Question about Pioneer DEH-P690UB CD Player
When using aux. 1 (stereo mini) sound only comes from front speakers. Is that all I get?
    Problem Solver:
  • 14 Answers
Something is wrong with the aux port or the cable but also check the fader control
Posted on Jul 14, 2009
How do I connect a mixer to my pioneer receiver
mixer audio leads go in to receiver (you could use the aux in on receiver),then switch receiver to AUX on the front.
you need receiver to recognize the mixer....
Jul 24, 2016 | Pioneer Audio Players & Recorders
Tip
How do i connect my iPod to a Pioneer Car Stereo
<p>It is advisable to listen to your iPod through headphones while driving in the car. Not only is it dangerous to completely cancel the sounds of the road as it is often illegal in many cities across the country. There is an alternative, however. In just a few steps you can use your iPod to your car stereo speakers and use the car to listen to your music, podcasts and audiobooks. No brand car stereo makes it easier to connect these beautiful than Pioneer. <br /> <p><br /> <p>1. Connect one end of the mini-jack on your iPod headphone jack. Once done, set your iPod or on your dashboard or your car seat so that it will not tip over while driving. <br /> <p><br /> <p>2. Find your sound system's auxiliary input Pioneer. It is often located in front of the front panel stereo, but can also open the front or back of the unit completely. If the extra connector on the back of the stereo itself, then you remove the panel. When it comes to this, see the instructions that came with your sound system is provided for further guidance. <br /> <p><br /> <p>3. Connect the other end of the cable mini-jack for stereo aux port. This will allow your iPod to the audio signal through the cable to the stereo and the stereo signal will pass to the car speakers. Most often, when something is plugged into the stereo aux jack will work in stereo. In some models a setting to select the additional connection. Whatever the case, now you can sit and enjoy your iPod for that long car ride. <br />
on Aug 09, 2011 | Apple iPod touch
All led lights are going side to side no sound
Make sure you try out all sources using the remote.
Press repeatedly to switch between
AUX 1,
AUX 2,
LINE IN and
FM Modes.
Mar 28, 2016 | iLive It082b 2.1-channel Stereo Sound Bar...
How can I connect my itouch to my pioneer VSX-52TX receiver
You can use the RCA jack and an RCA cable to your aux in on your receiver.
Oct 16, 2013 | Pioneer Audio Players & Recorders
Karaoke, plenty vocals in floor ,no music without loud humming
Try a couple things
Try plugging the player directly into one of the stereo channels using correct cables (just go to Radio Shack or someplace like that) - you'll probably have to get a stereo to mono "Y" adapter that terminates in two mono mini or 1/4 inch male jacks ... if mini, then upsize them with another adapter ... it's not as rigged as it "sounds" ...
The benefit is, it is actually simpler and you will be able to use all of the channel strip controls for the player just as you would for a mic or guitar plugged in to a channel, and the volumes will behave more as you expect them to ...
Just be absolutely sure the cable you assemble is correct, meaning stereo single 1/4" (or whatever it is, two RCA's whatever) going into the player, and terminating on the other end with two MONO 1/4 inch jacks ...
I use this kind of "Y" connector to play my iPhone through my 808s and it works very well, and I have full control and no confusion.
I'm not sure what you mean by running your player through the "aux in" on the front of the 808s - there are different versions of this mixer, but mine doesn't have anything labeled "aux in" - if you mean the tape inputs on the right front ... RCA jacks ... that should also work, but I prefer just using the normal input channels ...
For example, use input 8 - it's labeled "mic 8" - but if you use the two 1/4" jacks above the Canon jack the mixer will automatically adjust to line level ... on my 808s these 1/4" jacks say "stereo mic/line" ...
Also, I would bypass the effects section completely unless you need it and understand how it works ... and
Make sure the "Power Amp Routing" switch is in the correct position ... since you are using mains and monitors you probably want the "mono" position, which disables the stereo outputs and instead uses one of the power amps for the mains and the other for the monitors ... on my 808s this is the "in" position
On the back, you'll use the speaker outputs labeled "left/main" to go to the main speakers and "right/monitor" to go to the monitor speakers
It's actually pretty simple - with the Power Amp Routing switch pushed in, you no longer have stereo, so ignore "left and right" on those speaker outputs, and follow the labels for "main" and "monitor" .....
Hope that helps!
For audio expertise and PA system help with feedback and noise, try our new DVD "PA Systems for Small Groups" at www.rexark.com
Jan 30, 2010 | Bob Mackie SRM350 Main / Stereo Speaker
When I plug my iPod into my car stereo, it's a Kenwood KDC-W3041, sound only comes out of the speakers in one door, but when I play a CD, sound comes from speakers in both doors. What's wrong?
If your using the aux plug in the front make sure the plug is fully inserted into the ipod and the stereo. then make sure all audio settings are set correctly. If you are using any other type of connection for your ipod ensure the connection is not loose.
Dec 10, 2009 | Car Audio & Video
No sound on my dell optiplex 330
Unless you have headphones, you need speakers, preferrably amplified speakers.
Another way the address the issue is to use a cable to connect your computer to your home stereo if it has an auxilery input (aux/cd/tape input) then all you need is a cable with two male RCA plugs on one end and an 1/8 inch stereo plug on the other end.
The 1/8th inch plug goes into your computers' sound "out" and the rca's go into the aux/cd/dvd "IN" on the stereo.
this cable can be purchased for under 10 dollars at walmart, though amplied speakers wont be much more expensive.
Hope this helps you decide which direction to go..
Regards..
Apr 04, 2009 | Dell OptiPlex 330 Desktop Intel Celeron...
Can I plug my MP3 player into the aux. socket on my car radio, with the appropriate cable and play the stored music?
You should be able to do that as long as you have the right cable.
Most of the mp3 players have a "mini-stereo" jack (3.5mm) and some car stereos have the same type of jack for "aux" input, and others car stereos have RCA jacks for the "aux" input.
Even if the jacks are not the same type, you can use an adapter cable that converts the mini-stereo jack to an RCA jack. You can find them at many places like Best Buy, Circuit City or Radio Shack.
Depending on the type of car stereo you have, you would normally press the source button to change between the tuner, cd player, aux or whatever you may have connected to the stereo. You may even have a seperate button to press for the "aux" input.
I hope this was helpful to you, if you need more information just ask, and please give more info on the type of mp3 player and the make and model number of the car stereo.
Jun 21, 2008 | Car Audio & Video
No sound comes out of my home theatre hen i plug it on my tv
hello
use the link below to check out if this is your tv. http://www.p4c.philips.com/files/2/29pt4273_75r/29pt4273_75r_dfu_eng.pdf
if it is, then go to page 5 in the manual.
connect L/R from monitor out to the AUX of your amplifier. when you want sound from the tv, select AUX as source from the front panel of your amp.
hope this helps
May 24, 2008 | Audio Players & Recorders
Wiring with a sattelite receiver and new Samsung TV
Nope RamaTheMan - you are incorrect! No way to get an actual surroundsound from your TV on this turd - this came straight from the Samsung FAQ -
"You cannot get surround sound from your television. On the other hand, if your television has audio output jacks you can connect your TV or Set Top Box to your Home Theater System and get stereo sound (that is, sound from the left and right speakers of your Home Theater System only).
To connect your TV or STB audio output jacks to your Home Theater System and get stereo sound, follow these steps:
  1. Turn off your TV and Home Theater System.
  2. Connect the Audio Out jacks on your TV to the External Audio Input jacks on the back of your Home Theater System. The External Audio Input connectors are typically labeled AUX IN. Note: There are usually two pairs of Audio Input jacks, AUX 1 and AUX 2. Each pair has a jack for the left audio input and the right audio input. Often, there are two Video AUX IN jacks as well. You can plug the audio cables into either audio AUX 1 or AUX 2. See the following diagram.
  1. Turn on your TV and Home Theater System.
  2. Press the Function Button on the front panel of your Home Theater System until the display on your Home Theater System shows AUX 1 or AUX 2.
For advanced installation, if you are using a High Def STB, you can connect an OPTICAL connection from the STB to the HTS. This is a specified cable that must be purchased separately.
In either instance, you must then set the HTS to its auxiliary input. (i.e AUX 1, AUX 2, DIGITAL IN) in order to get the sound from the HTS.
Note: If your television does not have Audio Out jacks, you may be able to get stereo sound by attaching the Audio Out jacks on your VCR to either the AUX 1 or AUX 2 audio inputs on your Home Theater System. If you attach your VCR to AUX 1 or AUX 2, you will have to tune your television to channel 3 or 4, and then tune to the station you want to watch on your VCR."
Dec 26, 2007 | Samsung HT-X50 System
Pioneer DEH-P690UB CD Player Logo
56 people viewed this question
Top Pioneer Car Audio & Video Experts
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
