Question about Boating
I own a mercury black max v6 200hp outboard. the motor has a engine miss at a idle and low speeds any idea. Ed Lindsey the year is a 1987
4 Suggested Answers
SOURCE: Free wiring diagram for 1978 Mercury Outboard 115 HP boat motor
I have a maintainance manual for this engine (I have the same one) with pages of wiring diagrams. What specific system/area are you interested in, I could scan in the page(s) and email them to you.
Mark
Posted on Sep 20, 2009
muffteck
  • 202 Answers
SOURCE: wiring diagram for 1982 Mercury 6cyl outboard tilt
go to ebay and buy a manual
Posted on Mar 27, 2010
SOURCE: I have a 1990 90 HP mercury outboard. It is rough idling and surg
I have a 90 hp force ob. when i run it with the ears she runs fine lets me bring the throttle all the way up. when i but it in the water thru the wake area i can do 4 mph once i'am out of the wake area and give it the gas she dies, any ideas
Posted on May 20, 2010
2006 mercury outboard opti max 200 engine alarm, (4 beeps). oil was run low, do i need to prime the system or should it prime itself?
The low oil sensor is not "seeing" the oil in the tank...(mine does this when I crank it,, the low oil light stays on).. It uses plenty of oil,,I quit worrying..- -don't feel like taking the oil system apart..
Get one of these.. I have one for every outboard I ever owned..they DO come in handy...
Mercury Outboard Manuals by Seloc 1965 2014
Jul 31, 2017 | Mercury Cars & Trucks
What year is a evinrude outboard with serial number 1451821
The motor HP is critical in such searches. Here are all the resources you need to find the information yourself.
About this result
How To: Outboard Engine Serial Number Year Match, iboats.com How ...
www.iboats.com/basics/serial_number_year.html
  1. Cached
  2. Similar
For engines prior to 1969 refer the the Johnson 1960-1979 serial number year chart located here. If you have a commercial model refer to the Johnson commercial serial number year chart located here. Evinrude changed how they indicate year in the model number in 1980.Mercury Outboard · ‎Evinrude Outboards 1950-1979 · ‎Johnson Evinrude Commercial
[PDF]5006145_Model Number Reference.fm - Evinrude
shop.evinrude.com/media/document/ModelNumberReference.pdf
  1. Similar
MODEL NUMBER DESIGNATION - OUTBOARDS. Model Years 1980-1998. V E 70 T L ED A. MODEL VARIATION. A = Australia. B = Belgium. C = Canada.
Evinrude Outboard Motor Model Numbers & Codes - Marine Engine
www.marineengine.com/manuals/evinrude/
  1. Cached
  2. Similar
The nameplate should contain a model number and a serial number. The model number will identify the year and certain details of that motor. 1980-Present: Evinrude outboards from 1980 to the present use a model number that can help determine the year and features of the motor. See the model number code here.0.5HP · ‎0.9HP · ‎1HP · ‎1.1HP
Marine Motor Look-Up Guide - Auto Repair Manuals
www.autorepairmanuals.biz/page/599222
  1. Cached
  2. Similar
keywords: Find year, serial, number, model, number, #, outboard, motor, marine, motor, look-up, Johnson, Evinrude, Mariner, Mercury, Force, OMC, Yamaha, ...
EVINRUDE OUTBOARD MOTOR MODEL YEAR LOOKUP GUIDE ...
www.maxrules.com/models/OMC_models_files/EVthru79/ev_index_79.html
  1. Cached
  2. Similar
WHAT YEAR IS THAT OLD EVINRUDE? FIND OUT HERE ON OUR MODEL YEAR LOOKUP CHART! evinrude outboard with serial number Google Search
Nov 29, 2016 | Boating
1985 mercury 150 hp outboard V6 black-max.Where can I get a free service manual. I really only need the wiring diagrams. 1985 mercury 150 hp V6
go google and type in--- mercury outboard motor manuals --and there are pages of download manuals
if there is not one for your engine then alter the url question to --manual for mercury outboard engine 150hp v6--and see what comes up.
Sep 22, 2015 | Boating
How do I set the timing on my 1967 Mercury outboard motor? It starts but seems to sound like it has a slight miss, and when you idle down to put it in gear, it dies.
I have seen it done. The shell is removed to the points. A probe is inserted in the cylinder hole for #1. When the piston is clocked to TDC the breaker plate is locked when the piston touchs the probe and provides continuity. Some engines may require a few timing degrees either BTC or ATC. Throw in new points to eliminate the low end miss as weak spark at low rpm may not flow good on worn points.
Relist on outboard motor or boat section of Fixya.
Aug 30, 2015 | Mercury Cars & Trucks
Have 115 Hp mercury outboard motor missing at full throttle and on idle. At mid throttle it is running fine. Any Idea what the problem could be. Thanks, Milton
Have your spark plugs changed AND carbs cleaned and adjusted.
Usually that can also be caused by a seized advance system ( plate under the flywheel, commanded to turn with the throttle linkage... )
Aug 16, 2013 | Seloc Mercury Outboard Repair Manual, 1965...
Apr 20, 2010 | Raymarine Linear Feedback Unit For...
When I start my 10hp mercury outboard after priming it will run for a few seconds and then die. IF I push the throttle only button and rev it up before priming or set the low idle up higher and then prime...
Be sure to run the recommended fuel mix. most modern 2 stroke outboard engines run on 100 to 1, some times the mix is on a decal inside the cowl.
Cheers, Timo.
Feb 27, 2010 | Light Outboard Motor Boat Bass Fishing...
40hp 1987 yamaha outboard motor will run for 30-60
Sound like the fuel pump is not keeping up with the engine's demand. Check it out. Good luck. Hope this helps.
Apr 27, 2009 | Boating
Boating Logo
855 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
