Question about Bosch 24 in. SGS47E02 Exxcel Free-standing Dishwasher
Dishwasher does not start.
I have Bosch Logixx SGS6942 Free standing dishwasher.
The problem I am facing is that when I switch it on, the it pumps out the water but the pump continues to run even when there is no water left. It does not go on to the main program selected. I have checked the drain hose and the water pumps out without a problem.
How do I correct this problem?
  • stephenB1 Dec 11, 2007
    I have the Bosch SGS6952GB/14 which does the same thing but has no tray behind the kick plate
  • 213 Answers
Remove kick plate from below the door. youll see a white tray behind the kick plate there is water in the tray activating a over flow switch. using a towel remove the water. this will solve the problem
Posted on Nov 20, 2007
How can I do to remove the top cover (top) Bosch Logixx?
There are 2 screws on the back edge of machine at ether side.
remove this.
then push the top backwards.
may need a tap with you hand to get it to move.
Please dont forget to vote if you liked my answer
Feb 12, 2011 | Bosch 24 in. SGS45E02 / SGS45E08 Exxcel...
Water does not run into the machine
Check the strainer attached to the machine inlet. May be it is clogged. Try loading water 10 liters to the front chamber manually and run the m/c. If any air locking in the water pump this will ease out.
Apr 16, 2010 | Bosch 24 in. SGS09L12 Logixx Free-standing...
My Bosch logixx dishwasher is sticking on 1 minute at end of cycle; the dishes will be clean but still wet rather than dry.
100% add the jet dry until it is completetly filled then close the dispenser door and lower then raise the door.repeat this at least three times then check and fill if you can still add more. then after doing that b4 you start the machine run the hot water to get the right temp. when the water is hot enough then start the machine.
Mar 03, 2010 | Bosch 24 in. SGS09L12 Logixx Free-standing...
Srs55l22 is not filling with water?
check water going in the machine and check water valve with ohms meter. also if its partially filling it can be the circulation pump. check these things in that order.
Feb 28, 2010 | Bosch 18 in. SRS55L02 Logixx Slim-Line...
Bosch logixx dishwasher draining constantly even with door open
there is a leak . when the unit stays in drain mode that means there is water at the bottom of the base. The float switch stays in drain mode untill the water is removed. you must take off the side panel to remove the water,let me know what happens.:)
Nov 08, 2009 | Bosch 24 in. SGS47E02 Exxcel Free-standing...
Hot water fill
No you need to plumb into COLD only the unit has a built in heater if you plub it into hot you will ruin the sealve and the inlet valve will fail
May 11, 2008 | Bosch 18 in. SRS55L02 Logixx Slim-Line...
Wont drain!!!
Check first the drain lines and the drain pump.
If the drain pump is working, and there is no problem in there, then the problem is usually because the water level switch activated by the floating sensor is stuck.
You probably need to have the water level switch replaced.
You can find parts on websites below:
You can find replacement water level switch , and schematics on websites below:
BSH - Bosch Customer Service
Appliance411: Repair Parts
how to mend it .com - ~~ Wiring diagram for BOSCH Dishwasher.
Jan 06, 2008 | Bosch 18 in. SRS45E02 / SRS45E08 Exxcel...
Bosch 24 in. SGS47E02 Exxcel Free-standing Dishwasher Logo
455 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
