Question about Sony ICF-SW11 AM/FM/SW Radio
Loud buzz all freq
Sony ICF-SW1s have not used for a few years. Added batteries today and can scan and get stations but the constant buzz does not go away even when the volumn control is at zero.
Thanks
Dan
I came across this web site while researching similar issues on my radio:
http://cc-module.com/sw1/sw1.html
Haven't tried it yet, but soon will... Good Luck!
Posted on Jul 26, 2009
Sony icf-sw77 - listening to FM if station feq is 102.0 it's distorted so have to tune to 102.05 - what's wrong here? It's the same for all FM stations AM seems fine...
Common problem and will need realignment and / or capacitor replacement. Usually on a few are bad but I recommend all to be replaced. Contact me .... poikaa(at)yahoo(dot)com
Dec 21, 2010 | Sony ICF-SW77 AM/FM/SW Radio
Sony icf sw100 broken battery case (the tooth on which the battery lid hinges)
Re Sony ICF-SW100 battery case lid.Ive had same problem with battery case lids on this these units, I used a strong rubber band around the length of the whole battery case to keep lid in place as no parts available in Australia. Love the radio, have had 4 over many years.
Nov 11, 2010 | Sony ICF-SW100S Radio
Sony Radio ICF-SW7600 intermittent working
These radios are subject to bad electrolytic capacitors. Need to replace them. Not an easy job but can be done for about 25 dollars plus shipping. Rod ( poikaa@yahoo.com )
Apr 14, 2010 | Sony ICF-SW7600 AM/FM/SW Radio
My ICF-SW7600 has a clipping sound when first
It's hard to describe a sound in words, so I'm not sure I know what your "clipping sound" sounds like. You may be describing what's called "motorboating", which is a loud rapid putt-putting that drowns out the desired sound until it fades away. This is usually due to power supply problems, most often caused by bad filter capacitors. If I remember this model correctly, it doesn't have a built-in supply so you need to run it with an external adapter. That may be the source of your trouble. Try a different adapter or use battery power to see if the problem goes away.
If this problem only shows up when you're tuned to the station on 93.9, your radio may be picking up some kind of interference. It's also possible (but very unlikely) that the radio itself is producing a "birdie", which is a false signal on some frequency. If this is the case, it's a very obscure problem that may be very hard to find.
Sorry I can't be more precise, but maybe this will get you started. Thanks for using Fixya!
Mar 27, 2010 | Sony ICF-SW7600 AM/FM/SW Radio
Sony SW7600 -- static, scan tuning no longer functional
I can do the task, the parts are around 25 dollars for all, labor is what time I would have in it. Email me for more details...... poikaa@yahoo.com
Feb 09, 2010 | Sony ICF-SW7600 AM/FM/SW Radio
I have a Sony icf 2010. No sound, but white noise.
AA batteries need replacing or the contacts are corroded and one more, the PC board is connected to the AA negative post by a wire that touches the pad on the PC board. Sometimes it will lose contact because of oxidation or corrosion, to fix this a wire soldered is best but just repositioning the wire will make the cure. Requires removal of the circuit boards.
Jan 20, 2010 | Sony ICF-2010 AM/FM/SW Radio
I have a Sony ICF 2010 (for over 20 years) and when I turn it on, the only reception I get is on the FM frequencies (+ aircraft freqs). Thank you. Alex
Late answer on this.... There is a FET problem with older radios and this could be the problem. Static can "zap" the transistor making the radio deaf on receive in the AM modes.
Aug 24, 2009 | Sony ICF-2010 AM/FM/SW Radio
ICF 2010, no sound suddenly
If the radio does not work with headphone then the external jack for audio may have broken loose from it's soldered points. Simple re solder may make the repair. Beyond that it would have to be diagnosed by a technician.
May 28, 2009 | Sony ICF-2010 AM/FM/SW Radio
Sony ICF 2010 Shortwave scan does not scan, it beeps.
It will not scan blank memories and it will not scan on search function till you specify a frequency range.
Rod
Jan 30, 2009 | Sony ICF-2010 AM/FM/SW Radio
Sony ICF-SW11 AM/FM/SW Radio Logo
409 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
