | 2003 Jeep Grand Cherokee
Glow bouy will ony stay on for 45 minutes
According to the owners manual for these swimming pool lights, if you light is not working for the full amount of time expected (at least 4 hours) you should try the following troubleshooting steps:
1. The battery pack might not be fully charged. Check the charge and recharge if necessary.
2. The battery pack or charge might be defective. Run the light through several charging cycles. If it fails to hold a charge but the indicator lights are showing normal operation, take the light to an authorized repair shop.
3. The battery pack might be old. After approx. 600 charges, the batteries might lose their ability to be charged. If this is the case, take the light to an autorized repair shop to receive new battery installation.
4. The product might be overheated. The light's internal temperature regluator will shut of the product to prevent damage. Allow the light to cool down and then test for normal opperation.
Jun 15, 2009 | NRS CANTAR GLOW BUOY FLOATING POOL LIGHT...
My glow bouy won't hold a charge.
May 26, 2009 | NRS CANTAR GLOW BUOY FLOATING POOL LIGHT...
4l60e transmission leaking fluid
there is aseal around that tranny shop has to be done from inside tell fixya bouy me ok
May 24, 2009 | 1995 GMC Suburban
Nissan Wont hold a charge
Hi. this is defiantly a slow or major drain that is occurring within this vehicle. Here is a test that you can preform that will help you find this battery drain so you can illuminate this issue.
--BATTERY DRAINAGE TEST PROCEDURE--
Using a 12-volt test light, hook one end to the negative battery post the other end to the negative battery cable you just disconnected. The test light will glow or "light" if there is a drain. If the "light or glow" is faint, that is probably normal draw for the clock or computer. If the "light or glow" is bright, then there is a large drain. That should be corrected. Now start removing and replacing the fuses one by one until the light goes out; that one will be the circuit with the drain. Remember to hold in the button in the door jam for the interior lights.
Please rate and god bless:)
Apr 23, 2009 | Nissan Frontier Cars & Trucks
Apr 10, 2009 | NRS CANTAR GLOW BUOY FLOATING POOL LIGHT...
NRS CANTAR GLOW BUOY FLOATING POOL LIGHT 92000 Logo
153 people viewed this question
Top NRS Pool & Spa Experts
Jay Finke
Jay Finke
john h
David Spradling
David Spradling
Are you a NRS Pool and Spa Expert? Answer questions, earn points and help others
