Had 77 jimmy 4x4 could go anywhere. What is the difference between posi and limited slip on these newer ones today or is something wrong or do I have a big problem, please explain in simple terms I can understand.
4 wheel drive is unfortunately a bit of a myth as in 4 wd any two wheels with no traction will not move you any where
so if you have both rh side wheels slipping,
go no where
left front right rear ,
going no where
the wheel that was not turning was the only wheel that had traction but through the differential action the other wheel spun faster
now with limited slip diff centers , both wheels have to turn as the differential action locks up so yes you would be going some where.
posi traction is the same idea
vehicles that have limited slip diffs are Toyota and Nissan as standard with some Nissans having limited slip diffs in the front drive axle as well
now if you are doing a lot of 4wd driving in adverse conditions , you need to have locker diff centers ( available from off road shops ) as they physically lock the diff actions ( with the flick of a switch) with the result if all 4 wheels are spinning and you are not moving , your stuck but if one wheel has traction you keep moving
