Question about AOpen AX4SPE Max (91.8AT10.501) Motherboard
Problems using usb ports
I have recently started having problems with my usb ports. First I tried to install a new multi-function Epson printer. The scanner part installed ok but the printer didn't seem to install. I had a lengthy discussion with the Epson help desk where we tried uninstalling the printer drivers and removing the usb ports via device manager. No luck. They recommended contacting the manufacturer.
Since then I've bought a Freecom mobile drive which works fine on several pc's but not the problem one. It just makes a funny clicking sound when you plug it in.
I also had problems with another external hard drive which is connected to the firewire port. This was not being recognised at all, although it seems to be working all right at the moment.
I've tried restoring a known good backup of the operating system but this hasn't fixed the problem. Could this be a hardware problem? Is there anyway to diagnose it? Do I need to replace the motherboard?
Any help would be appreciated.
Thank you
  • lance1 Nov 18, 2007
    Thanks for the reply. Yes, these are the built in ports. When you say install another usb port via a dongle is that like adding a pci card with usb ports?
  • 298 Answers
I assume these are the built in ports you are
having trouble with.Do you have a terminal to
install another usb port via a dongle It may be
that the inner terminals of the usb receptacle
are not making good contact (defective) If you
have a junk board with same setup you
might be able to desolder the port,and
replace yours. I haven't had the occassion to
try this yet, but it might work
Posted on Nov 16, 2007
  • Eugene Merritt Nov 19, 2007
    PCI card should work okay
    may have to disable onboard usb
    card instructions should explain if
    not get back with me
    The dongle is like a port cover with 2 usb
    ports built in with 1 or 2 set of wires with
    a plug or 2 on the other end that connect
    to the motherboard via a set of terminals
    simllar to a com port,but you cant guess
    at it the plug and terminals must match
    Mothboard manual would give that information
Epson TM-T90 wont work with USB plug
I have the same problem...Epson does not work with a parallel to usb cable or adapter. If you still want to use this printer you will have to use the parallel port or change the interface on the printer to USB.
Nov 21, 2009 | Epson TM T90 Printer
I have recently purchased an Epson SX415 and when installing the printer using the cd it fails at the communication point. I am running XP and I have downloaded drivers from the Epson site and the printer...
It could be you usb port acting up. You may need to gointo device mode and remove you usb ports Then restart the computer so it can reinstall them. Did you old printer work with the desktop?
Oct 09, 2009 | Epson Printer
My pc won't detect my printer, my printer is brother dcp 150-c
have you connected the printer's USB port to your CPU? If not, then do so. If after doing it, still your PC don't detect your printer, make sure you have a functional USB port. To check it, try using a USB Flash drive if it works with your PC. If it won't, you might have to "Enable" your USB at your BIOS.
Jul 09, 2009 | Office Equipment & Supplies
Computer no longer recognizes my scanner
If you are using a multi port USB adapter that allows you to plug many devices into one USB port it may interfere with the scanner. Try uninstalling your Epson driver then download the newest one from the Epson website.
Install the newest driver first then plug your scanner into a single USB port on the computer instead of the multi port.
Mar 31, 2009 | Epson Perfection V500 Flatbed Scanner
USB plug in Epson Printer RX595
assuming you properly installed the "printer driver".
disconnect the printer.
check Printer & Faxes for printer icon(s) - delete print queue(s) and the printer icon(s).
open device manager and go to Universal Serial Bus Controllers section.
now we check for connectivity: (treat the printer and scanner as separate devices)
connect the printer, USB Printing support must show up (also check Imaging Devices and the scanner must also show up)
IF USB Printing support shows, windows will create a printer icon in the Printers & Faxes, right click choose properties and print a test page.
ELSE, it's the printer and request for a replacement if it is still within 1 year from the date of purchase
Jun 14, 2008 | Epson RX595 Photo All-In-One Printer
Epson Printer problems
well i'm not sure waht is your issue,
but you can try to check this out
If you are using win 2000/xp/
and usb cable connection/interface
after you installed the drivers from the cd software or from epson website
click on start>> control panel>> printers and faxes>> right click on the printer icon(epson stylus?)>> properties>> ports>> select usb001 virtual printer port for usb...
well... sory if i misunderstand you
good luck!!!
Apr 03, 2008 | Epson Stylus Photo RX600 All-In-One InkJet...
Epson 1800 error message -9672
try using only one type of connection (USB or FireWire) see if that helps.
no known conflict for DivX for the printer, not sure for the mac though
Jan 26, 2008 | Epson Stylus Photo R1800 InkJet Printer
How to install my multi function center
That means that windows doenst recognize that you have your usb connected...try a port that is in the back instead of the front...also plug your device before you run the program..
Jan 05, 2008 | Brother Multi-Function Center MFC-240C...
Inkjep printer
Unplug the printer. After uninstalling the software make sure you delete the printer from Printers and Faxes! Try plugging it up again(don't install back the software just as yet), the New device found pop up should come up! if it doesn't then it could be the USB cable / the USB ports on the PC or the USB interface on the card! If it does , put the cd in the drive and select Install Drivers automatically(if its pops up) Also, Try using different USB ports if the new device pop up doesn't pop up! Test the USB ports by using a regular USB device in the same port you are plugging the printer into! A bad USB cable could be the issue but it can also be something else! You'll need to verify that its the cable, what you can do is try it with a cable that you know is fully functional! If you still don't get a response from the printer and everything else works(i.e. usb cable, usb ports) then it could be the USB interface on the printer! and you'll need to take it to a tech! Hope this helps!! regards, babb
May 04, 2007 | Epson Stylus Photo 1280 InkJet Printer
AOpen AX4SPE Max (91.8AT10.501) Motherboard Logo
137 people viewed this question
Top AOpen Computers & Internet Experts
Michael Galve
Michael Galve
Alun Cox
Are you an AOpen Computer and Internet Expert? Answer questions, earn points and help others
