Question about Sharp UX B700 Plain Paper Inkjet Fax
Printer keeps telling me printer error and i havechanged the ink cartridge already
2 Suggested Answers
SOURCE:
  • 59 Answers
SOURCE: I replaced my ink cartrige , it keeps telling me
Make the the cartridge is seated properly and the contacts are not dirty or soiled form touching them.You can remove the cartridge and clean the contacts with isopropyl alcohol gently and ley dry.
Posted on Feb 17, 2010
The printer keeps telling us to do an alignment, but the printer is already aligned and if we do an alignment we are just wasting ink. And is there a work around??
The prompt to do an alignment could be due to the cartridges in the carrier. Please follow the steps below to fix the problem:
1. Make sure the printer is on.
2. Open the printer cover. The print cartridge carrier moves and stops at the loading position, unless the All-in-One is busy.
3. Remove both cartridges from the carrier.
4. Close the printer cover.
5. Unplug and re-plug the printer into the power source to reset it.
6. When the printer turns on, reinsert one cartridge first.
7. Close the printer cover and check for any errors.
8. If no error appears, reinsert the other cartridge. Close the printer cover.
9. Replace whichever cartridge is causing the error to appear with a new cartridge.
You could also try a different known working cartridge to determine if the other cartridge is faulty.
Jul 28, 2011 | Lexmark X2500 All-In-One Printer
Error No. 5200 for Canon iP2700 even there is a new black ink cartridge installed. My colored ink is running low or maybe empty. Pls help. Thanks.
Hello thanks for using FixYa
Error 5200 is a service error
Follow this solution step by step
  • With the printer turned on,unplug it
  • Open the top and bring the ink cartridge holder to the middle
  • Raise the gray bar and remove the print head assembly with the cartridges in it
  • Lower the gray bar with the head missing and close the top with the head out
  • Restore the power,wait till the printer starts
  • It will tell you to put in the cartridges, Put in the cartridge
  • Restore the print head, close the top and the printer will resume working
Error will be removed.
If you have already tried all of the above and still you have error then it is probably that your Canon printer is in need of servicing by a service professional.
So go to the Canon Service Center. If you want to get support on Call then
Call Canon Support by phone, at 1-800-OK-CANON (1-800-652-2666)
I hope this solution will surely helpful for u
"If it is helpful" then please don't forget to click on Four thumbs which are given below this solution
THANKS
Keep Using Fixya
Feb 28, 2011 | Canon Pixma iP2700 InkJet Photo Printer
The printer keeps messaging ink on sseveral colours is low but it is not. Have even tried new cartridges but no difference, same message . Seems to be misreading ink level
Some printers need special software (that shipped with the printer) to "tell" the printer that the ink-cartridge has been replaced, and that the ink-levels need to be fully "reset".
Apr 23, 2010 | Computers & Internet
HP6180 Printer. I keep getting an error message, Ink cartridge em
some cartridges are charged up ( have a chip fitted to them )
If the chip is not charged to tell the printer it,s full of ink. this will cause the problem.
have you tried. unplugging the printer from the mains. then powering it back up.
also try using the printers own software to add new cartridges et,c.
you could also try re-installing the printers drivers/software if you have it,s instalation disk.
Mike @ Compurepair.
Jun 15, 2009 | HP Photosmart C6180 All-In-One InkJet...
Expired ink cartridge
You may be getting this error message due to the printer being able to tell that it is a non-hp cartridge. I don't know how it can tell, but mine says that too. I uninstalled the software and then reinstalled the software. And then I took out the cartridge and put it back in. See if this works for you.
Apr 07, 2008 | HP OfficeJet d145 InkJet Printer
Ink tank
Users having problem like ink cartridge is only partial used, but error code appear to check ink cartridge, maybe trying to taking out and putting back, it works sometime and problem occurs again,
  • By replace a new ink cartridge will sure help as the partial used one would be faulty already, and if you are using Canon ink cartridge, do call up Canon to report the issue and they will exchange a new ink cartridge for the faulty partial used cartridge as it due to the unique feature that Canon has build on the ink cartridges not properly done, which resulted to be faulty. Canon's purpose is to prevent the usage of 3rd party ink cartridges.
Mar 05, 2008 | Canon Pixma MP500 All-In-One InkJet...
Overiding Empty Cartridge error for Dell A10 962
I would take out both cartridges and put them in again. Realign the printer and the error codes should remove themselves. Try turning the printer off and on before puting the cartridges in again. That may make a difference. You can let your computer know not to tell you when the ink is low too. Let me know how this work for you.
Cynthia Charczenko
Dec 26, 2007 | Dell A940 All-In-One InkJet Printer
"ink cannot be correctly detected" error U130
Hold down the "Stop/Reset" button for 5 seconds and it dismissed the first message, but then there was another for a different cartridge, etc. Eventually I got it to work.
Jul 26, 2007 | Canon Pixma MP800 All-In-One InkJet...
Sharp UX B700 Plain Paper Inkjet Fax Logo
73 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
amir hamza
amir hamza
k24674
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
