Question about Craftsman Garden
Starts when primed but dies...
My mower ran great this morning till I ran out of gas. I refilled and ever since it won't run. It will start if primed but dies within seconds. I looked at the carb and it looks clean. I checked the bowl and it is clean. I did have a slight crack in the fuel line so I replaced it. At this point I'm lost. Any ideas?
    Problem Solver:
  • 7 Answers
Check your gas cap, try running it without your gas cap on and see if that helps if so id either replace it or drill a really small hole in the top as modern engines the fuel is gravity fed into the carb
Posted on Jul 14, 2009
I have a 1986 for ranger this happens very regular now need help asap I can crank it up and it will crank fine most time till this happens going down road the truck will start to bog down you can let off...
If you have any rubber fuel lines in the fuel system, I would replace them. Over a period of time the insides of the hoses swell up and stop the fuel flow to the engine.
Jul 15, 2017 | Cars & Trucks
Primer bulb collapsed
Slightly unscrew the gas cap and see it the problem goes away.
Many times the Gas tank Vent clogs and this will cause the engine to create a vacuum in the gas tank until the engine can't draw in the gas .
Jul 15, 2013 | Garden
Cant get my poulane pro 550 started
gas only lasts for 30 days in small engines try fresh gas if still have a problem take apart the carb and clean it out
Mar 24, 2012 | Garden
Yardman 6.5 HP XL 21'' CUT S/N#D06786CN
See if it will start with a little splash of fuel down the carb.
If it starts for a second you probably have a plugged main jet.
The mowers collect a little bit of fuel in the bottom of the carb and then water comes along and it makes rust and gunk and turns the brass stuff all green. You remove the main jet and clean the two holes on the bottom and the little tiny hole at the top of the threads *(you should wire brush the threads and get a tiny piece of wire strand to clean this jet.)
I know you ran the mower till it ran out of gas....but that was only till it ran out of enough gas to fuel the main jet. There was still fuel residue in the fuel line and the bowl.
This should be a fast fix though. Good luck and be careful!
Jul 18, 2010 | Mtd Yard - Man 160cc, 21" Self - Propelled...
Truck will start first thing in the morning run about 2 min then die, and will not re start. till next morning has plenty of gas and have replaced ignition switch already, after doing this ran great for a...
you must make sure the fuel is getting to motor, check the fuel preasure after it dies check preasure or try spraying starting fluid in throtlebody to see if it a fuel problem, if it doesnt start then check for spark at the plugs,the most common problems are fuelpumps or control modules going bad,
Jun 09, 2010 | 1986 Chevrolet S-10 Blazer
Wont continue to run after prime and start
often the last ounce of gas in the tank has some crud in it. Get a can of carbeurator cleaner spray. Remove the air filter and squirt three short bursts of the cleaner spray into the air port and then start it. Keep giving it short bursts of carb. cleaner until it runs smoothly again.
Aug 12, 2009 | Troy Bilt 5.5hp Self Propelled Mower
After 1 season it ran great ,slowly died now it wont start
So many possibilities, so little data... <grin>
When you say "clean gas", do you mean that you added "fresh" gas, or that you emptied the tank, and refilled it with "fresh" gas?
Try this:
a. remove the "float bowl" screw, and put a regular "bowl" or pan underneath to catch ALL of the gas as it comes out.
b. if the gas is totally "clear", then it (probably ain't the gas), but... if it's "yellow", it's old and/or contaminated; alternatively, if there's any water (which may appear as a grey-ish liquid) then it's contaminated; also, don't forget to check the gas from your "storage" can, the same way...
c. re-install the the screw, and put some *FRESH* gas in the tank.
d. pull the spark-plug, and clean (or replace) it.
e. prime it, and crank it, and it should start right up.
Jul 03, 2009 | Poulan Pro 22" Self Propelled High Wheel...
I have a troy built self propelled mower, it ran great last season, now it will not stay running. I checked to see if it was getting fuel and it is. I primed it and it acts like it is going to run and then...
The jets in carbs are really small and clog easily. If you stored your mower with gas in it start by replacing the gas. Remove the air filter and prime the carb. Start the engine and place your fingers over the air intake on the carb. This will cause the engine to stall as it will be starved for air. It will also create a powerful suction on the jets and possibly dislodge a blockage. Prime the engine again and start. If does not continue to run, repeat the steps again. If after 3-4 tries your engine wont run you will have to remove the carb and clean the jets manually. The reason your engine runs for a short time is because it is burning the fuel that you put in there by priming it. After that the fuel comes through the jets in the carb and if these jets are clogged the engine will die.
Jun 06, 2009 | Troy Bilt 5.5hp Self Propelled Mower
Lawn mower dies
Find the fuel air mixture screw and while the mower is running turn so mower almost stops then turn them back till the moter is running smoother.Give it some throtle to see & hear how it is running
Nov 02, 2008 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Garden Logo
567 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
