Question about Frigidaire HV2736B Kitchen Hood
Help we have a frigidaire HV2736B down draft and everytime we trun it on it goes up and back down right away,the blower will not trun on and it will not stay up. What could be the problem and can we fix it ourselves?
  • 833 Answers
Is this the one with the slide power unit? If so, the slider could be defective. First, have a look at the slider....is it full of gunk? If so, you might be able to clean it out. With the power off, get some brake cleaner from the local auto supply guy. Spray it liberally into the slider and move it around...The dripage will be messy. Put a bunch of paper toweling under it to catch the stuff. It is not flammable but you should wait for it to dry for a few minutes before restoring power. Still with the power off and the motor/fan exposed...does it turn easily? If not, you may have an issue there. Gunk or bad bearings. Fix that up.
Posted on Dec 11, 2007
WERE IS THE BLOWER MOTOR LOCATED ON A 2002 MITSUBISHI MONTERO SPORT XLS?
under the dash board, most likely right above the passengers right foot.
Aug 29, 2014 | Goodman B1859005 Induced Draft Blower...
I have a pyle plts77du. it was playing for about 20 min then i trun off the car. i push it back to mont it and trun the car back on then nothing happend..... like a little red light come on then went...
Its possible the connections From you Remote Wire are not fully tight.. Same goes with The Ground and positive,,,
I would remove and redo all connections..
Even as Far as re stripping the wire for best connection
May 09, 2011 | Car Audio & Video
Hi, I have a Goodman furnace model GKS91155DXAD. The blower stays on. After turning power off for a few minutes then back on, the draft blower comes on for a few seconds then goes out but the blower...
I would check hot surface ignitor or spark ignitor to make sure they are working. If not then replace them and try again.If ignitor does not come on control board will shut down, try to restart usually try 4-5 times then lock. out. Generally for a preset time then try again. If it has tried to start to many times and failed it will lockout until power is shut off and it can reset. Hope this helps you. Thanks
Nov 17, 2010 | Heating & Cooling
Furnace lights fan comes on then fan goes off furnace stays light until overtemp takes it out code flashes 4
Have some one hold the bottom door safety switch, turn furnace on wait until heating fan relay clicks, and check at terminal (Heat) & terminal (neutral or where all the white wires are located on the control board) for 115 volts to 120 volts. If voltage is present replace blower motor, if voltage drops out while running then replace control board.Turn power off to furnace, open bottom door and feel blower motor with hand, if motor is real hot replace motor. you can not oil this type of motor, it has to be replaced along with the compacitor. Good luck.
Jan 22, 2010 | Goodman Furnace Draft Inducer Blower ...
The furnace will come on and ignite then it will go out and not come back on. It doesn't do it everytime but you can reset the thermostat and it seems to help
Flame sensor should be cleaned every 1 to 2 years. The flame sensor is a small silver rod that sits in front of one of the burners. Cleaning it with abrasive cloth will do the trick. Always shut power off first.
Jan 08, 2010 | York Furnace Draft Inducer Blower Fasco #...
Filter Removal Procedures HV2730B/HV2736B
Contact Filter Factory - TTN Inc , they make filters and are very helpful. Open 7 days a week
I hope this helps.
Jul 12, 2008 | Frigidaire HV2736B Kitchen Hood
Unit will sometimes not turn on
NASCAR...I'm thinking more like the switch. If you can, with the power off gain access to the switch wiring. find the lead that goes to the power and the motor. Connect them directly (you might need a paper clip). Tape it all up securely and fire up the power. If it works...you will know about the switch...if not, you might look at the motor. By the way...check that motor rotation...it should turn easily when you give it a spin. Motors of the type used in fans generally don't degrade in performance unless they get gummed up with kitchen grease. Clean the grease off with WD 40.
Nov 21, 2007 | Frigidaire HV2736B Kitchen Hood
Frigidaire HV2736B Kitchen Hood Logo
148 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Paul Carew
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
