Question about Mitsubishi WS-55511 55" Rear Projection Television
I have taken the back off and cleaned everything and i am still having an out of alignment coloring on the outsides of my tv. the middle is perfect bet the outsides, mainly the left side(my right facing the tv) is out of color alignment. what can i do to tackle this myself? my email address is bfaulkner_tattooed@yahoo.com.
  • 1 more comment
  • Tattooed B Jul 14, 2009
    i have looked at the diagram and it really doesnt pinpoint what im suppose to be looking at. But i looked in that general area and everything seems to look soldered together. What do you suggest now?
    Sorry, my tv is a mitsubishi ws-55809. serial number 010180......
  • Tattooed B Jul 15, 2009
    i will take the whole piece out and check the underneath side. If the convergence chips are not the issue, i guess i will just keep elliminating problems one by one. Thanks for your help and if you have any other solutions, just let me know. My email address is bfaulkner_tattooed@yahoo.com
  • 10,594 Answers
Post shows its Mitsubishi WS-55511 TV, if that's correct then check convergence section for dry solder joints and resold these joints. Specially check convergence out ICs pins.
Below is an exploded image of main board of TV and convergence area is marked to have an idea...
Let me know if problem remains to check further options.
Thanks.
Posted on Jul 13, 2009
HP 2600n will not print black after lens cleaning (other 3 colors are perfect)
check supply status, configuration page, how is look if black only getting miss alignment then check formatted board/dc controller
Jun 26, 2013 | HP Color LaserJet 2600n Printer
I have the quantaray lens ld 70-300mm. Was working fine until one day. When I look through it everything looks slightly foggy. Adjusting it doesn't help. Cleaned the outside lens. Would like to kn
Yes, the lens can be disassembled and cleaned. But before you think about doing so, think about this. Do you have a lens collimator and other equipment necessary to ensure proper alignment on reassembly? If you don't, please leave inside cleaning to a trained professional.
Dec 05, 2012 | Cameras
My RCA P52937SG projection tv. Picture distorted. I beleive it has to do with the green circuit / projector. Everything needs to be aligned to green. Green projector is on, but, in alignment screen I get...
The tv have a problems known as a convergence problems,it dead.Tv have colors lines R,G,B mis alignments,have colors shadow pictures or 3D pictures look alike?The tv convergence board is dead.The tv convergence board must have replace the 2 STK convergence ICS and some or all of it resistors too.To fixed the tv convergence board to solved the tv convergence picture problems.The shop,will cost u like $300-350 for parts and labors.
Mar 28, 2011 | RCA R52WH73 Projection Television
Colors out of alignment
you moved this set huh? alignment is out, magnets slid out of place on align coils the a convergance alignment preformed (sometimes u get lucky and the coils can be put back perfect and then no alignment needed)
Nov 22, 2009 | Televison & Video
Picture adjust
Put it in the custom mode.Put the contrast to the max.Everythings else in half in the middle.
Colors maybe less.Now u have the desire adjustment?
Aug 19, 2009 | Televison & Video
I have taken the back off of this, cleaned everything and cant find out what is wrong. My TV is having a "bow tie" affect and the colors are off on the outsides of the screen but the...
MOST OF THESE SETS HAVE A DUAL SETUP YOU NEED TO REPLACE BOTH @ THE SAME TIME,IF YOU REPLACE THE 1 IT PUTS TO MUCH STRAIN ON THE OTHER AND YOU END UP WITH THE SAME PROBLEM HOPE THIS HELPS
Jul 16, 2009 | Mitsubishi WS-55809 55" Rear Projection...
Mitsubishi ws-55809 distorted picture
Sounds like you are having a convergence error.
What you could do is either replace the TV or have some wires/circuits/boards replaced.
Shop around for prices.
If you're lucky you'll find someone willing to do a free estimate, as replacing anything on these will set you back a few hundred...at least.
Hopefully, in your case, the problem can be solved by tightening a screw or two.
Jul 15, 2009 | Mitsubishi WS-55809 55" Rear Projection...
Mitsubishi WS-55311 answer you gave me.
Before you replace a board, please double check or use different cables, make sure the cables are in the proper out/inputs, rgb to rgb. Try 'comp' 2. Composite vs component uses two different paths to produce a picture. Also, after taking tv's back off ensure that all boards are seated properly, since this happened after movement. CAUTION: make sure the unit is poweless, unplug tv. Let me know. Good luck....
Apr 03, 2008 | Mitsubishi WS-55311 55" Rear Projection...
Mitsubishi WS-55511 55" Rear Projection Television Logo
177 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
