Question about Canon PIXMA MP830 All-In-One InkJet Printer
Ragged edges intermittent
My almost new mp830 has a problem that causes the paper on output to be a little ragged on the lower half of the right edge. Of course this would be an intermittent problem but it happens enough to be a problem.
If there is anything I might be able to check from here, any suggestions that would avoid a trip to the repair shop would be appreciated.
  • Canon Master
  • 1,113 Answers
Check paper tray guides are firmly set to edge of paper.
Posted on Nov 16, 2007
How do i clear paper jam after tearing half of the paper leaving other piece locked inside machine?
IF the jammed paper tears and you cannot remove the paper either from the paper output slot or from the transport unit, or the jammed paper remains inside the machine, remove the paper following the procedure below. 1. Turn off the machine, and unplug the power cord of the machine from the power supply. 2. Open the paper output cover. Remove the paper on the front tray if any.
Important:
    Do not touch the clear film (A). If the paper or your hands touch these parts and blot or scratch them, the machine can be damaged.
3. Make sure that the FINE cartridge holder does not hang over the paper. If the FINE cartridge holder hangs over the paper, move the FINE cartridge holder to the right edge or the left edge whichever is easier to remove the paper. When you move the FINE cartridge holder, hold the FINE cartridge holder and slide it slowly to the right edge or the left edge.
4. Hold the jammed paper with your hands.
If the edge of paper is jammed near the paper output slot, pull the edge of paper to the position where you can hold it with your hands.
5. Pull the paper slowly not to tear it, then pull the paper out.
6. Make sure that all the jammed paper is removed. If the paper is torn, a piece of paper may remain inside the machine. Check the following and remove the piece of paper if it remains.
7. Close the paper output cover, then reload the paper.
All print jobs in the queue are canceled. Reprint if necessary.
Jul 20, 2014 | Canon Pixma Mx432 Wireless Inkjet Office...
Canon mp830 displays error message. Paper output
Hello there
You may not see a paper jam.
This may work for you, it has worked for many here I given this advice so gave it a try it could work for you. Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there.
And gave the rode that the ink slides on a good clean and maybe a bit oil on cloth and wipe the rod with it.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Mar 20, 2010 | Canon PIXMA MP830 All-In-One InkJet...
Error code 5110 on canon mp830 copy and alarm flashing
5110 is Carriage lift mechanism error.First, make sure there is no paper jam anywhere in the machine.. look inside, rear, where the paper tray (output) is, etc to see if you find any shreds or torn paper that may have gotten stuck and you didn't see.Look carefully in the zone of Purge unit, using flashlight in the right side on printer.If this not help your printer need service.
Nov 17, 2009 | Canon PIXMA MP830 All-In-One InkJet...
Mp830 shows paper output slot jam
I cannot receive faxes or print anything.
The message says that "there is no paper in the machine". There us plenty of paper in the machine and I push "OK" and get the same message
Jun 24, 2008 | Canon PIXMA MP830 All-In-One InkJet...
Print Output
Try cleaning the feed rollers. these are the rubber wheels that actually contact the paper and pull it through. If they get dirty, their grip on the paper will be less than adequate. Just use some clean water, or perhaps some rubbing alcohol, and a clean rag to wipe them thoroughly.
Feb 11, 2008 | Lexmark X85 All-In-One InkJet Printer
Pixma mp830
see if you can open a back door on the feed side. sounds like a paper is not feeding properly inside and must be removed.
Would be nice to know the model, make.
Jan 07, 2008 | Canon PIXMA MP830 All-In-One InkJet...
Printer is catching on the bottom right section of paper when printing
when was the last time you changed the cartridge/inkhead could be ink buildup and causing it to snag Inkjets are horrible about drying and clogging. if inkhead is removeable you may take it off and clean the area that comes in contact or proximity to the paper, I would also check the bottom part of the roller and housing for anything that could be jammed in there or stuck.
Dec 22, 2007 | Canon PIXMA MP830 All-In-One InkJet...
Canon MP830 paper jam
Your "Best Solution" posted 10/01/07 needs just a little bit more. I followed the directions and saw the jammed paper but couldn't get hold of it. I then called Canon support and they told me that the green plastic can be pulled up and then the paper under it is accessible. I pulled up the green plastic and was able to grab the jammed paper and pull it out. He also told me that the solution could be found in the Canon knowledgebase with a color picture as well.
Sep 27, 2007 | Canon PIXMA MP830 All-In-One InkJet...
My printer folds top lefthand corner intermittently? why?
Do you run labels through the unit? If so, ther is probably a little bit of the glue or label that is inside the feed asm. Hard to find it. Have you tried to open the top door when the paper has fed just under the toner cartridge to see if the bent edge begins at that point. Did the problem appear right after the new maintenance kit? Do you still have the old fuser asm? Reinstall the old fuser and see if problem goes away.
Jul 31, 2007 | HP LaserJet 4250n Printer
Canon PIXMA MP830 All-In-One InkJet Printer Logo
35 people viewed this question
old marine
old marine
