Question about Canon PowerShot SD1100 IS Digital Camera
Lens blocked? Canon PowerShot SD1100 IS, recently water damaged
I dropped my camera in water about a month ago. It's mostly working fine now, except the screen is black in shooting mode. It's the kind of image you'd get if you completely covered the lens - grainy, not solid. If I take a picture, it just takes a picture of the blackness. Pressing Display doesn't solve this. Help?
  • Canon Master
  • 4,738 Answers
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open).
To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see the following for further info and a simple fix that may help:
http://camerarepair.blogspot.com/2009/05/simple-fix-for-stuck-shutter.html
Posted on Jul 14, 2009
Lens barrel is stuck in the out position on my Canon Powershot SD1100 IS. Error message reads: "Lens error, restart camera". To my knowledge the camera has not been dropped and the barrel seems...
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ... Here are some troubleshooting steps that you can try that may (or may not) correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty (or repair cost approaches that of the camera), they're worth that try. Some of the later steps do involve some risk to the camera, so carefully weigh your options before deciding to conduct them:
Jul 20, 2011 | Canon PowerShot SD1100 IS Digital Camera
It was dropped in ocean more than a week ago . Now not turning on. What can be done to fix it?
Even if you dried it properly (burying it in a bowl of dry rice for a week before even trying to turn it on), salt water is very corrosive and continues to do damage for weeks and months. It also dries to a salty film on the lens elements. Dropping a camera into salt water is usually a death sentence for a camera. Even if you could find someone willing to repair it, the cost would be astronomical since everything except the case would have to be replaced.
Dec 18, 2010 | Canon PowerShot A560 Digital Camera
Cannon powershot SD1100 IS it displays the
Here are some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, or if repair costs close to the value of the camera, they're worth a try.
Nov 24, 2009 | Canon PowerShot S410 / IXUS 430 Digital...
My canon SD1100 Is digital camera lens came open in my pocket and now wont open or close. How can I repair this?
Here are some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try.
Oct 22, 2009 | Canon PowerShot SD1100 IS Digital Camera
Lens error canon powershot sd1100 is
Apparently, you missed some sand and it just took a while to work its evil way into the works of your camera.
Aug 11, 2009 | Canon PowerShot SD1100 IS Digital Camera
Canon SD100 Lens Error (camera)
First try calling 1-800-OK-CANON to see if warranty repair applies. If not...
Here's some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Jul 12, 2009 | Canon PowerShot SD1100 IS Digital Camera
Lens error, restart camera message
This is probably THE single most common failure among digital cameras. There's a halfway chance of fixing it yourself, described here: http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
May 21, 2009 | Canon PowerShot SD1100 IS Digital Camera
Lens error restart camera
same thing just happened to me today. the little girl that I babysit dropped it about 1 foot to the rug on the ground, not a hard drop at all. so i tried taking out the batteries and hit it on the table (read on other sites) then i gently turned the end of the lens (my lens was stuck out) counter clock wise and it clicked and then worked.
Apr 20, 2009 | Canon PowerShot SD1100 IS Digital Camera
Dropped my camera in a pool of water in a glacier 12 months ago. I immediately took out the battery and memory card. I then spent 2 hours with a hair dryer drying the camera. Since then the camera has...
There is no relation between the two incidents that you explained. The recent problem might have occurred due to damaging of the lens. MY solution is to replace the objective lens ( lens assembly) and the motor ( if needed ). If it costs much, then go for a new one, since digital camera with high pixels rates are available cheaply now a days.
Mar 30, 2009 | Canon PowerShot S500 IXUS 500 Digital...
My lens won't come out.
It sound like the lens mechanism was damaged during camera's drop. Only way (to my regret)is to sent it to be repaired in a professional lab.
Dec 03, 2006 | Canon PowerShot S2 IS Digital Camera
Canon PowerShot SD1100 IS Digital Camera Logo
782 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
