Question about Homelite Mighty Lite Lawn Trimmer
ATTACEMENTS DO NOT WORK ON MY TB20BC
Had unit for about two tears worked fine now none of the attachments work. Head spin from motor but it moves back and forth. Think it is disengaging. Repair or buy a ryob last one lasted 12 years sr#1k137dc0422
Agitator won't spin and water won't drain during spin cycle
Hi
Try these things first.
1) Verify a circuit breaker isn't tripped
2) Advance the timer control dial slowly 360 degrees-
If the washer starts spinning, then we know the motor and drive belt are fine but that there is something wrong with either the timer control dial or the agitator solenoid. Call in a professional for this.
If the washer doesn't budge, then verify that the drive belt(s) is attached and not broken by removing the back panel. If the belt is broken, replace it. If it is loose, then tighten it by loosening up the bolt holding the motor and moving it on its swingarm (much like a car alternator) until there is a 1/2 to 3/4 inch deflection in the belt. Some washers use reversing motors. It's possible the motor works on the spin cycle but not on the wash cycle. If so, call a pro.
3) Visually inspect the lid safety switch- Is it loose or cracked? If so, the washer might work intermittently, stopping at different cycles.
4) Check motor and drive belt- Remove the main access panel (usually in the back). Is the motor spinning, but the drive belt isn't? If so, then you have a drive belt problem. Go here. If the motor isn't spinning, then go here for washer motor troubleshooting.
If none of these tips resolve the problem, then there's probably a more serious problem with either the motor, the transmission or the agitator itself. If this is is the case, call in a pro.
Thanks for using Fixya.
May 22, 2011 | Maytag Washing Machines
My Lacie external drive clicks but won't spin up. It is about a year old, maybe less. It was working fine and just stopped working. It has not been dropped. In fact it hasn't been moved.
Your harddrive is bad, the motor bearing that spins your cylinder heads is damaged, even though the harddrive hasn't been dropped, or removed, this is a result of faulty and cheap product. Theres nothing you can do to replace the motor bearing, you will need to just get a new harddrive and install into the external hd enclosure or get a new external drive. If you decide you want to recover your files, you will need to take this harddrive out and maybe take it to bestbuy/ office depot where they will have to send your harddrive out to a data recovery center. They might be able to recover some data, or all, or none. It is a pricey move to take this step.
Jan 28, 2011 | LaCie Hard Disk 1TB Desktop with Hi-Speed...
My Whirlpool washer LSQ9500LQ0 would not spin correctly, it would slip and you could smell a burning smell. Empty if you manually spun the tub it would slowly pick up on its own and then work. With this...
The old clutch assembly sounds like it was bad. Yes, it does sound like something got put back together wrong. Most likely, the beige plastic "finger" on the spin tube is in the wrong place when you reassembled the unit. Unfortunately, this means totally disassembling the unit again. BEFORE you tear the unit down again, see if the timer is pausing after it is done agitating and before it goes to spin. If it doesn't, it could be a timer. Hope this helps!
Dec 16, 2009 | Whirlpool Washing Machines
Hook up the stereo system in my car
Slide out the head unit and see if the square box with the wires attached has come lose, give it a push back in and try turning on. If this does not work look for the red wire and see if it is still attached, this is your power wire, theres also one or two fuses in the back of you head unit depending on your make and model check for wear and tear they might need replacing.
Sep 15, 2009 | Car Audio & Video
One fan blade stopped working and is hot to touch
The motor is 'locked up' that's where the heat is coming from. It may have a bad bushing or something is jammed. Give it a good look over you may see it. Does the blade feel hard to turn?
Sep 08, 2009 | Minka Aire F602-BNCH Gyro? Fan
Dropped my wd portable hard disk now computer is not reading it
brother
your hard drive has either a crashed head,ir amisalligned head due to dropping it several times. also head stuck to platter is the result of dropping it.and may be the motor of the hard drive has lost its central axis and has got jammed.
if your drive is still spinning i am sure it has head crash problem only.
please try to either get it replaced if its under warrenty.
if you wish to recover data , please pm me.
datarecoveryfactory
Sep 04, 2009 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
My Rainbow SE vacuum was working fine until I ran over the edge of a rug and it went in to the nozzle. I immediately switched the vacuum off and proceeded to move the rug. When I tried to turn the Rainbow...
hello lilbutmunch1,
The brush is motor/belt driven so you probably either broke the belt or it shifted off the motor or brush shaft. I suggest you unplug it,flip it over and look for screws that hold the baseplate together.. remove those screws and seperate the baseplate to gain access to the brush and motor head. Once open, it should be fairly obvious what the problem is.. a broken belt, a belt that has shifted or the brush won't spin freely due to an obstruction. Hope this helps..
Regards,
Rick ( bigbutmunch..LOL)
Dec 04, 2008 | Rainbow E series Canister Wet/Dry Vacuum
Remote works, but not the reciever
This one is tough one. It soundslike you have lost the connection between the flip face and the main head unit. I suggest you pull the head unit and get it to a bench for closer investigation. Look for and tears in the connecting wire harness between the Flip control, and the main Unit.
Sep 03, 2007 | Toshiba Sony CDXM8805X
Kenmore Ultra Wash Dishwasher
Cyber, did you get down to the chopper screen? If that is clogged with gunk it will restrict the flow and the top arm will not spin. Im going to try to attach a pic of the chopper assy and screen. Catriver..post back
Apr 02, 2007 | Kenmore 24 in. 16582 Built-in Dishwasher
Faulty PS2 v12
Hello shaundiane, first of all try by replacing the optical block unit. If the problem persists, continue with replacing the RS2004FS driver IC. Best regards, Arpi
Jan 24, 2007 | Sony PlayStation 2 Slimline Console
Homelite Mighty Lite Lawn Trimmer  Logo
60 people viewed this question
Top Homelite Garden Experts
roeb
Roland W VanLue
Roland W VanLue
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
