Question about Freezers
Frigidaire Frost Free Commercial Freezer
Why is there ice forming in the bottom of my frost free freezer?
  • 1 more comment
  • Anonymous Sep 06, 2008
    the same hapen with a Kenmore I have. I will try running hot water
  • microgpaphic Jan 24, 2009
    This freezer has always developed ice at the back of panel and down underneath the lowest draw, but now its getting worse. The hotpoint engineer said he could not find a problem. anyone out there help?
  • Anonymous Mar 31, 2014
    no power, outlet is fine
  • 473 Answers
The drain has most likely frozen over. It is at the bottom behind the back panel inside the freezer. You will need to remove all of the ice and run hot water down the drain until it is clear.
Posted on Nov 16, 2007
Went to get something out of the freezer this morning around 10am and notice that there was some items inside that was not frozen and water underneath the freezer door. Found out by my son that he had opened the freezer around 2am and had thought that he closed the door all the way. Now the temperature alarm light is on. What should I do?
Posted on Jun 24, 2010
Upright freezer not freezing food and ice forming on back wall
is the top of the freezer full where it can breathe remove something to help it breathe
Sep 10, 2012 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Freezer compressor gets hot
Check behind and underneath for dust buildup, sounds like your compressor needs cleaned on the outside, the dust is causing it to overheat and retain condensation, hence the ice buildup. Easy thing to check, good luck.
Jul 02, 2017 | Frigidaire 19.53 cu. ft. Commercial...
Ice if forming along top gasket area and side of freezer where
If we have ice on the inside of the freezer it means air is being pulled into the box somewhere. The most likely place is the door seal, it sounds like you already checked it, but I would suggest that you look very close at the bottom and aides of the seal too, it could be leaking in air from there. Check the inside liner for cracks and seal them if you find any. Look at the corners of the cabinet to make sure there is not room for air to come in.
Air leaks will lead to frost, it is just hard sometimes to find where it is leaking in.
Apr 13, 2010 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
I have a frigidaire freezer upright model#ffu20f9gw3
Without any additional info, there are a lot of possibilities:
1. Condenser coil (underneath unit) is dirty and clogged.
2. Compressor is failing. (need A/C tech)
3. Metering device is clogged. (need A/C tech)
4. Refrigerant charge is low. (need A/C tech)
5. Door seal is broken (frost will form around door).
6. Defrost heaters are stuck on (replace defrost timer located underneath unit at front).
7. Condenser fan has failed (underneath freezer on back).
8. Evaporator fan (inside fan) has failed (ice will form on cooling coil).
This should get you started...
If this helps you, please select YES to the first two ratings questions. Thank you, and Good Luck.
Oct 13, 2009 | Frigidaire Freezer 20.3 Cu. Ft. Frost Free...
Freezer forming Ice on the bottom not draining water
pour some hot water in the drain if this does not work use compressed air
Aug 23, 2009 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
Sheet of ice forms in bottom of freezer
Frost free fidges are supposed to stay frost free because the automatically defrost regularly. When they do this they may drain water down to the bottom of your fridge. Look for a tray that catches this water underneath the unit. Make sure yo keep it emptied. If you live in a very warm climate you may be getting a lot of humidity inside. There may be a switch that you can change for lower moisture.
Jul 01, 2009 | Freezers
Maytag model MQU1556AEW, frost-free freezer forms ice in bottom.
I'm not sure if this will help but the freezer that is located on the bottom of my refrigerator started forming ice on the back part where the cold air was supposed to be coming out. I kept hearing a hissing sound like water dripping on a hot surface. I called the repair man in and he had to replace the defrost timer. Once he did that it worked like a charm.
I am not an expert by any means although removing ice from a frost-free freezer is a pain and this took care of the problem for me. Good luck!
Apr 07, 2009 | Maytag Freezers
Ice build-up
Defected DEFROST HEATER can cause frost build up on the panel at the back of the freezer,and freezer stop cooling and ice frozen on unit so air could not flow to refrigerator side.Water will coming out caused of unbalanced freezing,and causing the flooding of water in the floor. You must change this defroster heater assembly so it will works normal again..
Hope this may help;
Sep 22, 2008 | Frigidaire 20 cu. ft. / 566 liter Upright...
Is the frost build-up in my freezer normal? Why do I have ice in forming the the bottom of my frost free freezer?
Nov 16, 2007 | Freezers
Freezers Logo
1,009 people viewed this question
Top Freezers Experts
Dennis Boxerman
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Freezer Expert? Answer questions, earn points and help others
