Question about Lite On (SOHC5236V) CD-RW/DVD-ROM Combo Drive
My computer opens Lite On 5236 (drive E:) yet sees nothing?
PowerDvd displays the error: "a disk with unsupported format on drive E:"
Drive E: is the correct drive letter for the Lite On 5236 combo drive.
powerDvd (and all other media programs) work(s) fine for all AV stored on HD.
5236 drive plays, AND autoplays, CD and data CD's fine; and burns fine Audio only of course).
These types of files also show up as "files currently on the CD" when viewed under "my computer." (XPpro/pentium/etc w/NO Other conflicts or issues).
The other drive (cd-rom) works fine for all media/data.
BUT a DVD shows no files at all...is this definitely a prob w/ the drive or could it be with the registry or...? I used autorun fix from MS and arrived at the following:
AutoFix [V5.2.3790.67]
Time [2007-11-16 14:16:43]
Microsoft Windows Version [5.1 (Service Pack 2) <2600>]
Test [The Shell Hardware Detection service is running.] - Instance [N/A]:
Result [AutoStart Setting]: OK
Result [The Shell Hardware Detection service is running.]: OK
Test [Policies] - Instance [E:\, Drive Type: 5]:
Result [HKCU\...\Policies!NoDrives]: OK {Absent}
Result [HKCU\...\Policies!NoDriveAutorun]: OK {Absent}
Result [HKCU\...\Policies!NoDriveTypeAutorun]: OK {Present}
Result [HKLM\...\Policies!NoDrives]: OK {Absent}
Result [HKLM\...\Policies!NoDriveAutorun]: OK {Absent}
Result [HKLM\...\Policies!NoDriveTypeAutorun]: OK {Absent}
Result [Driver level policies]: OK {
HKLM\...\Services\cdrom!Autorun (Present)
HKLM\...\Services\cdrom\Parameters!Autorun (Absent)
HKLM\System\CCS\Enum\...!AlwaysEnable (Absent)
HKLM\System\CCS\Enum\...!AlwaysDisable (Absent) }
Test [Drive Notification] - Instance [E:\, Drive Type: 5]:
Result [Legacy Notification]: Problems
Result [AutoPlay V2 Notification]: Problems {
Service (Silent)
Shell (Deaf) }
>> Repair << [Legacy AutoPlay Event]
Step: No steps to take.
Result: This AutoPlay setting cannot be fixed. Either the device is malfunctioning, or the wizard cannot determine the problem.
>> Repair << [Autoplay V2 Event]
>> Required action: The wizard found problems but cannot fix them -> None
THANKS!
~jesse
  • jesse loop
    jesse loop Nov 19, 2007
    sure does...i just re-installed the update from the Lite-On website which didn't seem to do anything, and of course i've already removed and reinstalled this component a couple times...
    thanks.
  • 51 Answers
When you check the properties of the device does it recognise the drive
Posted on Nov 19, 2007
Create boot disk
Insert a blank diskette into the floppy drive. Click start click on computer you should see all of you drives.
Right-click on Drive A. You will see the option to format the drive.
Click on Format. Depending on your operating system, you will see an option that reads either "Create a system disk" or "Create a MS Dos system disk." Click the box next to this option.
Click the "Start" button to begin formatting the disk.
When completed, you will have a bootable floppy disk.
For CD Rom or DVD disks
Open the software that you use to burn or write files to the CD-rom or DVD drive.
Click on "Make a Data CD or DVD." Insert a blank CD-R or DVD-R disk into the drive.
Look for the option to "Make this disk bootable." You may have to scroll over the various icons displayed to find this option. Click on the option.
Burn the CD or DVD as usual. Once completed, this disk can be used to boot your computer.
hope this helps
Aug 22, 2012 | Seagate Computers & Internet
What do i do if my hard drive is only saying unsupported format on the screen ?
Did you format this drive using Mac computer? The only time when the computer will display "Invalid or Unsupported format" is when Windows do not recognize the file format that you are using on the external drive. If this is the case you may need to format the drive, but backup your files first before doing that.
Aug 27, 2011 | Verbatim 500GB USB Desktop 500 GB Hard...
FREEZES UP AND STOPS.SCREEN SAYS CANNOT READ DISC OR UNSUPPORTED FORMAT
Check the disk for scratches, and attempt to play it on another DVD player or your computer, if it has a DVD drive installed. The drive will have DVD written on the front. If the disk isn't a commercial DVD but playable on the computer then the problem is a unsupported format. To make sure your DVD player is working correctly put a known good DVD the player to ensure it still works.
Feb 28, 2011 | Bose (321GS) System
"windows cannot format this drive. Quit any disk utilities or other programs that are using this drive and make sure that no window is displaying the contents of the drive. Then try formatting again"...
Is this a main PC/laptop drive? If yes, you would need a bootable windows CD to format or reinstall..
If it is an external or secondary drive, you can use a bootable disk to boot to dos and format it...you can also use a USB thumb drive to boot from...
Jan 25, 2018 | Dell Computers & Internet
DVD plays in DVD player is not seen at all by Windows XP
Hi,it's obvious from your problem that the particular disc that cannot be viewed on your computer is of a formatt not supported by the windows XP.some DVDs are of low quality which can be viewed practically on any DVD player but as a result of their low quality and the sensitivity of the Windows they are not recognized by your computer. In as much as other DVDS play on your computer,it means there's no problem with your computer,but an unsupported disc formatt is been trying to be viewed and there's nothing you can do to view a DVD formatt not supported by your computer.please don't be bothered.
Thanks and take care
Apr 21, 2010 | LG SecurDisc 20x Internal Double-Layer DVD...
Dvd-rom not able to read pc dvd game
What is the game title and manufacturer? Can you read/play any other type of DVD on this drive?
Mar 12, 2007 | Lite On LITEON DVD-ROM16X, 21600KB/sec...
Lite On (SOHC5236V) CD-RW/DVD-ROM Combo Drive Logo
186 people viewed this question
Top Lite On Computers & Internet Experts
John Anderson
John Anderson
Rommel Balcita
Gbenga
Are you a Lite On Computer and Internet Expert? Answer questions, earn points and help others
