I have water in the tub at all times, when the machine is finished with a load, you can spin the tub and the water sloshes in it, and now my clotes smell. Is the water suppose to be in the tub?
  • 25 Answers
Blocked sump hose ie hose from tub to filter or blocked filter
Posted on Jul 13, 2009
Standing water under tub in washer
Some washers don't pump out completely during the spin cycle.
Aug 16, 2016 | Samsung 4.8 Cu. Ft. Top Load Washer -...
My maytag neptune spins water out, the tub is empty but when you turn the tub manually you can hear water sloshing and the clothes smells moldy after washing
There will always be some residual water left in the outer tub after draining. This is normal for most washers. Purchase a container of Oxy-clean and cycle the washer a few times using hot water settings with a half-cup of Oxy-clean added to each cycle. This will help remove any organic matter left behind that might be causing odors.
Oct 15, 2014 | Maytag Neptune MAH5500B Front Load Washer
Unbalance when spinning
Unauthorized water gets into the tub ring. Sloshes about and cause unbalanced load even if nothing is in the washer. Rich mans solution: replace inner tub. poor mans solution: drill holes, drain water.
Dec 18, 2010 | Maytag Bravos MTW6600T Top Load Washer
Water leaking from under machine, doesnt do it all the time, but when it does leak it makes a skreatching noise too
This sounds like the transmission making the noise you are talking about. If this is only happening on the highest water level setting and when you have a big load, the tub may be adijating and spinning at the same time causing the water to slosh over the top of the tub.
There's not much I could reccomend that you do if this is the case other than lower the water level setting and load size and/or replace the machine. Don't waste your money investing in a new transmission - buy a new machine instead.
Jun 16, 2010 | GE WBSR3140DW Top Load Washer
Standing water
do you see water in tub?
if you are just spinning tub and hearing sloshing that is the liquid in balance ring and is normal
Apr 18, 2010 | Maytag Neptune MAH5500B Front Load Washer
Hello, On Neptune washer serial # 34098916EF, Washer tub fills with about 2 inches of water within hours after doing a wash. When I spin the tub by hand, I hear water sloshing inside. Machine drains fine....
You have a bad water fill valve. Until you get it fixed shut water valves off at the wall so that you don't have a flood if the fill valve on the machine fails completely. Let me know if there is anything else I can Help you with.
Ken
Mar 17, 2010 | Maytag MAH6700AWW Neptune Front-Load...
Maytag neptune error code lr
i think this one is the one with the clutch. if it does it b4 it spins. put it on a spin. if it doesnt spin, u need a clutch. under the unit the belt is whapped on it
Feb 12, 2010 | Maytag Neptune MAH6500A Front Load Washer
WHEN WASH IS COMPLETE, WHEN YOU SPIN THE TUB BY HAND YOU CAN HEAR WATER SLASHING.
The pump cannot completely drain all the water out of washers. There will be some water left in the bottom of the tub that you can't see but here slosh around if you move the basket. If your clothes are not wet, this is probably normal.
Jan 24, 2010 | Maytag Neptune MAH5500B Front Load Washer
Water remains in tub after spin cycle
Have you tried to clean the drain hose on the back of the washer? It may have build up inside that you are loosening up by using bleach.
Sep 06, 2009 | Frigidaire ATF6000ES Front Load Washer
Clotes come out soaked
The spin bearing or basket drive maybe worn or seized. Lubrication maybe needed. The motor starting torque is not sufficient to spin the tub during start-up. Check also the motor rotor. When turned by hand, it must spin freely. Lubricate if necessary. Otherwise the bearings/bushings are worn out and needs alignment or replacement. You may need the service of a qualified appliance repair technician.
Aug 21, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Washing Machines Logo
88 people viewed this question
Top Washing Machines Experts
