Question about Jenn-Air JES9860 Electric Kitchen Range
Front burner not working correctly - Jenn-Air JES9860 Electric Kitchen Range
  • 54 Answers
Have you tried to change the burner all together. If it is the one you pull out, just pull it out and go to a appliance store or home depo and get a replacement it should work fine after that. If the problem still exists you have a wiring problem to that burner. but I am sure it is just the burner if all your other burners work...
Posted on Jul 14, 2009
One burner won't spark when another is aflame. Multi-ignition BlueStar 4-burner range.
I would check that the plates are on correctly. Make sure they are aligned and sitting properly. Sometimes they move while cleaning and give you a bad ground connection for the spark.
Feb 15, 2016 | Kitchen Ranges
My kenmore flat top stove front burner quit working. I replaced the 9" element and it still will not work. Any suggestions.
your burner switch is wattage rated ( as all burners are ) you want to check H1 and H2 for voltage 220vac and replace it with the correct switch Rf,Rr Lf Lr some shafts on controls are colour codded
refer to your model number and proper switch and element location
Cheers
Dec 11, 2013 | Kitchen Ranges
Front burner does not light. Turning gas on and the gas does not seem to have a lot of pressure.
If the rest of the burners work correctly, then you have a clogged burner head. You can try to clear it out and if that doesn't work you will need to replace it. Here is the kit to order.
Oct 16, 2013 | Jenn-Air PRG3010 (NP) Gas Kitchen Range
JDS9860AAP Front e-burner does not light.
follow this instructions. God bless you
    • 1
      Unplug your unit and turn off the gas supply at the saddle valve near the unit.
    • 2
      Lift up the hood of the oven. If you have sealed burners, the lid will not lift up. Locate the ignitors near the burners of the unit. Clean any gunk away from the ignitor using a toothbrush. Test the unit.
    • Sponsored Links
    • 3
      Pull the burner dials off the front of the unit if the ignitors won't work.
    • 4
      Remove the screws at the ends of the front cover, where the gas supply knobs are located, using a screwdriver, and remove the cover from the oven.
    • 5
      Slide the wires off the burner valve switches and pull them off the burner valve by sliding the switch forward. The switch will have wires attached to it. Loosen the screws holding down the wires of the burner valve. Pull out the wires carefully. Place the wires in a new switch. Slide the new switch onto the burner valve. Replace the knob, and turn on the gas supply and power. Ignite the burner.
    • 6
      Follow the switch wires into the oven if the new switch doesn't work. Locate the module box, which is usually 2 inches by 3 inches. Slide the wires out of the module terminal by pulling on the wire connectors. Remove the screws from the old module and pull the module out. Insert the wires into the new module, using the same wire orientation as before. Reassemble the oven. Turn on the electricity and gas, and turn on the burner.
Read more: http://www.ehow.com/how_7925141_repair-electronic-ignition-gas-stove.html#ixzz2ZPuc5nad
Jul 18, 2013 | Kitchen Ranges
Burner will not get hot enough
When the burner arced out it probably also ruined the switch. Most switches on a standard electric range have 5 wires. 2 wires to the burner. 2 hot wires from power and a smaller wire which connects to the indicator light marked P. It is easy to test the switch Unplug the stove. Turn the suspect switch on wide open. Check for continuity between the 2 terminals going out to the burner marked H1 and H2
If you cannot get a reading then the switch has failed. Note: when replacing the switch usually on most stove the replacement will not be or look like the original HOWEVER it will still have L1 and L2 H1 and H2 and P but the terminals are not always in the same order. If you fail to correctly connect the new switch you will fry 2 switches when both get turned on. Ouch!
Aug 30, 2012 | Kitchen Ranges
I am renting a condo with an old Weber Grill - 2 burner / LP (I think it is a Genesis Silver A ('00-01) model . I have very little gas pressure at the burner tubes. - Front tube flickers on/off with...
Yes the best option for just for you is to buy a new burner,tube kit and a new manifold kit because all the things that you said you removed from the burner must have caused alot of rust on the burner and if you keep welding the burner there will still be linkage after awhile so the best thing is just for u replace the burner.
Jan 15, 2011 | Weber Genesis Silver A Grill
The front burner won't light.
I assume the other burners are lighting and the spark ignitor is working - if so try cleaning in and around the burner. a spill could have caused this problem. this should be a sealed burner model - if so make sure the burner top cap is on and seated correctly and or not gunked up with a spill. also check to make sure
May 25, 2010 | GE Profile Spectra JGBP90 Gas Kitchen...
2 of 4 burners ignite, all tick?
The two front burners are used most often. On the side of the burners are tiny holes that become plugged and keep the burner from lighting. If all the burners are the same size try swapping the heads around. If they are not all the same size be sure they are in the correct position and fully seated on the top. Sometimes the heads have to be replaced when cleaning no longer works.
Jun 08, 2009 | Kitchen Ranges
Need Manual For Electrolux Oven Model EOB 985GR
Having trouble locating the correct model number. Look at following areas for the model number
  • Under Right Front Burner
  • Under Left Top Burner Front Or Rear
  • Under Main Top Left, Rear Or Center Front
  • Under Left Rear Or Right Front Element
  • On Nameplate Inside Burner Box
  • On Front On Burner Box Bottom
  • On Nameplate On Oven Door Liner
  • On Main Front Behind Oven Or Compartment Door
  • On Front, Center Bottom Of Burner Box
  • On Thermostat Cover Under Main Top
  • Let me know, Sea Breeze
Mar 27, 2009 | Electrolux Ovens
Both 6'' & 9'' burners come on however I turn the 6/9 knob.
may be a problem with the switch itself, but honelstly dont take offense but make sure the knobs are on correct knob stem, it squite common for someone tho clean the knobs and not put them on correct valves
Nov 16, 2008 | GE Kitchen Ranges
Jenn-Air JES9860 Electric Kitchen Range Logo
137 people viewed this question
Top Jenn-Air Kitchen Ranges Experts
Mike Carew
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Jenn-Air Kitchen Range Expert? Answer questions, earn points and help others
