Question about Panasonic KX-FL521 Plain Paper Laser Fax
My Laser Panasonic Fax won't pick up papers when sending faxes
I hear no sound or click when placing paper to be faxed in the tray. Also, the fax machine fails to pick up paper when after dialing fax number. How serious of a problem is this?
    An expert whose answer gotĀ voted for 100 times.
  • 87 Answers
Re: My Laser Panasonic Fax won't pick up papers when...
There is a sensor in paper tray .u will see just its lever at the other end of lever there is a sensor .i think it is dirty .just clean it when u will put paper u will listen sensor is working .fails to pick up mean that fax try to pick paper but not pick the paper .there is a ruler justclean it with cloth and some licquid.and properly check this ruler is movi ng or not moving.
Posted on Jan 21, 2009
0 characters
3 Points
I get plain paper or double when I received fax from my uf5300 laser print one page from 5 pages that sent and I got empty pages and double somtimes
Paper feed rollers and sheet feed pad dirty. Feed roller on top pad should be just below. Clean with alcohol. Papers have clay in them. Recycled is worst. It will glaze the pick up roller and pad.
Sep 21, 2014 | Panasonic PanaFax UF-8000 Laser Fax
We cannot recieve faxes check cassette error code 011
The small tip on the left side of the paper cassette is broken off.
wad up a small piece of electrical tape up and stick it into the black u-shaped sensor hole where the tip used to go in.
Jul 07, 2009 | Panasonic Panafax UF-790 Plain Paper Laser...
My office fax machine can receive the fax in the memory, but it does not print it.
May 19, 2009 | Panasonic KX-FL541 Plain Paper Laser Fax
Panasonic Panafax UF-880 Plain Paper Laser Fax - Info code 011
Remove the paper cassette completely, look in the cavity for a broken magnet or crumpled up paper. The machine thinks that there is no paper tray installed
May 08, 2009 | Panasonic Panafax UF-880 Plain Paper Laser...
Open the front of the fax machine. Then pull down the the tray that has the down arrow imprinted on it. Locate the glass strip towards the back, just behind the center roller. Use a cloth and rubbing alcohol to clean the glass and that should remove the black line.
Apr 22, 2009 | Panasonic KX-FL511 Plain Paper Laser Fax
Fax uf 590
Pull open the bottom of the operating panel just above the paper tray one inch 1". Clean the small scanner glass with alcohol, it's hard to see. It's just above the first rubber roller at the black base of the machine.
Feb 19, 2009 | Panasonic UF-590 Plain Paper Laser Fax
Model - Fax Machine Panasonic KXF-110
it would cost as much to have a technician replace the ADF motor as a new fax machine.
Feb 04, 2009 | Panasonic KX-FL511 Plain Paper Laser Fax
Fax is not picking the paper from tray.just clean paper pick up ruler.or replace it.MIAN AKHLAQ
Jan 01, 2009 | Panasonic KX-FL511 Plain Paper Laser Fax
Failed Pick Up
use alcohol and dry cloth and clean all what lubricated,fax machines don`t lubricate!!!!!!!.after cleaning the fax will work properly
Oct 29, 2007 | Panasonic KX-FL501 Plain Paper Laser Fax
Panasonic KX-FL521 Plain Paper Laser Fax Logo
328 people viewed this question
Top Panasonic Fax Machines Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Michel Smith
Are you a Panasonic Fax Machine Expert? Answer questions, earn points and help others
