Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
WHEN WE TRY TO OPEN OR CLOSE DOOR ONLY THE LIGHT COMES ON AND YOU HEAR A CLICK UP BY THE CONTROLLER
    President:
  • 3,197 Answers
Unless your door is stuck in the open position you have a bad logic board.
Posted on Jul 14, 2009
4 Suggested Answers
scottyfixit
  • 186 Answers
SOURCE: garage door opener
Pop open the cover and check for loose wiring. Also check to see if the capacitor is still good that powers the motor.
Posted on Apr 25, 2008
Door Tech
  • 98 Answers
SOURCE: Garage door opened, won't close
If you can press and hold the wall button and the door will go down, you have a photo eye issue. Check the photo eyes at the bottom of the door.
Posted on Jan 17, 2009
  • 118 Answers
SOURCE: Craftsman garage door opener - Clicking/blinking - no open/close
First, check the safety eyes. There should be a light on each eye that is on. If not, realign the eyes. If that does not work, check the force settings. They are the blue adjustment screws. They should be set on 4-5. Do not go above 6 or there is a problem with either the door or opener, or both. If this does not work check all of the wiring on the back of the opener. 1 should be a red wire, 2 should be three white wires and 3 should be two black wires. Check the wiring to the wall button. the back of the button indicates red and white screws. To take off the wall button you will have to remove the big white button if you have the "deluxe wall control" If this does not fix it, respond with more info on door position and what happens with remotes and wall button.
Posted on Feb 26, 2009
The unit is displaying a sequence of 5 flashes with the amber light. When I try to open the door, it will only go forward and backward aprrox. 1 ft. Any suggestions on what I should do?
Craftsmsman 1/2 HP opener indicator light blinks five times ...
? 0:29
https://www.youtube.com/watch?v=AvXJd-tYCJ0
Apr 28, 2012 - Uploaded by bship452
Then showing the amber indicator light blinking 5 five times, stops ... push remote to operate opener, you hear a clicking sound from the unit. ... Show more .... blink 5 times (looks almost alike) If I forced the garage door closed, ...Missing: sequence
Sears Garage door opener problem - Home Forums
ths.gardenweb.com > Home Forums > Garages/Workshops
Jun 27, 2006 - Now, I cannot get the light in the sensor at the door to come on. ... the green LED went OUT about 1/2 way up the door opening sequence. .... other is working (I don't recall if it's green or amber, but know that it is lit.) ... Their is also a green LEDflashing 2 times every 5 seconds or so at control center of unit.
Craftsman Garage Door Opener Problem - Home Forums
Jan 05, 2016 | Building Materials
Frigidiare lffh21f7hwa freezer When door is opened light will flash on and off you can hear a clicking sound, every so often it will have to be reset by unplugging
You are talking about the inside light right? The clicking is coming from the controls panel right? I think the problem is related to the control board itself because there is a relay that switches the light on when the door is opened part number=> 297366300 Frigidaire Freezer Main Control Board Otherwise if removing the bulb will stop the problem, please try that. Appliance 911 Sea Breeze
Dec 06, 2015 | Refrigerators
Garage door opened fine but now when I try to close it, all I hear is a buzzing sound for 3 sec., light comes on but door won't go down.
Your trolley may be jammed against the bolt just in front of the motor unit. If so, loosen the chain enough to relieve the strain on the chain and then run the opener until the door is closed. While the door is closed locate the 'up limit' control on the side of the motor unit. Turn this control 2 full turns in the opposite direction of the arrow printed on the cover. Tighten the chain.
Jul 18, 2011 | Sears Craftsman LiftMaster Chamberlain...
When i open the door only the light is supposed to come on. the light comes on but the fan and turntable run also.
This is a very hazardous condition. DO NOT stick you hand inside the unit as you may well get yourself burnd by microwave radiation. It appears that there is either a problem in your control panel assy or that you have time on your timer and the unit has a defective door switch allowing the magnetron to keep running with the door open. There are at least 3 protective micro-switches in the door closed and latched circuit. Very slowly depress your door open button or pull the door open slowly (depending on unit type) and listen for 3 distinct switch clicks. All 3 click should happen in less than one one half inch of the door opening. Try is sevral times and listen for the 3 clicks repeatedly. If you do not hear 3 clciks then you have a bad micro-switch If you hear all 3 clicks, more than likely your controll panel has a failed relay on it.
Jan 06, 2010 | Food Processors
My Whirlpool Gold side by side refrigerator when you open the refrigerator door you hear the sound of maybe a relay trying to open and shut. The display panel that shows the thermostat setting is off and...
sounds like your having an issue with your door switch its just not opening the machine still thins the door is closed
that clicking you hear could either be the switch itself arcing inside
not knowing your model number i cannot be sure
but that is ehre id start
www.appliancepartspros.com
type in your model
the door switch should be in the body/cabinet section
Oct 26, 2009 | Refrigerators
Liftmaster pro 1/2 hp wont shut in one button press
You have a door sensor problem. Either your main light bulb is burned out or you don't have one in your opener. The clicking sound you hear is the relay for the light. Both of the door sensors should have a small light that is lit. Tweak them until they are.
Jun 28, 2009 | Sears Craftsman LiftMaster Chamberlain...
Door will not close. led blinking 5 times
Is your door open or closed? If you release the door is it easy to open and close manually? Does the opener run with the door released?
Jun 22, 2009 | Sears Craftsman LiftMaster Chamberlain...
Microwave not working
HI, this is a faulty control panel. replace asap if possible.
May 29, 2009 | Whirlpool Microwave Ovens
I push wall button and hear clicking but won't open
Try unplugging the operator. This may reset any problems you had.
Jan 11, 2009 | Sears Craftsman LiftMaster Chamberlain...
Garage door opener
Apr 21, 2008 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
98 people viewed this question
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
