Question about Acer Aspire 3000 Notebook
I installed a windows vista and now cannot connect to eithe cable modem
  • Fabricio Holguin May 11, 2010
    Have you install all the drivers for that particular pc or laptop?
  • 585 Answers
You will need to visit the manufacturer's website and hope to find Vista drivers for your unit You will need ALL available Vista drivers starting with the chipset drivers in order to make all of this work properly. Find and download the chipset drivers first, then the network adaptor. Copy the drivers to a USB drive to transfer them to your computer. It gets easier once the network adaptor is up and you can get on line to do the rest. If you can't find drivers for Vista on the manufacturer's website, you may just be stuck with the previous software version you had.
Posted on Jul 13, 2009
How to install huawei ETS1001 (FWT) modem driver for windows 7 OS
Windows 7 should manually install the drivers for the modem. However, modems usually don't require drivers unless they're being plugged in with a usb cable. If possible, I would use the ethernet connection as it's much faster than the usb connection. If that's not possible, search on the manufacturer's website to find the driver you require. I did some searching myself and couldn't find anything specifically relating to Windows 7, but usually a Windows Vista driver will work.
Mar 05, 2011 | Computers & Internet
I have hughes net with an HN9000 modem installed and I'm trying to use it with a D-Link DI-524 wireless router. When everything is connected, I can connect to the router, but Local Only. When I click...
Make sure you use the correct cable between the router and the D-Link. If you use the blue wire it won't work. The orange and orange white pair have to be swapped with the green- green/white pair on one end of the cable only. Usually, the cable is orange in color and is called a crossover cable.
Apr 16, 2017 | D-Link Xtreme N DIR-655 Wireless Router
Error 638 while connecting through modem on
Sir, error description is of "The request has timed out".
First, Try once by restarting the system
http://www.modemsite.com/56k/duns6xx.asp
Second, You can try diagnosing the modem if the diagnosis results some text. Then modem should be working. Else, check for proper cabling.
To diagnose modem
1.Click “Start” then “Settings > Control Panel” or “Control Panel”.
2.In Control Panel select the “Phone and Modem Options” icon.
3.Select the “Modems” tab in the top middle, of the new window that opens..
4.Then on the next screen select the “Properties” button in the lower right.
5.You should now select the “Diagnostic” tab in the top of the new window..
6.Then click on the “Query Modem” button in the middle of the window
Lastly, try unstalling an installing & reinstalling the modem driver
Hope this helps
May 19, 2010 | Microsoft Windows Vista Home Premium...
Just installed win 7 and can't get internet on
Can't connect to the Internet using Windows 7 OS.
1. If you haven't already done so, run the Network troubleshooter to see if it can help diagnose and solve your problem.
Open the Network troubleshooter by right-clicking the network icon in the notification area, and then clicking Troubleshoot problems.
2. Make sure that all cables are connected (for example, make sure your modem is connected to a working phone jack or cable connection, either directly or through a router).
3. Restart your modem, and then restart your router. Remove the power cable from the modem and router. After all lights on the device have gone out, wait at least 10 seconds, and then plug the modem and router back in. Some modems have a battery backup that prevents the lights from going out. For this type of modem, press and quickly release the Reset button.
4. Check your router. Because of the new networking features in Windows Vista andWindows 7, some older network routers are not fully compatible with these versions of Windows and can cause problems. You can test your router to see whether it is fully compatible with Windows 7 by running the Internet Connectivity Evaluation Tool. Or, for a list of routers that are compatible with Windows Vista, go to the WindowsCompatibility Center website.
May 03, 2010 | Computers & Internet
How to connect usb conection from my data one "UT-300R2U" modem to compaq laptop.we have usb cable and driver cd but drivers are not installed in my laptop.plz give me the complete solution for this...
If you are using Windows Xp, just connect the modem using USB/LAN it will be automatically detected & software for it will be installed. Then you can just set up a connection, put in your username & password, done.
If you are using Windows Vista / Windows 7, modem in LAN mode will be installed automatically like XP, but not in USB mode. Because there's no USB driver for UT300R2U (BSNL modem) in Vista. You need to find a ZTE Remote NDIS device driver, install it & then you can connect. Hope this will fix your problem.
May 12, 2009 | Computers & Internet
I can't install modem drivers for SB 5100 motorola (usb) on my laptop having windows vista. An error is showing that no cable found connecting the modem and computer. Can someone help me how to set this...
Here are the current windows Vista drivers from motorola:
http://broadband.motorola.com/consumers/products/SB5100/downloads/542708-001-install-utility-b.exe
Hope this helps you on your journey
Let me know if you have anything else.
I also would recommend you use ethernet since you do not have to install any software to make it work.
You will need to reboot the cable modem when ever you change how its connected also Ethernet/USB or if it was connected to a different PC.
Please Rate
Jan 20, 2009 | Arris SB5100 SURFboard DOCSIS 2.0 Cable...
My modem does not install in window vista
hi, This is rohit from Primus Tech Support, Canada
As i understand correctly, you canot make the modem work with windows vista, right?
Make sure that the OS Window Vista has not encountered any problems while installation process.
Try to create a conectoid
click start>control panel>internet connection>network and sharing center>setup a new connection or network>connect to the internt>broadband PPPoE> Enter you User ID and the Password (contact your ISP) confirm the password and click connect.
You should be conected.
Make sure the ADSL LINK or DSL light on the modem is solid before you create the connectoid.
Regards,
Rohit Singh
Sep 22, 2008 | D-Link DFM 562E (dfm-562e) Modem
Connecting modem via ethernet cable
I'm not an expert in window based units but since it worked with Vista OS and not with XP. Sounds like you might try re-installing XP again. Take note on any windows that refer to the ethernet port during installation. It is likely you might of hit "next" without reading all the text. I know I have in the past. I changed over to mac and I know longer have any problems only at work but give then I give it to the IT Dept and wait and wait and wait.
Sep 05, 2008 | Westell Wirespeed LiteLine 6100...
Tusb3410 vista
Sir , I am having Huawei Wireless Modem.(TUSB3410).For Internet connection(dail up). I am having windows xp I cant install the modem with this vista. .Please solve my problem...
Aug 21, 2008 | Computers & Internet
ADSL Modem Huawei SmartAX MT841 USB driver not supporting Window Vista Name update of Vista
Hi!
Do not use the usb port or cable. use the RJ 45 port instead. and configure PPPoE and connect using UTP / STP cable with RJ 45 connector straight crimped.
Jul 27, 2008 | Computers & Internet
Acer Aspire 3000 Notebook Logo
41 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
