Nikon D300 When I depress the shutter half way or fully on my D300 the frame counter reads r27 and the lens (any previously compatible Nikkor lens) will not auto focus. The camera is not set in burst mode and should not be buffering. Please help.
Only reason the lens will not auto focus when you depress the shutter half way is due to either lens AF switch is set to Manual OR camera body's focus system is on M. There is 3 way toggle switch below the synch port around the lens mount. It should be set to C or S in order for auto focus to work. If all the settings are correct and even "AF-ON", next to rear dial doesn't activate auto focus then the issue maybe in the setting or the body itself. As for the buffer reading r27, I think mine displays r## regardless of burst/continuous mode.
Was this helpful?
Yes
No
Popular Solutions for Nikon D300 Body Only Digital
What is the name or part number for the MD cover on the bottom of the NIkon D300 and can I replace...
(More)
What is the name or part number for the MD cover on the bottom of the NIkon D300 and can I replace it?
Monitor on the back of the camera is locked up. Monitor on-off button does nothing, none of the left...
(More)
Monitor on the back of the camera is locked up. Monitor on-off button does nothing, none of the left hand buttons work, selector button does not work. However when I turn the camera on I do get images on the screen, but they are locked.
out of warranty Nikon D300 with a continuous blinking "ERR" message. Tried multiple...
(More)
out of warranty Nikon D300 with a continuous blinking "ERR" message. Tried multiple lenses, cleaned the contacts, fully charged the battery, tried several CF cards and problem still persist. Shutter has a weird sound when pressing the shutter button.
