Question about Sport & Outdoor - Others
Waverunner sat for 4 months. thought battery was
98 yamaha xl 1200 waverunner sat for 4 months. thought battery was dead. changed it and when start was pressed only 1 click. tried a few times after that and now nothing happens. what gives?
  • 24 Answers
Try jumping the waverunner using a set of jumper cables and your vehicle, this will rule out if the battery is bad. If you still have the same issue, check the connections. The connection at the starter or another place may have corroded a bit. Yet another option is to remove your spark plugs to make sure that your motor has not hydraulically locked. Once you have removed the plugs try and turn over the engine. You may need to ground out your plug wires if you have an electronic ignition to protect it. I hope this helps.
Posted on Jul 14, 2009
99 yamaha waverunner 1200 xlt starter stays engaged and powered on even after stop is pressed and kill switch is pulled.
The start stays engaged the entire time? I would guess it's a bad ignition switch -- it would be sending power to the starter (through the solenoid) regardless of if you switched it off.
Maybe it could be a bad starter, too. I'd start with the switch.
Mar 10, 2016 | Yamaha Jet Ski Pwc Watercraft Cover...
Yamaha waverunner does not start
hi there it sounds like the switch gear need pulling apart and the copper contacts cleaned as it sounds like the kill switch is closed up and the starter button contacts need cleaning as well also check to see if the stater soliniod might need a cleanup where the wires go,also check your fuses to see if there contacting alright if you ride in all weather or the bike sits outside it can have these problems as mouisture gets into everything. hope this helps cheers pete
Jun 12, 2013 | Yamaha 98 Gp 1200 Air Box Intake Mount...
Yamaha 1200XL PWC won't start
hi there could be corrosion on the switch gear and kill switch check and clean as well as the wires going tostarter soliniod,corrosion on these electrical connections are always a problem cheers pete
Jun 11, 2013 | Yamaha Waverunner Xl 800 / Xlt 1200 Jet...
I was told i need to clean out my exhust on my 1998 yamaha xl 1200 waverunner how do i do that?
Not true, whoever told you that probably thought you had an xlt which runs a diff motor. You need not worry.
Aug 11, 2011 | Yamaha 12V Air Pump
Have a 1999 yamaha 1200 xl limited waverunner only clicks at the starter relay when trying to start it after a friend forgot to put the plugs in and it got water in the engine compatment
your starter is shot more than likey try to jump the relay in that black boxs buy jumping the two post on that round relay if it does the same its the starter if it turns over its the relay or the start **** becareful jumping the relay no fuel around air bike out and you have to take off the exhaust manifold to get to the starter
Aug 01, 2010 | Boating
I have a 2000 Yamaha XL1200 waverunner. When I went to start it, the existing battery was weak. So, I put in a new battery and now it won't even try to start.
my 1998 xl 1200 has this thing it the batter is changed or if it sits for awhile you have to hit mode then something that says code should pop up on the screen then hit a b c a and then it should be able to start. but your code may be different
Jun 20, 2010 | Yamaha 12V Air Pump
Sport & Outdoor - Others Logo
1,008 people viewed this question
Top Sport & Outdoor - Others Experts
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
