Question about JVC Everio GZ-MG360 HDD Camcorder
Access & Power/Charge lights flashing - GZ-HD320 doesn't fire up
I have a GZ-HD320 ... when I open the LCD screen the video camera should (and did) start up ... the HD would spin up and the lens cover would open and it would be ready to shoot. Now, after just 1 week (it's brand new) I find that the camera doesnt fire up ... the HD spins up, but the lens cover doesn't open and the 'lazer strip' down the side of the LCD does this 'Knight Rider' thing. After 10 secs both the Access & Power/Charge lights start flashing together.
Any ideas anyone??
  • 21 Answers
SOURCE: White screen on LCD and two vertical lines-1 red & 1 blue
Hi, check the lense. It might be dirty or you may have left the lense cover down.
hope this helps,
Eric
Posted on Jan 03, 2008
  • 15 Answers
SOURCE: I have a JVC gz-mg130u HD camcorder that willnot work in Vista
The short answer is that unless JVC have released a firmware upgrade to this model, currently its not support for use on vista.
You can try here though, for some upgrade info,
http://support.jvc.com/consumer/support/index.jsp
Thanks
Posted on Dec 10, 2008
  • 4 Answers
SOURCE: screen flashes "Lens cap"
IT IS A DEFECT THAT JVC WILL FIX FOR FREE. JUST GIVE THEM A CALL AT 800-252-5722 AND THEY WILL TELL YOU WHERE TO SEND IT.
Posted on Mar 24, 2009
chazacisa
  • 4 Answers
SOURCE: Cannot access my data on jvc gz-mg21u camcorder?
Or if you want an easier solution download storm codec pack at
http://www.softpedia.com/progDownload/Storm-Codec-Download-20053.html
(23mb .exe file)
and you can easily open these .mod files, as well as almost any video file you throw at it!.... then convert for youtube using the youtube downloader at
http://youtubedownload.altervista.org/
(3mb file)
as it helps to compress big files into .WMV without losing video quality and also converts to avi, mpg, mov with only a couple of clicks.
~Cheers!
Posted on May 20, 2009
SOURCE: GZ-MC500
I HAVE FOUND THE ANSWER!
this is a strange method so bare with me (found the solution on another site)
turn on the camera and then hold it upside down then for want of a better word "tap" the camera near the lens (i tapped the mic in front of the flash) and hey presto your image will return!
dont ask me what this does as i have no clue, it might have the same error after you switch off the cam but just follow the same method and it will show images. or if your not happy giving your camera a slap then speak to JVC or any camera repair centre.
heres then link where i found this solution
www.avforums.com/forums/camcorders-video-editing/690055-jvc-ccd-lens-cap-error-claim-deadline-extended.html
Posted on May 21, 2009
JVC Everio GZ-HD3U red and green access light flashes... no buttons work as soon as i turn it on
some need the date and time set proir to using..may need to take battery off entirely and reinsert.. see if its in the menu somewhere..
Jan 11, 2014 | JVC Everio GZ-HD320 Hard Drive Camcorder
JVC GZ-MG680BEK No display. Can't use camera. I
Ok silly question you have removed the lens cap correct?
Apr 22, 2012 | JVC Video Cameras
No sound when trying to play back on TV. Can hear sound thru camera but that's it. It's a JVC GZ-HD320
Normally you require a cable to connect to the TV. It should have at least 3 RCA connections to connect to the TV: Yellow for video, red for right audio and white for left audio. The camera connector will have a small stereo type plug that has 3 sections on one stem corresponding to the yellow, red and white cables.
May 13, 2011 | JVC Everio GZ-HD320 Hard Drive Camcorder
When i open the handy cam i cant see what i am taken because the screen is black
hi penalvermary,
LCD problem..check the battery and the power that comes on it..maybe lack of power inside LCD..
There is also a contact from Camcorder to LCD..if you can check it the better.
mastergani
Jan 07, 2011 | JVC GZ-MS120 Flash Media Camcorder
Windows movie maker will not regonise my video camera which is a JVC GZ-HD320. It was suggested I get firewire but the camera does not have a firewire port.
Go into a search engine such as GOOGLE and type in the word driver with the model name of your camera. An updated driver is needed it seems for your Windows Movie Maker
Jun 11, 2010 | Cameras
Is there any way to download the set-up disk for my jvc gz-hd7u
Connecting the Camera to the PC
Preparation:
Set the camera’s power/mode switch to OFF.
NOTES
• When the USB cable is connected, turning on or off the camera causes malfunctions of the PC.
• Connect the camera directly to the PC, not through the hub.
• Do not use an extension USB cable.
• Saving the wrong kinds of files in a recording medium or deleting files or folders from a recording medium can cause problems with the operation of the camera. When it is necessary to delete a file from a recording medium, delete it through the camera. Also, do not move or rename folders and files in the medium on PC.
• Never disconnect the USB cable while the access/charge lamp on the camera lights or blinks.
1 Create a folder to back up files into.
2 Set the camera’s power/mode switch to STANDBY/ON.
3 On the camera, move the set lever to
\/ / /\ to select [PLAYBACK ON PC],
then press down.
4 Double-click [EVERIO_HDD] or [EVERIO_SD].
5 Select the folder that you want to back up, and drag & drop it into the folder you created in step 1.
SD_VIDEO:
Folder that contains video files. If you want to back up fi les individually, open this folder, and drag & drop folders such as [PRG001] one by one.
DCIM:
Folder that contains still image fi les. If you want to back up fi les individually, open this folder, and drag & drop files such as [PIC_0001.JPG] one by one.
When you have finished operation
Always follow the procedures below when disconnecting the camera, or turning off the camera/computer power.
Failing to do so may cause damage to the camera and computer.
1) Confirm that the access/charge lamp on the camera does not light or blink. (If the access/charge lamp lights or blinks, wait until it is turned off before proceeding.)
2) Double-click the [Safely Remove Hardware] or [Unplug or Eject Hardware] icon in the status bar.
3) Select [USB Mass Storage Device] or
[USB Disk], and then click [Stop].
4) Click [OK].
5) Disconnect the USB cable.
6) Turn off the camera and PC.
Sep 20, 2009 | JVC Everio GZ-HD7 Camcorder
JVC GZ-MG37U Menu screen won't come on, blue access lt. stays on
you have to check the firewire securety port....
it protect the camera from the wrong conections with the pc...
it doesn"t complot the camera work....
if you have a playback recorder deck it can wait ....
Jan 21, 2009 | Video Cameras
GZ-MG130U
replace the fpc wire which is coming from lcd disply unit to mainboard
Dec 26, 2007 | JVC 580136 Camcorder
JVC Everio GZ-MG360 HDD Camcorder Logo
188 people viewed this question
Top JVC Video Cameras Experts
Larry Stiles
Larry Stiles
Steven Wander
Steven Wander
Are you a JVC Video Camera Expert? Answer questions, earn points and help others
