Question about Philips 42PF9631D 42 in. Plasma Television
No piture or sound , red light blinking 4times
So everyone is saying a software upgrade is needed can someone tell me what web site and if it works
    President:
  • 1,077 Answers
If the red light is blinking and there is no picture or sound, most likely your TV is in " Protection Mode ". Software upgrade wouldn't fix this problem.
Normally, " Protection Mode " happens when the TV detects a failing circuit board.
Most likely the TV has a power supply related problem. It's possible that it maybe a bad capacitor or transformer on the power supply board. The most common thing to go out on flat panel TVs is the circuit board that supply power to the screen. Commonly called a Backlight Inverter Board. But, I can't say it's 100% the problem because I can't actually look at the tv over the internet. I can only make guesses with the symptoms.
You have a few choices:
1. You can try leaving the TV unplugged for 30 minutes so the TV can reset itself.
2. If by chance the TV is still under warranty, go that route.
3. If you have some electronic experience, if you can find and purchase a Service Manual over the internet; It will help you diagnose the source of the problem and fix it by soldering in the new part. The Service Manual will give you red light blinking codes, circuit diagrams, test points, and part# lists.Usually, cost under $20. And most cases the new part cost less than $15.
4. Pay a TV shop to do the repairs. It maybe costly, but get an estimate of how much they will charge. That way you can decide if it worth repairing or replacing the whole TV.
I hope I shed some light on the subject for you.
Posted on Jul 14, 2009
Flashing light code 4times over & over
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit stage inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power led, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating, to many popular brand TVs and other devices. Viewing it in "Mosaic" will make surf easy.
Blinking codes details to many popular brand TVs are given.
Feb 22, 2014 | Panasonic Televison & Video
SONY T.V. MODEL KV-25ST12 4TIMES BLINKS STANDBY
Four blinks - No vertical Deflection (V STOP), Screen goes to a single horizontal line then the video signal muted. Check IC1509, Q1505. Check the vertical output IC, especially to the solder terminals for any loose soldering points. Visit the site named 'Electro-help' for more details. Click this link. View it in "Timeslide" or "Flipcard" option, which can be selected from the drop down box menu by the [Sidebar] tag, at the top left corner of the display window. You can also click the [Home] tab to see the latest updates. It will make search easy. There are more than 1350 posts to different brand TVs now. Pull up older posts there.
Nov 30, 2012 | Televison & Video
Plasma tv th-42pd50u not come on and keep blinking red light two times and then stop again blinking red light two times and then stop not come on
The light blinking twice means there is a fault within the system and it is a code to tell Panasonic where roughly the fault lies.
Go to Panasonic's web site and look for your set then input the fault code and hopefully they will tell you where the fault lies.
Oct 16, 2010 | Panasonic TH-42PD50U 42 in. Plasma EDTV
Phillips Plasma - Model #42PF7320A/37 - 3 flashing red lights
it sounds like you could have a signal board problem they are pretty expensive but there is a web site that sells refurbed parts
Nov 17, 2008 | Philips 42PF7320A 42 in. Plasma HDTV
Panasonic PT-53WX42 - When I turn the TV on, the red light comes on but, no sound or picture.
Does the light blink? If it is blinking a 3 code, the IC's need to be replaced. Those three lamps as you called them are not lamps, they are the three picture tubes.
Jan 08, 2008 | Panasonic PT-53WX42 53" Rear Projection...
TV Won't Turn On
My phillips 42" is the same way. Just started popping up the settings menu the other day and wouldn't stop popping up until I downloaded the software upgrade from the Phillips web site. But now, two days later it won't do anything but give that same annoying red blinking light. The customer service says to take it to an authorized repair center. sounds like they have a ton of these calls everyday. The solution is to buy it from Costco, and make sure you return it and get a new one before their return policy expires.
Apr 22, 2007 | Panasonic TH-50PX60U 50 in. Plasma HDTV
Philips 42PF9631D 42 in. Plasma Television Logo
325 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
