Question about Proform 760 CrossTrainer Treadmill
Treadmill wll not start, have changed the circuit breaker but get no activity on console
    Problem Solver:
  • 8 Answers
You have to have the little magnet on the front of the treadmill. If it is an old treadmill, you may just need to get a new one. Hope i helped!!! :D
Posted on Jul 14, 2009
I just put together a Sole f63 treadmill (it took forever). I turned the power button on and the display lit up. I pressed the start button and the display shut off. I can't get the display to turn back...
First of all, make SURE that the unit is NOT plugged into a ground fault circuit interrupt (GFCI) outlet. Make sure that the safety key (or safety tether cord's magnet) is on the round metal portion of the console control's head. (It will NOT operate without this in place because it's a safety feature. Also check the circuit breaker under the console, & push it in until it clicks (if it has been tripped (it would extend out if tripped)). Make sure that the power cord is fully inserted in the appropriate power outlet & that the building/home's circuit breaker has not tripped. Otherwise, call your dealer to replace what would be a defective treadmill.
Feb 22, 2015 | Exercise & Fitness
The console will not work with the treadmill. Cannot start or change settings but is getting power.
Hi Nancy,
If you have tested the power point ~ for example: plugged in a vacuum cleaner and you have power ~ yet when you plug the treadmill in, you have no console display, there is a 99% chance you have a faulty lower control board...
Thank you,
Ben.
#treadmillrepair #treadmillbelt
TreadmillBelts.com.au HealthEquip.com.au GYMWORKS.com.au
Dec 01, 2014 | Exercise & Fitness
I have an Ifit treadmill. I was changing speeds and it turned off and won't restart. It beeps when i turn it on but no lights on console.
Power issues with ProForm treadmills fit into two categories: the power does not turn on or the power shuts off when using the treadmill. If the power will not turn on, make sure that the treadmill is plugged into a working power outlet. In addition, you should use a single-outlet surge protector for the treadmill. Single-outlet surge protectors protect the machine from any voltage changes that may occur in your home.
If the machine is plugged into a working outlet, make sure the safety key is in the keyhole on the console. If the safety key is not plugged into the machine or if it is pulled out during operation, the treadmill will not operate.
Finally, make sure the circuit breaker located on the frame near the power cord is set to "Reset." The circuit breaker is set to "Reset" if the top of the button is pushed in. When the breaker is tripped, push it back to the "Reset" position and wait five minutes before powering on the treadmill.
If the ProForm treadmill shuts off during operation, check the power cord and circuit breaker as described above. You can also try removing and reinserting the safety key.
Increase Engine Horse Power.
Jun 02, 2012 | Proform Exercise & Fitness
Pro form 365 won't start
Dear Sir:
I will help you, please do the exact step:
PROBLEM: The power does not turn on
SOLUTION: a. Make sure that the power cord is plugged into a surge suppressor, and that the surge suppressor is plugged into a properly grounded outlet (see page 10). Use only a single-outlet surge suppressor that meets all of the specifications described on page 10. Important: The treadmill is not compatible with GFCI-equipped outlets. b. After the power cord has been plugged in, make sure that the key is fully inserted into the console. c. Check the reset/off circuit breaker located on the treadmill frame near the power cord. If the switch protrudes as shown, the circuit breaker has tripped. To reset the circuit breaker, wait for five minutes and then press the switch back in.
Finally: check, the breaker from the home, if there tripped, check this, and Reset.
I will recomend when you finally set up, install Stabilizer Voltage, is cheaper us$15,00 aprox
Thank you in advance, sincerely.
Blessing, if you need additional help, please contact me.
E.CUADRA MANAGUA, NICARAGUA.
Sep 26, 2011 | Proform Crosswalk 365 Console Treadmill
I have two cardio zone treadmills which won't start. console lights but nothing happens. checked the two fuses for continuity, both good. what else can i check? s/n 35005624 and 35005616
Dear Sir:
I will help you.
Please in all this check in, use The Vom digital:
1. NoPower
o 1 Make sure that the surge protector being used isproperly grounded and turned on. Check that the treadmill power cord isproperly plugged into the surge protector. o 2 Check to see that the key is inserted in theconsole. o 3 Check the circuit breaker on the frame near thepower cord. If the reset/off circuit breaker has tripped, wait 5 minutes andthen reset the breaker by pressing the switch in.
4)Check the circuit breaker from the main panel( wall) and Measure the Voltage for properly 115VAC. if there .
Hoping help you, contac me if there are something extra.
blessing.
E.CUADRA Managua, Nicaragua.C.A.
Sep 13, 2011 | Cardiozone Exercise & Fitness
The power is on but it won't run
Power issues with treadmills fit into two categories: the power does not turn on or the power shuts off when using the treadmill. If the power will not turn on, make sure that the treadmill is plugged into a working power outlet. In addition, you should use a single-outlet surge protector for the treadmill. Single-outlet surge protectors protect the machine from any voltage changes that may occur in your home.
If the treadmill shuts off during operation, check the power cord and circuit breaker as described above. You can also try removing and reinserting the safety key.
Thanks for the rating Good luck
Dec 22, 2010 | Exercise & Fitness
It does not turn on says safe
This message appears when you remove the Safety key.
Kindly provide me with the make and model of the machine?
Are you sure that the key is intact? Is it properly placed?
Thanks!!
Aug 21, 2010 | Exercise & Fitness
Treadmill will not operate when plugged up.
check the outlet first by plunging in a light to make sure their is power and that the house breaker was not tripped. then plug in the power cord next locate the reset/off circuit breaker on the treadmill frame near the power cord. Switch the circuit breaker to the reset position. Then place safety key on console and the display should light up if not then you may have a lower board problem.
May 17, 2010 | Weslo Cadence Ct 5.8 Treadmill
T3 Treadmill Stuck Key
The cause of a “STUCK KEY” error message on the Basic or Advanced consoles. A stuck key error is displayed when one or more keys on the console or activity zone remain actuated for more than 45 seconds.
SOLUTION
Recycle the power. If the key remains stuck, the console will display “PLEASE WAIT” until the stuck key error is displayed again. Determine the stuck key. Replace the console if the problem is a key on the console. Replace the activity zone membrane keypad or the activity zone circuit board depending on the product if the problem is not in the console.
Jul 28, 2009 | Life Fitness T3 Treadmill with Advanced...
Proform 515s treadmill motor won't start
If the colse buttons make a chirping noise when you push them the console should be Ok. If there is no chirping noise with the push it is a bad console. If everything but the speed works it will probably be your motor controller that is bad.
Apr 14, 2009 | Proform CrossTrainer Treadmill
Proform 760 CrossTrainer Treadmill Logo
330 people viewed this question
Top Proform Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
Matt Olenzek
Matt Olenzek
 Atlanta Fitness
Atlanta Fitness
Level 1 Expert
Are you a Proform Exercise and Fitnes Expert? Answer questions, earn points and help others
