Question about Whirlpool GHW9100L Front Load Washer
Machine is totally dead
I have power at the plug but machine is dead. no lights no matter what postion the selector is in. I don't see any type of reset or breaker on back of machine.
  • 92 Answers
Firstly check the motor bushes as this maybe causing this problem.
Posted on Jul 15, 2009
How do i reset washing machine AEG 64840
You can choose the right programme for any type of laundry following the descriptions on the washing programme tables (see «Washing Programmes»).
Turn the programme selector dial to the required programme. The programme selector determines the type of washing cycle (e.g. water level, drum movement, number of rinses) and the washing temperature according to the type of laundry.
The pilot light of button 8 starts blinking.
The selector dial can be turned either clockwise or anticlockwise. Position "0" to Reset programme/ Switching OFF of the machine.
At the end of the programme the selector dial must be turned to position "0", to switch the machine off.
If you turn the programme selector dial to another programme when the machine is working, the yellow pilot light of button 8 will blink 3 times and the message Err is displayed on the display to indicate a wrong selection. The machine will not perform the new selected programme.
Dado
Jan 15, 2015 | AEG Washing Machines
Indesit 1200 widl 126 no lights showing when machine switched on. Checked plug fuse is good
Hi Whalley
Are all fuses ok? kindly check your outlet as your power source and measure the voltage.
Jan 19, 2014 | Car Audio & Video
Completely dead laptop.
sometimes you just need to remove the battery then power-up the unit using its charger.
Jul 05, 2013 | Toshiba satellite c660
My Zanussi Electrolux Essential 1200 washing machine ZWF12070W1
Most times unplugging a washer for 5 min or so will reset to factory. Some units just a quick unplug works too. But I'm not totally familiar with yours.
If it's going to be hard to unplug just turn off the breaker to it.
Hope this helps
Feb 27, 2018 | Zanussi ZWF12070 Front Load Washer
My Lenovo 3000-N500(Type 4233-79G) (1.5 Yrs Old) will not boot from Battery or Power Adaptor. Both power sources are OK & when both power sources plugged on to this machine, this laptop displays...
Do any lights come on when you press the power button? If not, did you get all the cables reconnected properly? If lights come on or fans come on when you press the power button, then it sounds like the screen has gone bad. That is the symptoms you are describing.
Jun 26, 2011 | Lenovo 3000 N500 Notebook
Washing machine has died and I dont know how to drain water from drum. HOTPOINT AQUARIUS EXTRA WMS38
hello get a bowl or bucket and position the drain hose a low as possible the water should drain out .as for the machine dying do you mean it's total dead if so check the fuse in the plug if ok then check the fuse inside the washer's power supply it's a glass type hope it helps
regards
shaun
Mar 26, 2011 | Hotpoint Washing Machines
I have an Electrolux EWD1477. I have been away for four months and I'm having problems with it. I set to do the quickwash30 program and press start, you hear the clicks, it might put some water in then...
My EWD1477 was doing this a year ago and I fixed it. Then it started doing it again a month ago and I seem to have cleared it again.
Firstly, remove the drain hose from where it is inserted into a laundry sink hole to make sure it is not blocked or sealed in with sludge.
Secondly, make sure the machine is empty of water and clothes and then turn the machine to off with the Program Selector Dial. Then turn off the power at the socket and remove the power plug and leave for five minutes.
Step 1: put the plug back in and turn the power back on.
Step 2: turn the selector switch to the right (Whites/Intensive). The green light of the Start/Pause button should be flashing and the green lights on for Prewash/wash, Rinses and Spinning. Don't press any other buttons or change any other settings.
Step 3: press the Start/Pause button and wait for the machine to empty any excess water. Press it again immediately after you hear water flowing into the machine OR two audible clicks. The machine is now in pause mode with the green light of the Start/Pause button flashing. Only the green light on the Prewash/Wash button should be on. Leave it in pause mode for 30 minutes and then press the Start/Pause button to recommence the cycle.
Step 4: If the Start/Pause button begins flashing, water stops flowing into the machine and the three green lights mentioned above are back on, turn the Program Selector Dial back to off, wait 10 seconds, and repeat the process above.
Step 5: If when you then turn the Program Selector Dial to Whites/Intensive and hear the two audible clicks, immediately press the Start/Pause button to set the machine in pause mode. Wait 30 minutes. Then press the Start/Pause button to recommence the cycle.
Hopefully the cycle will run without a problem.
Mar 26, 2011 | Electrolux Washing Machines
I'd like to know the key sequence I need to press to be able to self-diagnose the problem I've got with my zanussi washing machine. ZWF1640.
To display Error Code:
Move Programme Selector to the Off postion.
Press the 2 buttons on the right and turn the selector 1 position clockwise and hold the 2 buttons for about 5 seconds until all the lights are flashing. Release buttons and turn the selector to the 10th position. The Error Code will be displayed.
Note the code then turn the selector to off ,then on,then off again.
Feb 28, 2010 | Zanussi ZWF1440 Front Load Washer
I think my HP Pav powersupply is dead. When I plug it in and try to turn it on, nothing happens to the HD and computer except a green light flashes on the back of the power supply. It is a Bestec...
all atx powersupplies are generic-it dous not really matter what computer it comes from unless its a high end pc requiring loads of power-if your machine is intel you may need a supply with an extra twelve volt lead(two yellow and two black leads in a little block)-but for that pc i would just harvest a powerpack out of a dead machine
Feb 25, 2010 | Compaq Computers & Internet
Minolta EW501 Electronic Typewriter switch problem
A totally dead machine is usually the easiest to find the problem. Make sure the outlet works. Test it by plugging in a lamp or fan or something. Once you are sure the outlet works make sure the cord is not cut or pinched. Most machines have a micro switch that turns off the machine if the cover is open. I don’t know this machine but check that the cover is properly closed. See if you can find the switch, and try to determine if it is being activated. Some manufactures have a plastic “tab” that hits the switch when the cover is closed. Those tabs can get broken off.
Last suggestion would be to look for a blown fuse. Again seeing that I am unfamiliar with this model I don’t know it the fuse is in the back cover if it’s no there (near the power cord) chances are that you will have to remove the cover (not open the lid). This means you will have to pull out a screwdriver. BE SURE TO UNPLUG THE POWER CORD!!! If the fuse is inside it would likely be near where the power cord.
Oct 29, 2007 | Office Equipment & Supplies
Whirlpool GHW9100L Front Load Washer Logo
186 people viewed this question
Sal De
Gerry Harvey
Gerry Harvey
