Question about BMW Car Audio & Video
I own a 2004 525i and I get this intermittent loud static in the radio which blocks out the music and sometimes the radio just dies completely for several seconds and then it comes back on. This might last for several seconds to a minute, then it is totally fine. Sometimes a few days go by and there is no problem at all and then it starts up again, and once it starts, it continues. If I turn the radio off during the the times when the radio cuts out or the loud static takes charge, the radio will not turn on again until the static clears. Any help with this would be appreciated.
  • 1 more comment
  • mflyer Jul 14, 2009
    The exact same thing happens when I am using the CD player . I don't have tinted windows and I really don't think it is the antenna. Someone mentioned a bad processer, since the radio is not a separate unit, it is connected to other functions in the panel.
    I DO NOT have tinted windows and the same thing happens when operating the CD. One radio shop I went to said I have a bad processor since the radio is not a SEPARATE unit. It operates with other functions in the panel. He also said it is NOT the antenna. I just needed another opinion.
    So you don't think it is a faulty processor? This is what a radio repair shop told me and of course they can't fix that problem -- it is a dealer fix and he said it was very expensive. I do not have bluetooth or BMW Assist. Could you please tell me where the TCU is located in the trunk so that I can remove it?
  • 3,037 Answers
Are your windows Tinted especially the back one? The antenna is in the window ant the tinting will cause the static, BMWs are very famous for having this problem. There are aftermarket window mount antennas and FM boosters you may want to try to help reduce it. Go to an audio shop or search online for one.
One part that confuses me in your statement is when you turn it off, it won't turn back on, Do you mean the cd player won't even work during this time or just the AM and FM bands as the cd player should work?
Benjamin
Posted on Jul 13, 2009
  • Benjamin Patri
    Benjamin Patri Jul 14, 2009
    Alright since the Cd player does the same thing. Then the problem is in the TCU (Telephone Control Unit ). A TCU replacement costs a ton which is why I didn't suggest it at first.
    Here is the solution. Go into the trunk
    and remove the TCU. It is not required for any of the car functions
    except for bluetooth and BMW Assist (which only matters if you actually
    pay the subscription fee for that). Once you remove the TCU, the
    radio/CD static problem should be fixed, and the only difference now is that
    when you go into the "Communications" menu, instead of saying "No
    Signal", it should say "No Cell Phone Installed". Let me know if this fixes the radio problem
  • Benjamin Patri
    Well if you don't have bluetooth, then you won't have the TCU and so the processor is probably the next option in being a problem especially if a shop diagnosed it as being bad. These radios are very expensive to fix, so you may be better off getting a new aftermarket one instead of fixing this one then since you don't have any of the fancy extras with yours.
Loud static burst at random times
Bose is proprietary. It could be electronic parts that are called capacitors.
Dec 09, 2013 | Bose & Wave& Music System
Alot of static or interference through speakers
Check all leads are plugged in the right spots and are in good condition. Sometimes "static" is caused by plugs not connecting properly.
Nov 29, 2013 | Altec Lansing Audio Players & Recorders
How do i stop the intermittent static?!
Static can be caused by a poorly charged or bad battery. Try cleaning your battery contacts with a pencil eraser, on the battery, radio, and charger. Then recharge the batteries and see if the problem still exists. If so, try a battery from a known good unit and see if it stops the static.
If the battery is not the issue, you could simply have environmental noise. RF (radio frequency wave) in the environment is a common problem in urban areas. If you are using the radios in or around computers and other electronic devices, coil the cords to these devices and make them tidy. RF noise can be emitted through the cord like it is an antenna of sorts. Coiling will reduce this effect.
If your radios have PL capability, aka private line code, interference eliminator, turn it on, or change the setting. This should block out unwanted noise and interference.
Best regards.
Jul 18, 2012 | Uniden Gmr3040-2Ckhs 30-Mile Range 2-Way...
On my 2003 Avalanche, after the radio has been on for a few minutes static starts in the front right speaker then travels to all of them. As the static gets louder the radio volume goes down and the static...
take out the speaker in question and test it.
a 9v battery is good enough to 'burp' it.
if it makes a scratchy noise when you put power to it then you have a short in the voice coil.
Burping a speaker is just a short power up. Don't hold power to it.
Tap it on and off like a music note measure.
Apr 16, 2017 | 2003 Chevrolet Avalanche
Static problem
You can try a laser cleaning kit to see if that will help, generally when the laser gets to that point it is time to replace the laser pickup assembly or just replace the whole unit due to cost over runs in repair.
Apr 05, 2012 | Sony CDP-CE375 5-Disc CD Changer
My 2005 Accord's radio / CD player will not produce sound to the speakers, the display panel works fine. Sometimes a loud static sound will come from the speakers with no volume control, powering off gets...
The sound chip may have gone in the stereo, especially if someone has had it on very loud they sometimes blow, otherwise you have 2 speaker wires touching each other, that way you only get static noise, insidee the door they sometimes come free and touch the body
Check all your speaker wires first.
Jan 17, 2010 | 2005 Honda Accord
08 nissan frontier problems
No you need a new battery or alt. or both running a stereo will kill both faster. and could carosion faster too.
Jun 29, 2009 | 2008 Nissan Frontier
Radio Dies with Noise
sell it now! Ebay would be a good place
Jan 30, 2009 | Tivoli Model Three Clock Radio
Distorted sound
I have had this problem also. While I haven't completely fixed it I have figured out the root of the issue. Within this unit there are two circuit boards. Between the two boards is a white connection. It appears this connection becomes loose or is susceptable to the heat that is generated from the unit. I've tried teasing out the pins within the connection to see if they can get a better fit together. This will work for a little while but then the static returns. I'll post back if I come up with a final solution to this problem.
Apr 24, 2008 | Sirius Starmate ST2 Satellite Radio...
BC350A loud static
It may be that someone you are monitoring is now using digital or at least parttime.
when they go digital, you may only hear static.
hope this helps.
UPSO506
Dec 29, 2007 | Radio Communications
Car Audio & Video Logo
79 people viewed this question
Top BMW Car Audio & Video Experts
xxxxxx xxx
Joseph Hoffmann
Are you a BMW Car Audio and Video Expert? Answer questions, earn points and help others
