Question about Belkin F5D7230-4 Kit (F5D7230V4SNPDQ)
My router just stopped working. The internet
My router just stopped working. The internet light is not on, what is wrong?
  • Dick
    Dick May 11, 2010
    There is no way to tell from the information you have provided. Get out your manual and go through the troubleshooting steps listed. If you don't have the manual, go to Belkin's website and read it there. Post here with the results of your testing if you need more help or don't understand something.
Hi All,
Some times the Belkin WR, can't get the NTP from the primary or secondary server, on the system settings Utilities. You can see for the Wrong Date in the Time & Time Zone place. Change to other server and Apply Changes, wait & look at the Security Log on the left hand menu; FireWall.
Restarting the Belkin Router will can help, some times I have to do this. But this time doesn't work for me. I'm keep trying to found a solution. Anybody knows how?
Regards.
Posted on Jul 31, 2009
  • 33 Answers
There can be several causes for this:
1. Check for power to the router which can be lost because of a loose DC plug or bad power brick.
2. Check the DSL or cable modem if it is working properly and can get you on line if directly plugged into your PC.
3. If any of the above are ok, then your router has just died. Routers have a high rate of failure so I won't be surprised if this was the case with yours.
Posted on Jul 13, 2009
Magic Jack Plus worked in USB and then Internet on computer stopped working
It's got the wrong gateway setting. Without a gateway (router) to the Internet it can only see local network stuff. I suspect the Magic Jack is still trying to be the gateway but it has no Internet. Stop Magic Jack doing this and it should work.
Feb 27, 2015 | Computers & Internet
I have a netgear wnr3000 router and all of a sudden my internet stopped working now there is an orange blinking light
The orange blinking light tells you, you have not got an internet connection. Check the settings on the router.
Jun 22, 2014 | NetGear WGR614 Wireless Router
I will be working on the internet and suddenly the connection is dropped. It will restart when I unplug and replug in. Will run fine for a few hours and then stop again and have to unplug/replug. All...
I would call the professional and have him replace/repair it for starters. There is obviously something wrong with the hardware or the connection of your Internet Provider, ether way the install should test the connection and stand behind his installation. If you paid this guy demand, politely but firmly of course, to repair it. 2DAYS OLD, I would be livid. By the way I do the exact same thing as your professional.
Nov 09, 2012 | NetGear N300 Wireless Router
Netgear DG834G router dropping internet connection
You could try a firmware update, if this is no better it may be time to ask your ISP for new router.
Aug 01, 2010 | NetGear DG834G Router
Just stopped working. all lights light up - but
you did not post model, you did not post what operating system on your computer either. general help therefore only can be provided. if you post required data, then i can provide more detailed instructions how to check your router.
disconnect all cables from the router, including power cable, wait about 20sec then insert cable connecting to the computer, insert cabel connecting your telephone line and then insert power cable.
in about 2min router should connect itself to the line and to the computer.
check if you have valid ip address on your computer (in most linksys routers it will look someting like: 192.168.1.***), that will meant that router did establish connection with computer. check if you can connect to the internet (through the cable!), if you can, this meant that your router is working correctly, so is your computer. disconnect cable and check if you can connect via wireless, if yes, problem is solved, if you cannot, check and compare settings between your computer and router, problem ususally is wrong credentials on the computer or wrong protocol. both of these must be same on the router and on the computer.
if you use wep, wep must be in both, on router and on the computer, if you use network name johnny, exactly this same spelling in router and computer must follow, same with password. and do not use spaces in passwords! especially if you use password on every login...
Jul 22, 2010 | Linksys Wireless-G Broadband Router
Router stopped working.
As long as the power light stays solid, then the router is fine. You need to reconfigure the router for it to receive internet connection from the modem.
May 17, 2010 | Linksys Wireless-G Broadband Router
No power indicator light
This is a common symptom with the router. The hardware of the router has failed. It will not work anymore.
Please get a new router.
Apr 27, 2009 | NetGear WGT624 Wireless Router
Cant get internet on both computers using router
When did the router stop working?
Have you tried a new cable between the router and the modem?
Since the status light is off on the router, that tells me that there is no communication between the router and modem. Is it possible that the router was reset by accident? Resetting it will put all settings to default. If it has been reset then you need to sign on to the router to setup the communication again to your modem. Typically this is done via the IP address.
I can walk you through those steps if that is the case. Try supplying a different cable though between the router and modem. Power off both of them, power on the modem and then power on the router....then try to connect to the Internet.
Mar 26, 2009 | D-Link DI-624 / DWL-G520 Kit...
Wireless router stops internet connection to modem during install
are you sure your hooking the comcast modem in the right place?
Feb 08, 2009 | Arris SURFboard SB5120 Modem
Router stops responding with red alert light turned on
Is the actual router not responding or the internet?
(IE - can you still log into the router but the internet won't work, or will it not even connect to the router)
Dec 27, 2007 | 2wire 2700HG-B Router (2700HGB)
Belkin F5D7230-4 Kit (F5D7230V4SNPDQ) Logo
228 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
