Question about Harley Davidson Harley-Davidson Motorcycle Desktop Telephone
03 fatboy have been having problems with the bike taking too long to warm up.. it will bog down and backfire through the aircleaner until after about 2o minutes of riding. I just changed the plugs to see if that would help but it did not. dont know if it is bad gas or what? anyone have ideas
  • 116 Answers
Might be time for camchain followers 20 to 35000 miles usually not hard to check
Posted on Dec 31, 2009
2006 attic cat 400 runs great in 4x4 but when you hit the switch to 2x4 runs bad like it's booging down
'03 400 backfiring/bogging under throttle - ArcticChat.com ...
www.arcticchat.com > ... > ATV's > General ATV Discussion
Apr 3, 2007 - 7 posts - ‎7 authors The engine would only sputter and bog down, kinda like the choke was hung. ... I didn't remember the fan running, so I checked the fan fuse, but it was ... of the windings and cause a misfire, so bad that it would kill the bike. '07 F8 intermittent start and bog issue - ArcticChat.com
Dec 23, 2012
Arctic cat suzuki 700 efi wont start - ArcticChat.com ...
Apr 28, 2012
400 4x4 idles but bogs out when throttle pressed ...
Jun 29, 2011
cat is slowly dying
Oct 10, 2008
More results from www.arcticchat.com
Oct 21, 2015 | ATVs
Motor bogs down
could be from cold transmission oil in the transmission.. check that the manifold heat control valve is working..
Mar 04, 2014 | Chevrolet Impala Cars & Trucks
Toyota 4cyl. truck bogs down backfires after warms up
Hi Bennie, When did you last replace the fuel filter? I believe a service may be the answer to your problem. If you have carried out a service recently, try replacing the fuel filter for a better quality product. Regards John
Feb 15, 2013 | 1992 Toyota Pickup
2005 KTM 450 EXC throttle bogs! Badly! Warm or cold if I nail the throttle it bogs WAY down until I let off, then she wails. The bike has been well taken care of and the motor is bone stock. I too was...
if its bogging that badly i think it may be the jets in ur carb take your carb off and blow through the fuel line and giv a proper clean it may help your problem
Nov 24, 2009 | KTM EXC 450 Racing Motorcycles
1997 FatBoy backfires through the carberator.New carb.
Carburator backfires are almost always due to a lean condition. Check your intake manifold for air leak. Star the bike, warm it up and let it idle on the kickstand. From the air breather side spray a bit of wd40 onto the intake manifold (one side at a time) and listen for the idle to pick up. If it does, you're sucking air around the intake. This should be fixed right away as it will just get worse and could result in burned valves. If this is not the case then check the main jet in your carb and get one that is richer. Trial and error is the only way to determine the best jet for your bike.
Jul 08, 2009 | Harley Davidson Harley-Davidson Motorcycle...
Bike bogs down once warmed up
You should try adjusting your fuel mixture, it seems it's way too rich.
May 30, 2009 | 1996 kawasaki VN 1500 Vulcan Classic
My bike was runing good it,s a94 fatboy the other
Sounds like your voltage regulator is bad or come unplugged
May 09, 2009 | Harley Davidson Harley-Davidson Motorcycle...
I have a 2003 Fatboy that has an unusual idle.
Hello Jim...
Ok, the ignition is stock...
**Have you removed the ignition cover and looked at the ignition sensor? Is resin dripping down the plate? IF so, replace the sensor, but that may or may not rectify this problem.
**YOU CAN Also remove the sensor plate and clean/inspect the pickups on the back of the sensor plate. Be sure to mark/scribe the plate prior to removal so you are back to the same timing.
**Also, check to make sure the
I also need to ask, -does your bike BACKFIRE upon Acceleration?
-does it BACKFIRE upon Deceleration?
And your idle should be set at approx. 950 rpm.
Let me know if the above has been helpful Jim...
-Marko
Jan 23, 2009 | 2003 Harley Davidson FLSTF Fat boy
97 jimmy
Have you replaced your O2 sensor? If not, try that.
Jun 27, 2008 | 1997 GMC Jimmy
Lands Phones Logo
169 people viewed this question
Top Harley Davidson Lands Phones Experts
ted dux
Ronny Bennett Sr.
Ronny Bennett Sr.
David Payne
David Payne
Are you a Harley Davidson Lands Phone Expert? Answer questions, earn points and help others
