Question about Honda Maxus Pressure Washer MX5222
Retentioning a pull cord
How do i retention a pull cord? do i pull the assembly off?
  • firehead May 11, 2010
    Can you tell us the model of the engine?
  • 3 Answers
Yes
Posted on Jul 14, 2009
Troy bilt pull cord wont retract
Recoil spring is broken or slipped out of retention slot. Coil needs to be retentioned or replaced. Unless you have done this before I recommend taking to pro. This is easy job if you have the jig but almost impossible if you don't.
Jun 29, 2014 | Troy-Bilt 4-Cycle Curve Shaft Gas String...
How do i clean the spark arrestor on a ryobi ss30 trimmer?
Got a manual? They likely tell you there. If not:
Obtain and use the proper tools for removing the arrestor retention assembly/diverter and leaving the muffler in place right where it is at. Once the screen is in your hands? A blast of carb cleaner and a fine wire brush is all the attention it will need. Re-install, snug your retention screws/bolts and go play in the grass! :D
May 07, 2010 | Ryobi Garden
I have a leaking flow valve (part#8182862) on my whirlpool duet washer model#GHW9300PW4. I have a replacement valve, and have the existing valve exposed and disconnected on the interior of the washer...
The retention pin is actually a Torx screw, requiring a #T20 size torx screwdriver. Once removed the flow valve assembly simply slides sideways to be free from its mounting on the chassis.
Dec 25, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Keyboard freezes intermittently on 24" intel iMac
Run a Spyware, keylogger and virus check.
Typically, especially with keyloggers, the process of retention, assembly and transmission of your keystrokes to the recipient site or retention file will delay other processes while such transmission or retention is completed.
Scripts Kiddies don't write code that is efficient in handling data with consideration of the particular clock cycling for the simple fact that the code is written for the widest variety of processors and configurations, and as such the viral processes interfere with your legitimate use of your own system.
May 09, 2009 | Apple 24" iMac Desktop
How do you change headlights on a 2006 trailblazer ls?
first remove the headlamp assembly. there should be one or two clamps with a rubber grip vertically inserted behind the headlamp. they can be difficult but you just pull them up to remove the assembly. Then the socket should have either a snap in or twist in retention system remove it and you can pull the bulb. when you replace the new one be sure not to handle it with your hands. use a clean cloth, glove, or other item to insert it and then reverse the procedure to install the rest.
Mar 28, 2009 | 2006 Chevrolet Trailblazer
Replace front brake pad 2003 toyota 4 runner
Diagram is unnecessry.
Pull both front wheels
Work one at a time leaving the other for reference
Find the retention spring ... its a paperclip thickness wire spring... dislodge center retention loop and undo from both ends which engage brake pad retention rods.
Pull the rods out
Pull the old pads out... laying everything on the ground
Use scrap wooden wedges to pry between the rotor and the caliper ...inside and out until the calipers are fully withdrawn. Use the new pads to measure if they are far enough back.
Note... the brake fluid will have dropped in the master cylinder over many months of wear... do not fill it. When the calipers are pushed back they will fill the reservoir again... one wheel at a time.
Be sure to identify the correct pad based on what you took out and what is on the other side (if you screwed up the layout)
Make sure to take the old antisqueek backing plate from the old pad and place it on the new pad. They don't use lubricant on these anymore.
Replace the pads... the retention rods... then the retention spring
Do the other side
Then progressively step on the brake peddle until full tension is felt
Check the master cylinder reservoir... probably needs no additional fluid.
New pads will register in existing ridges in each disc in no time at all.
You should check the discs to see if they need to be replaced during this operation...using some calipers
Mar 19, 2009 | 2003 Toyota 4Runner
95 Corolla parking light
Remove the retention screw above the headlamp, and pull it straight out towards the front of the car. Note that it may be slightly difficult to pull, you have to defeat a retention tab that holds the rear of the lamp assembly.
Oct 04, 2008 | 1984 Toyota Corolla
Abit bd7m - no video, no keyboard, no mouse
Why does the BD7 board fail to POST with sirens? Is the mainboard faulty? A:
  1. If the CPU retention unit or heat sink wasn't installed correctly, the bad heat dissipation will cause P4 CPU over temperature and fail to boot up.
  2. Please check the black CPU retention is fully inserted into the holes in the mainboard. Below picture illustrates a bad installation- there is a gap between retention unit and mainboard.
  3. Please make sure the white nails were fully inserted and can prevent CPU retention unit from loosen.
  4. Double check the back side of mainboard. If the feet of CPU retention unit and white nails were correctly installed?
Mar 04, 2008 | Abit BD7m Motherboard
Honda Maxus Pressure Washer MX5222 Logo
188 people viewed this question
Top Honda Garden Experts
John Trevino
JOHN LAPIER
Are you a Honda Garden Expert? Answer questions, earn points and help others
