Question about Dometic Rooftop RV Air Conditioner
Circuit breaker overheating on rooftop ac after
20 amp circuit breaker overheating on rooftop ac after it was recharged 2 days ago. The breaker trips hourly now. Any suggestions?
Replaced the breaker with a new one sam rating still blows after an hour or so. Temp outside 98 F any ideas. after sundown breaker works fine and so does air conditioner
Posted on Jun 28, 2010
  • 614 Answers
Possible overcharge or bad breaker. You need to check the amp draw for the unit. If you draw under full load amps and trips breaker breaker is bad.Rus
Posted on Jul 13, 2009
Keep tripping breakers can i just remove the 15 amp breaker and replace it with a 20 amp ??
I would not go to larger breaker size until I knew why 15 amp breaker is trippingIf you find out that 15 amp breaker is tripping because it is being overloaded or that breaker is getting weak. Then I would replace breaker with the same size because they may have wired some with 14-2 wire instead 12-2, I would not feel comfortable pulling 20 amps, on 14-2 wire. That is my suggestion for what it's worth. Thank you.
Nov 20, 2010 | Sea and Sea Blue Sea 7327 Circuit Breaker...
Compressor runs for only a moment the circuit breaker trips
Lights dim, moaning from AC, just before it trips breaker? Have you checked incoming voltage? What type of plug are you hooked up to, 30, or 50 amp?
Aug 30, 2010 | Dometic Rooftop RV Air Conditioner
AC runs for 5 minutes and then circuit breaker
What else do you have running on hydro while AC is running? Such as coffee maker, microwave, water heater, fridge. That 30 amp breaker is your main breaker I assume, or breaker on pole your plugged in to. Keep in mind your AC will normally draw approx. 15-17+ amps momentarily when compressor kicks in to cool, then drop back to 12-15 amps when running normal. If your AC is drawing too much current, then you would only normally trip 20 amp breaker for AC in your panel. Try switching other appliances to gas operation while running AC, such as water heater, and fridge. Make sure incoming voltage is up to specs as well . (115-120 volts)
If water heater takes 5-8 amps, and fridge takes same when they are calling for power, you'll be close or over the 20amp mark when you consider your on board converter etc. as well. That only leaves approx 10 amps for AC that requires approx 15 amps to run, and up to 20amps when compressor kicks in. If you switch all those other items over to propane, and it still happens, then a current draw test should be done on AC unit to see if perhaps a capacitor is faulty, or possible compressor faulty.
Jul 22, 2010 | Dometic Rooftop RV Air Conditioner
My unit was working fine until 3 days ago when the breaker tripped, I reset the breaker and worked fine for a day then tripped again when it tripped both the ac breaker andthe main in the trailer as well...
High amp draw can be caused by a few different things, so first check that incoming voltage to trailer is sufficient. (115 volts) Not unusual for some parks to install more hydro hook-ups on a feed line, and when all are up and running, your incoming voltage could be decreased. If your o.k. that way, then I'd start looking at the compressor circuit of your ac, in particular, the compressor start-up capacitor. The capacitor basically stores electricity and boosts it to higher voltage for compressor and fan start-ups to reduce current draw that will trip the breaker. Please have a knowledgeable electrician, or RV tech check this for you, as a capacitor can give a real good high voltage (possible fatal) shock, even when power is off to unit. I also suspect that the start relay has shorted (welded) itself due to high amp draw situation, and that is reason it comes on by itself.
Jun 21, 2010 | Dometic Rooftop RV Air Conditioner
Hitachi RAS09UH randomly pops 15A circuit breaker
Two things that you could check: 1) If you have access to an ampmeter, determine if the unit is drawing over over 14 or 15 amps, 2) replace the suspect circuit breaker in case it is beginning to go bad. Breakers only trip for overcurrent conditions or failure of the breaker itself. If it is pulling close to 15 amps, then it could heat up over time and trip.
Jul 09, 2009 | Hitachi RAS-09UH Air Conditioner
Ac Problems
You must have too many things running on that circuit. Check your connection to the power box.Loose connection on the receptacle can cause the breaker to trip or too many things running on the same circuit. If the breaker is old it might need to be replaced.
May 10, 2009 | Dometic Rooftop RV Air Conditioner
Tripping circuit breaker
You probably have a dirty condenser coil or the con den ser fan motor is bad or the blades are jam that's why it overheat and shut off by overload.
Apr 20, 2009 | Dometic Rooftop RV Air Conditioner
Refrigerator cools as normal. Trips 15 AMP circuit breaker.
a full size refrige has to be on a 20 amp circuit, a 15 amp is just not big enough.. you should also know that this circuit has to be on a 12-2 gauge wire.. I also highly recommend installing a 20 amp HD receptacle
Mar 19, 2009 | Refrigerators
Dometic ac/heat pump
Would suggest it is drawing excessive current, make sure both fans are going, (inside will cycle low/high), or possible faulty reversing valve solenoid, or could be as simple as loose wire connection, how long does it run for and is it on the same 20amp breaker as the rear?if so start by running only the front unit in cooling 15/20min, check fans running, no unusual bearing noises, switch off for 60 sec then back on heat mode, if unit runs without stopping rewire onto separate circuit, if inside fan not working on heat check bi-metal switch in the airway, if running for a while, fans going but not very warm, check reversing valve.
Note, electrical's should be tested by someone who are qualified in the field.
Nov 05, 2008 | Dometic Rooftop RV Air Conditioner
Dometic Rooftop RV Air Conditioner Logo
590 people viewed this question
Top Dometic Heating & Cooling Experts
Bill Long
Tim Whalen
Dan Webster
Dan Webster
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
