Question about Troy Bilt Tb70ss Gas Trimmer
How do I properly install new line on the tb25sc
  • 162 Answers
If you have the serial number you can get the manual from www.troybilt.com
Posted on Jul 28, 2009
Installing stainless steel braided brake lines?
Just make sure they are secured properly because they will move when pressure is applied. Make sure they are bled properly also because they may have a bigger inside diameter. Securing the braided lines is critical due to the movement.
Nov 22, 2015 | Buick Cars & Trucks
How do i install my power steering return line
With the engine cold, loosen the steering reservoir filler cap to allow air into tank. Take the lowest fitting loose and let it drain into a bucket under the vehicle. When finished draining remove Line fitting at reservoir. Remove any brackets holding the line in place and remove line from vehicle. Take the line to automotive supply and buy proper replacement using old line to verify fit. Purchase enough recommended power steering fluid to replace what drained into bucket. Install new line in reverse of removal steps making sure seals (washers and/or "O" rings) are properly installed. Dispose of old fluid safely.
To fill reservoir and line: While filling reservoir with engine running turn steering wheel from left to right until wheel stops. Continue filling and turning until all air is out of system and reservoir is at the proper fill level. Check for leaks.
Mar 23, 2015 | 1988 Cadillac Eldorado
97 chevy pick up has no brakes after changing all lines booster master cylinder calipers and wheel cylinders and it has straight fluid after
Did you properly purge the master cylinder before installing? A new master cylinder needs to be properly prepared. Any chance you have a bad vacuum line?
Jan 26, 2015 | Car Audio & Video
Installed new front brake lines, now after trying to bleed them it supposdly will not let the fluid to bypass the abs. system. ?
Before bleeding brakes make sure you disable abs system. I usually remove the abs fuse for that time. With abs on you cannot bleed brakes properly. If still having problems then check new brake lines for glitches that might have happened during the install.
PS: Don't forget to put back the abs fuse after you are done! Otherwise you still have brakes but not with abs feature.
Dec 04, 2013 | Cars & Trucks
Intermittent vertical black lines samsung hlp5067w
even technicians who are familiar with those units, before installing new lamps, they use a 'calibration unit' for that or any particular model lamp and calibrate them right after installation. If you don't have the proper calibrator and adjust them right after you installed them, you will get that result. Even experience techs come across that problem if the calibration is not done properly. Also, each lamp for a different color value, has its own calibration/sync values.
Nov 18, 2013 | Televison & Video
How to change fuel filter mazada 2003 tribute
Mazda Tribute 2001-06
Fuel Filter - Removal & Installation
  1. Before servicing the vehicle, refer to the Precautions section.
  2. Properly relieve the fuel system pressure.
  3. Remove or disconnect the following:
    Negative battery cable Fuel line to the fuel filter
  4. Loosen the clamp and remove the filter
To install:
  1. Install or connect the following:
    New clips to the fuel lines Fuel filter and tighten the clamp Fuel lines to the fuel filter Negative battery cable
  2. Start the vehicle and check for leaks, repair if necessary.
  1. Before servicing the vehicle, refer to the Precautions Section.
  3. Disconnect the negative battery cable.
    NOTE To deplete the backup power supply energy, disconnect the negative battery cable and wait at least one minute. Be sure to disconnect auxiliary batteries and power supplies, if equipped.
  4. Disconnect the fuel line at the fuel filter.
  5. Loosen the clamp and remove the filter.
To install:
  2. Start the engine and check for leaks, repair if necessary.
Hope this help; TY for using Fixya (remember comment and rated this).
Apr 01, 2010 | 2003 Mazda Tribute
How to install brake lines
In many cases this is a straightforward procedure. You just install the new ones where the old ones were that you took out.
Now in actual practice this can become a freaking nightmare when rusted bolts will not come apart without breaking.
Hopefully your new lines are already bent to the correct shape. If they aren't then you need a special tool to bend them properly. Without the bends made properly you could accidently pinch off the flow causing a very dangerous condition.
Mar 27, 2010 | 1998 GMC Safari
Fuel lines rotted and broke. Installed new lines but unsure of proper connections.
Use the primer bulb & determine which nipple has pressure when pushed, that is the return (short line) the other is the pickup line with the fuel filter on it
Jul 18, 2009 | Ryobi Garden
1993 how do you properly bleed a new master cylinder
First You Bench Bleed The Master Cylinder Before Installation. Use The Provided Plugs Given With The New Master. Use Screw Driver And In And Out Motion You Bleed Until No Bubbles. Then After Installation, Crack Line And Have Buddy Slowly Push Down On Pedal. Close Line. Repeat To Other Line. You're Done
May 02, 2009 | 1990 Pontiac Trans Sport
Ryobi line cutter - petrol lines all broken
Petrol lines disintegrate when fuel is stored in the trimmer for long periods of time. These can be obtained from any small tool repair store. Just remove them and install new ones. They just slip through the holes in the tank, re-attach the fuel filter on the supply line. Make sure that the line is long enough so that the filter rests on the back/bottom corner of the tank. Be sure that the lines are attached to the proper ports on the carb>
Dec 22, 2008 | Ryobi 15" Electric Factory Reconditioned...
Troy Bilt Tb70ss Gas Trimmer Logo
219 people viewed this question
Top Troy Garden Experts
Matt Olenzek
Matt Olenzek
DROPNDEAL
DROPNDEAL
Wade Mobley
Wade Mobley
Are you a Troy Garden Expert? Answer questions, earn points and help others
