Question about Elotouch 17" LCD Monitor
Pc4 elo lcd screen
Hi I have a pc4 pos system the screen is comin up as pink on strart up for 3 secconds and becom blank when i plug a monitor on the back the monitor is working fine but lcd attached tu my system is not working .I m not able to she anything.
please someone can helpme out?
Your BL Inverter is bad.
Posted on Apr 28, 2008
I use a Mac Mini with Elo 1515L at its supported resolution for Mac. In the beginning, it turns on and I can see everything on the monitor, then it goes blank and gives me an "out of range" or "no...
An Elo 1515L has a set resolution of 1024 x 768. I'm not sure if there is something special with Macs, but you can check the OSD (On Screen Display) settings.
Apr 28, 2017 | Elo 1515L (Grey) (Dark Gray) 15" LCD...
Plug in the monitor and it comes on momentarily but then cuts out to blank screen.I got this given to me and am just trying to see if Ican use it with my hp system thanks.
Hi. If the display goes out after displaying the Power On Self-Test (POS) and the power indicator turns amber, it means that the display resolution of your computer is higher than what SyncMaster 192S can handle.
If you still have the monitor that you were using before, connect that one and change screen resolution to 800x600 and 60 Hertz. Turn off your computer then change monitor/LCD and turn on your computer. You may change screen resolution to optimize display on your SyncMaster 193S.
Let me know if you need help changing screen resolution or if you don't have the original monitor that you were using on your HP.
Aug 18, 2010 | Samsung SyncMaster 193S
Touchscreen is inaccurate
if the POS unit runs windows go to start/control panel and look for the monitor software (ELO is a popular touchscreen) and you should be able to calibrate the screen in the options
Apr 13, 2009 | Computers & Internet
This issue could be either the Monitor inverter failing or it could be your Video card. If you have another computer available, plug the monitor into a different computer and see if you get the same behavior, if you do, then the monitor is failing and needs to be replaced. If on a different computer it works fine, then you may have a video card failing. Does it seem to happen the longer the monitor is on? Could be as it heats up, it starts to fail.
Mar 03, 2009 | Dell E153FP 15" LCD Monitor
Broken Elo Monitor Screen
Touch screens are even more expensive that straight LCD panels. This repair may cost more than the original monitor. Why do you need another panel? Is the panel cracked or is the touch screen portion not working correctly?
Mar 28, 2008 | Computers & Internet
Blank screen
elo touch screen ET1925L -7SWA1 i get no picture on the screen but i hear sounds coming ou the back of theespeakers.. could it be the inverter?? help
Oct 24, 2007 | Elotouch 17" LCD Monitor
Monitor no display
hi, check out the connector pins if any is damaged or bent, if not try it on a different system just to confirm that its not the display card problem, let me know??
Oct 20, 2007 | Dell E173FP 17" LCD Monitor
How to adjust sensitivity on ELO Touch Screen monitors
you probably have a capacitive screen, it only responds to finger press. You need a resistive screen to be able to respond to finger, nail, or pen press.
Aug 28, 2007 | Elo 15" Touch Monitor
Elotouch 17" LCD Monitor Logo
240 people viewed this question
Top Elo Computers & Internet Experts
Ricky Ostrom
Ricky Ostrom
Sam DeGonia
Level 1 Expert
Are you an Elo Computer and Internet Expert? Answer questions, earn points and help others
