Question about Frigidaire Dishwashers
I have a frigidair dishwasher serial number th73793661 purchased in 07. It continues to wash and rinse but never turns off and no heating unit comes on. I have for some time had wet dishes and even mold in the trays. Is this repairable? mary Anna rushia
  • 2,200 Answers
Hi
Your dishwasher is certainly fixable - the issue is troubleshooting to find where the fault lies.
From your description this can be narrowed down in order to three areas as follows
1) The thermostat controlling the heater element is faulty or has been tripped
2). The heating element has stopped heating and is faulty.
3) The control board is faulty and has stopped cycling into the heat cycle and onto the drain cycle.
You may be lucky and find that the thermostat has been tripped. With the machine unplugged from the socket remove the bottom 2 screws in the panel giving you access to the underside of the machine. You don't need to remove the dishwasher.
If you look inside the dishwasher you will see the element and on the left hand side near the front the thermostat.
Underneath the thermostat is a small red button - reach in and push this - if it clicks - you've fixed it!
Total cost zero!
A heating element would need to be checked with a multimeter to determine if it is faulty as would the control panel.
It does sound suspiciously like your control panel is the problem as the machine does not appear to be cycling properly through heat and then drain etc .... but if you feel confident about doing it the thermostat trip is well worth checking out as you may just be lucky.
As always make sure the machine is unplugged before attempting to make any repairs to it!
Hope this helps. Please remember to rate my answer. Many Thanks.
Posted on Jul 13, 2009
Frigidaire diswasher not drying dishes properly
Make sure you have the heated dry setting selected, use rinse aid at all times, and make sure the unit is getting hot. If it is not, or there is no steam generated when you open the unit after cycle - have a professional diagnose the heating element.
Aug 01, 2012 | Frigidaire Dishwashers
Light is on for heat dry but won't allow me to run a cyle or turn on
Hi
Open the door. Within 3 seconds press the following sequence --Try pressing normal wash, heated dry, normal wash, heated dry, normal wash, heated dry three times within 6 seconds and then press cancel to reset the dishwasher. If that doesn't help then try pressing Saini Rinse, Heated Dry, Saini Rinse, Heated Dry, Saini Rinse, Heated Dry or Saini Rinse, Air Dry, Saini Rinse, Air Dry, Saini Rinse, Air Dry 3 times in 6 seconds and then the Cancel Button. Close the door and press Cancel.
Blinking lights would stop and should be able to use your dishwasher normally. If the light is still blinking try and reset the power to the dishwasher and try again. If still the light is blinking then check for the connections on the keypad, it may be due to moisture or shorted connections on keypad.
Hope this helps... Please post back if you need more information.
Daniel
Apr 17, 2011 | Frigidaire Professional Series 24 in....
Here again is my model and serial it stops in the middle of the cleaning cycle Kenmore 665.16773402 serial # ft0302854 Here is how I have been resetting the dishwasher. I hit the following sequence of...
Door latch.
Open and close the door to make sure the door latch is securely fastened
Hi-Temp Wash, Hi-Temp Rinse, or Sanitize options.
Some models have options that may require a water heating delay, such as Hi-Temp Wash, Hi-Temp Rinse, or Sanitize. Additional time may be required to heat the water to the proper temperature. The dishwasher will continue to circulate water during this heating delay but the timer will not advance until the proper temperature is reached
Oct 06, 2010 | Dishwashers
My Dishwasher (Westinghouse907 series) will not advance past the prewash/rinse cycle. I have cleaned out the filters. I also turned it off for a while and when I turned it back on it worked, but has now...
Hi
Thanks for using FixYa. If the cycle doesn't complete, then the first thing that should be checked is the Timer and then the heating element. Timers don't often fail. But if every other part of the dishwasher seems to be working properly and the timer knob seems to be stuck in one place--doing one function continuously--the timer may be at fault. Dishwasher timers can't be repaired. If yours is defective, replace it. Many dishwashers heat the wash and/or rinse water to a higher temperature, as the cycle calls for it. In these cycles, the dishwasher pauses after it has filled with water, waiting for the water to reach the pre-set temperature. What happens next depends, as follows: On some units, the pause is timed and the unit continues after the allotted time. On others, the cycle can't continue until the water reaches the higher temperature. If you have this type of dishwasher and the water isn't being heated (say, because of a problem with the heating element or thermostat), after the unit stops at the heating cycle, it never continues. When you repair the heating-system problem, the "cycle problem" is fixed too. Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
May 23, 2010 | Westinghouse 24 in. MDP531 RF...
Frigidaire fdb1050rem2 dishwasher will not drain during was cycle
Checked water temperature at water heater. It was at 110 degrees. Turned water heater up to 125 degrees. Dishwasher works perfectly now.
Mar 30, 2009 | Frigidaire 24 in. FDB1050REC Stainless...
Hi my hoover 6612 dishwasher does its pre-wash but then when the light for wash comes on it does nothing. I wondered if it might be a capacitor which needed replacing but I can't find one - any ideas??
Check the float switch inside the tub, it should move freely up and down.
Check the harness to the motor
Check start capacitor on the left side of the wash motor
Mar 13, 2009 | Dishwashers
Frigidaire dishwasher not completing cycle.
hi,
The cycle doesn't complete
If the cycle doesn't complete, check these:
Water-heating cycle
Timer
Water-heating cycle
Many dishwashers heat the wash and/or rinse water to a higher temperature, as the cycle calls for it. In these cycles, the dishwasher pauses after it has filled with water, waiting for the water to reach the pre-set temperature. What happens next, depends, as follows:
Timer
I see an error code
If your dishwasher has a digital readout and you see an error code, it may indicate a problem with the unit. If this happens, look up the error code in your owner's manual to find out what the problem is.
Good Luck
Jan 03, 2009 | Dishwashers
Won't run through cycle
Water-heating cycle Many dishwashers heat the wash and/or rinse water to a higher temperature, as the cycle calls for it. In these cycles, the dishwasher pauses after it has filled with water, waiting for the water to reach the pre-set temperature. What happens next, depends, as follows:
  • On some units, the pause is timed and the unit continues after the allotted time.
  • On others, the cycle can't continue until the water reaches the higher temperature. If you have this type of dishwasher and the water isn't being heated (say, because of a problem with the heating element or thermostat), after the unit stops at the heating cycle, it never continues. When you repair the heating-system problem, the "cycle problem" is fixed too.
Timer Timers don't often fail. But if every other part of the dishwasher seems to be working properly and the timer knob seems to be stuck in one place--doing one function continuously--the timer may be at fault. Dishwasher timers can't be repaired. If yours is defective, replace it.
please rate my solution thanks
Jun 30, 2008 | Frigidaire 24 in. FDB1050REC Stainless...
Whirlpool ADP 5966 Dishwasher using the complete salt load in 6 washes and coating all the dishes in salt that would not rinse off. I filled the salt and 6 washes later it was requiring a new load of...
Hello, we are sorry to hear that you are experiencing this problem with the Dishwasher. We would recommend having a certified technician out to diagnose the problem. If you would like further assistance you can send your name, phone number, address, model/serial numbers and the date on which you purchased the Dishwasher to Whirlpool_Reviews@Whirlpool.com. Thank you.
Apr 17, 2017 | Whirlpool 24 in. ADP5966 Free-standing...
Dishwashers Logo
Top Frigidaire Dishwashers Experts
Mike
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
