Question about Electrical Supplies
WILL NOT IDLE SMOOTHLY ENGINE RUNS GOOD UNDER LOAD
  • sal sabea
    sal sabea May 11, 2010
    what's the brand?
  • 37 Answers
Start with carb, try partially choking it at idle if it smoothes out its defintely a dirty carburator.
Posted on Nov 23, 2009
2007 V8 diesel sport. Missing badly at idle (650 RPM) when cold, runs smoothly if revs raised to 1000 RPM. Does not appear to miss under full power, and will generally run smoothly at idle when warm.
most likely bad injector tips
have them serviced and raise the idle to 750 rpms as the lower idle speed may not be raising the combustion pressure temperature to ignite badly sprayed fuel ( diesel has to be atomized not squirted )
Dec 01, 2016 | Cars & Trucks
What causes a 1989 nissan pickup ping or knock?
Pinging or detonation is caused by the spontaneous combustion in the chamber from incorrect air/fuel ratio and timing. It is most prevalent in lean mixtures under load. Run the fault codes and check for faulty HO2s and O2 sensors as they tell the ECM what mixture and timing is required to stop it
Apr 25, 2014 | Nissan Pickup Cars & Trucks
85 nisson pickup z24 hesitation
if engine idle good stall on acceleration either fuel filter clogged or fuel pump weak has low fuel pressure.
Dec 10, 2011 | 1985 Nissan Pickup
What is the timing set at on a 69 gto with 400 ci also, what are the points set at
I don,t know the exact settings but I would set timing by starting about 5 degrees and advancing to wher engine cranks good when warmed up and does not spark knock under load. The points should be fine at .017 or a little more if it doesn't idle smoothly.
Aug 08, 2011 | Pontiac GTO Cars & Trucks
My 1996 v6 chevy truck engine runs good at idle but in drive it has poor acceleration. In idle I can maintain 2500 RPM but in drive it does go to 2500 but the truck acts like it has resistance. I was...
sounds like a catalytic converter - runs good but lacks power - the back pressure keeps the engine from being able to accelerate under load - good luck :O)
Feb 19, 2011 | 1991 Chevrolet S-10 Blazer
When started engine surges and almost dies, sputters, occasionally pops, but seems to run smoothly under load. In the old days could adjust the low idle screw on carb...now what? Can't be good for engine...
Take the carb off and clean it out .sounds like it got some dirt in it.if that don,t work put a rebuild kit in carb and replace the intake gasket with a new one.it could be sucking air.
Dec 15, 2010 | Garden
CLEAND CARB NEED TO KNOW HOW TO ADJUST CARB
Most carbs have the adjustment removed (EPA) but if yours still has the adjusting screws here are the seat of the pants methods:
One Screw Carb: Turn it all the way in and then back out 3-1/2 turns, start the engine and make slight turns in or out until the motor runs smooth from idle to wide open, do not get it too lean, turn in until max RPM is reached then turn out 1/8 turn and go from there.
Two Screw Carb: You adjust the one to remedy either the low or high, high is adjusted until the motor runs smoothly under load at high RPM and the low is adjusted until idle and off idle is smooth.
Feb 27, 2010 | Troy Bilt Tb70ss Gas Trimmer
Golf engine cuts out while on idle
clean your throttle,,, try a carb cleaner, it will cost you about 5$ :)
May 24, 2009 | 1999 Volkswagen Golf
1991 dodge colt won't idle when engine is cold.
probably oil, it may be too thick when it's cold but once it warms up it liquefies and your engine runs smoothly. you could try changing oil, I'm guessing if you have a high performance oil the chances this is the problem may be greater since high performance things are usually geared towards working well when everything is hot
Jun 29, 2008 | 1991 Plymouth Colt
Electrical Supplies Logo
201 people viewed this question
Top Electrical Supplies Experts
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
