Question about Whirlpool WGD5900S Gas Dryer
Gas dryer not hot, do not stop running - Whirlpool WGD5900S Gas Dryer
  • Whirlpool Master
  • 1,606 Answers
Sounds like the thermal fuse (slim white piece located on the blower housing ) Pt# 3390719 , or , the ignitor Pt# 279311 is bad .Start with the thermal fuse first . Disconnect the power and put the 2 wires together (tape). Reconnect power and see if dryer heats .
Posted on Jul 19, 2009
Why have my dryer stop getting hot to dry clothes?
call an electrician to test the element or if gas call a gas fitter to check the gas operation
May 16, 2017 | Bosch Nexxt WTMC 3300 Electric Dryer
Dryer won't continue to heat and doesn't shut off.
The coils on the gas assembly get IFFY with age. They work a little then get hot and quit. My Video
Jul 08, 2012 | Dryers
SAMSUNG GAS DRYER DV 328 RUNS FOR A WHILE AND THEN STOPS . I GET ERROR CODE EO. THE CLOTHES IN THE DRYER ARE VERY HOT. AFTER A PERIOD OF TIME THE DRYER COOLS DOWN AND STARTS TO WORK AGAIN. THE DRYER...
The cycling or operating thermostatis often the problem when a dryer runstoo hot, but there are also other things that can make it run hot also.
Here is a tip that I wrote that gives more details about why a clothes dryer will get too hot.
Clothes Dryergetting too hot
heatman101
Aug 14, 2011 | Dryers
My gas dryer all of a sudden just stopped getting hot. it runs but just does not get hot.
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Sep 02, 2010 | Whirlpool WGD5600S Dryer
Cold dryer
if the dryer runs normal for the first 15 to 30 minutes you have bad gas coils located on the top of the gas valve,take out the 2 phillips screws,remove the top cover and change out the gas coils.when the coils are failing they will work until they heat up then they stop letting the gas come into the dryer,when they cool down then they will work again.change out the gas coils part number 279834
Mar 27, 2010 | Kenmore 73952 Gas Dryer
Gas dryer no longer gets hot
check the spark ignitor out for that lights up the burner to heat
Mar 11, 2010 | Dryers
Kenmore gas dryer doesn't stay on
I think it is probally the thermocouple not holding letting gas valve work properly, timers do not go out very often, its not getting hot enough to release the gas, valve wont let it, chheck thermocouple, let me know im not there, but its in the heat not getting hot enough
Feb 25, 2010 | Kenmore Dryers
Gas dryer - bruner will not come on
Probably a broken belt or a bad start winding. Remove the rear panel and check the fuse mounted on the blower housing. If open replace it and clear the vent to the outside. Click here for fuse locations and pictures.
Jun 01, 2009 | Kenmore 73952 Gas Dryer
My dryer will not get hot
My gas dryer will not heat, what could stop my dryer from heating?
A - Things that could stop a gas dryer from heating:
- glow bar igniter, thermal fuse ( not all models ), coils on the gas valve, gas valve, thermostats,motor heat switch, timer, selector switch, sensor.
A page for checking gas dryers is here.
Dec 15, 2008 | GE 5.8 Cu. Ft. Extra-Large Capacity Gas...
Not staying hot-Kemore 80 Series gas
suspect coils bad on burner valve after heating up first time will sometimes fail on following fire ups
Nov 19, 2008 | Kenmore 63942 Dryer
Whirlpool WGD5900S Gas Dryer Logo
112 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
