Question about Hitachi Performa CP-RS55 Multimedia Projector
No power lights
One day it was working then it lights come on at all.the power lead is working.any ideas?
  • Dick 2 May 27, 2008
    Suddenly stopped working. I changed fuse in the plug only to find that this fuse blows every time I try to switch on the projector at its on/off switch. The bulb, projector and leads are otherwise all in very good condition.
  • Anonymous Aug 06, 2008
    i turned off my hitachi cp-rs55 projector and blew the internal fuse i need help trying to locate said
  • 55 Answers
Ok " could be a internal fuse, or bad transformer
Id check for a fuse first
Posted on Jan 21, 2008
Why won't my PC power-up?
Firstly you should not unplug your computer for long times. Inside is a battery to keep the BIOS alive. When you unplug it, it flattens the battery and if left unplugged for a long time, it kills it. This means that the BIOS now starts in default mode, which can lead to many problems because all the custom BIOS settings are now lost forever or until you or someone else change them.
Change the battery on the motherboard and try again.
The reason why the LED was flashing then stops, is that the battery has a small charge enough to be stable. Now that your BIOS battery is dead, you will never be able to charge that battery again, so replace it.
Sep 01, 2014 | Watches
I put in a new 200 w Malibu LV. It worked one day, then only one light would work. The next day it worked again on all lights then it went back to lighting only one. I'm using a combination of 12 LV...
I don't have repair for defective transformer.
The transformer puts power on the wire. Buy multimeter and check voltage across the terminals.
If wires are loose, or bulbs are not connected to wire, or bulbs burned out, or if wattage of bulbs is mis-matched with transformer wattage, then lights might not work as expected.
Aug 16, 2011 | Intermatic & Malibu& 300 Watt Power/Pack...
I have a 2000 LHS, i was at a stop light the other day and got run into, from the back[just a scratch or two]. later i checked my brake lights and discovered they no longer worked[i had checked them about...
Have you checked for power at the sockets? How about power out of the turn signal switch? Is the third brake light also not working? If that bulb is good and there is no power at the socket than you have a bad break light switch. Check for power in and out of the switch with the brake pedal depressed. You can also unplug the brake light switch and jump it to confirm the lights work.
I can get you the wire colors if you need them.
May 08, 2011 | 2000 Chrysler LHS
Need help with 2000 grand prix stop lights. power good at the fuse, power wire good from fuse box to stop light, brake pedal switch works and still no stop lights..
Look for a broken ground wire at the back of the car!
You ran the power all the way down to the bulb which means there is only one thing left. The ground lead!
You can try grounding the brake light socket with a test light or a lead from your multitester to check it.
Nov 29, 2009 | 2000 Pontiac Grand Prix
Brake lights don't work, fuse is good, middle brake light works
Very popular problem for this vehicle. Check for power at the brakelight switch. If you have power, depress the pedal and make sure the power is transfered to the next terminal. The switch is very affordabl and quite simple to exchange. Good luck, Dana
Aug 26, 2009 | 1998 Dodge Stratus
Horn not working
Did it just stop working one day? A horn is mostly solid state and rarely just stops working. First place to check is the fuse panel. Make sure the fuses are good. If the fuse is good, you may have a bad relay. To test that, get a volt meter or test light and connect it to the two leads going to the horn. (the horn will usually be in the front of the car, behind the bumper or inside the wheel well. Get under the car and look up inside the front. It should be in there somewhere). When you have the test light on the leads, turn the key on (not th engine) and have someone depress the horn button. If you get power to the two leads, it's time for a new horn. Good luck.
Jul 07, 2009 | 1988 Toyota Land Cruiser
Monitor has just stopped working
perhaps a repair shop. most electronic devices fail this way
Oct 06, 2017 | Hanns.G Corporation HX191DP LCD Monitor
Infocus LP70
its not geting power lust like mine
Dec 11, 2007 | InFocus LP70+ Multimedia Projector
Pioneer 345 DEH
Intermittent faults especially one as intermittent as yours can be very difficul to trace but the first things to check are loose connections on the power supply leads at the back of the radio and if they are ok you will need to dismantle your radio and check for dry joints usually around the plug and if needed resolder these dry joints
Dec 09, 2007 | Pioneer DEH-345 CD Changer
Hitachi Performa CP-RS55 Multimedia Projector Logo
114 people viewed this question
Top Hitachi Office Equipment & Supplies Experts
Chris Goulet
Are you a Hitachi Office Equipment and Supply Expert? Answer questions, earn points and help others
