Question about Nokia N70 Cellular Phone
My usb cable can't connect - Nokia N70 Cellular Phone
  • 57 Answers
Replace cable
Posted on Jul 14, 2009
  • nuygas
    nuygas Jul 14, 2009
    replace cable
Won't reload on my ipad
Connect to wall outlet Uses the USB power adapter and USB cable included with the device. If it is a third-party accessory, check to see if it is Apple Certified . Then follow these steps:
  1. Connect the iPhone, iPad or iPod touch to the Lightning to USB connector cable or the 30-pin to USB connector cable .
  2. Connect it to one of three power sources:
Wall outlet
Connect the charging cable to a USB AC adapter and connect the USB AC adapter to the wall outlet.
Computer
Connect the charging cable to a USB 2.0 or 3.0 port on a computer that is not in sleep mode. Do not use the USB ports on the keyboard.
Power supply
Connect the cable to a powered USB hub, docking station, or other Apple-certified accessory.
When the device is charging, you will see a lightning bolt next to the battery icon in the status bar or a large battery icon on the lock screen.
Aug 12, 2017 | Tablets & eReaders
Tip
How do I Wire a USB Cable to a Stereo Phone Plug
<p>In general, the audio devices use audio cables such as RCA stereo headphones, or telephone cables, connection to other devices. In case you need a USB device to a stereo phone plug, you should use a single adapter cable to connect the USB cable will convert to a stereo phone. <br /> <p><br /> <p>1. Connect the USB end of the headphone adapter to the USB port of your audio device. <br /> <p><br /> <p>2. Connect one end of the headset to your male cable to the headphone port of the headset USB adapter. <br /> <p><br /> <p>3. Connect the other end of your headphone male to male cable to the headphone port of your stereo plug. Now you can connect to any port to connect to stereo. <br />
on Aug 05, 2011 | Cell Phones
Usb connection brack recionnection
Most external webcams directly hook up to a computer via a USB cable connection. However, if this cable is damaged, it will prevent the video signal from reaching the computer, rendering the web camera useless. Depending on the severity of the damage, you may be unable to correct the USB cable, but there are a few methods of checking and fixing the webcam's USB cable.
Disconnect the USB cable from your computer and check the connection port on the cable. If the cable is dirty or dusty, you will need to clean it to improve the connection and signal transfer. Spray a few shots of compressed air into the interior of the metal connection port. This will remove dust and other debris that may be stuck inside. Connect the USB port into a different connection port. Some USB connections do not accept all USB equipment, so changing the connection of the USB cable may correct any connection issues you are having. Look over the cable itself. If there are any tears or slight cuts in the wire, wrap electrical tape around it. This will seal off the damaged area while preventing any of the video signal from escaping through the open "wound." Delete the driver, then reinstall the driver for the webcam. The current driver may be damaged, so reinstalling it will correct the problem. Click "Start," "Control Panel," "System," "Hardware" and "Device Manager." Scroll through the list of drivers installed until you find the webcam listing. Right-click it and choose "Delete." Restart the computer, then insert the driver installation CD (provided with the webcam) and follow the onscreen prompts to install the driver back onto the computer.
Hope this helps.
Jan 14, 2013 | Computers & Internet
Trying to connect HP Laserjet 2100 (works fine with XP) to Pavilion dv7 with Win7 64 bit Professional. I downloaded the PCL5 driver from HP but it will not print. I am using a Manhattan parallel to USB...
Did you download the Win 7 64 bit drivers for this printer. If not i suggest try downloading the drivers from the following link
http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareIndex.jsp?lang=en&cc=us&prodNameId=14914&pr...
Check the USB connection
The icon on the USB cable (c01424575.gif ) faces up when the cable connects to the product correctly. Check the back of your product and the back of your computer to make sure the USB cable connects correctly and securely.
After you make sure the USB cable connects correctly and securely, review the following guidelines to check other potential USB-related problems:
  • USB ports on the keyboard. USB ports on the keyboard and in the front of some computers might not be powerful enough to support the product. If the USB cable connects to the USB port on the keyboard, try connecting it to another available USB port on the computer.
  • USB cable length. HP supports USB cables less than 5 m (16 feet, 5 inches) long. However, a USB cable that is 5 m (16 feet 5 inches) long must be of high quality. Otherwise, HP recommends using a USB cable that is less than 2 m (3 feet, 3 inches). Do not use patch cables to increase the length of an existing cable. Use a powered USB hub if you need more length.
  • Alternate USB ports. Connect the USB cable to another port on the computer to make sure that the USB port on the computer is not the cause of the problem.
  • Defective USB cable. Replace the USB cable to make sure that the existing cable is not defective.
  • Conflicting USB ports. Disconnect any other USB printers, USB scanners, USB cameras, and any other USB connected peripherals. Start reconnecting these devices one at a time to determine if one of the devices is using too much power. Consider purchasing and installing a powered USB hub if necessary. NOTE: A USB-powered hub is a device that increases the number of available USB ports on a computer and facilitates communication between the USB devices and the computer. A powered USB hub can resolve communication failures between some, but not all, USB chipsets and HP products.
Jun 23, 2011 | HP LaserJet 2100 Printer
Error code = 6A00 whats the problem
ou should disconnect and reconnect the USB cable at both ends to ensure there is a secure connection on the device side as well as the computer side. (Refer to the illustration below to confirm the USB cable is in the proper orientation.) It may also be necessary to try a different USB port on the computer. Additionally, you may need to disconnect other USB devices, temporarily, in order to determine if a conflict exists. Note: Some printers have a type-A USB receptacle on the front to connect directly to a digital camera. The type-B receptacle, on the printer, will connect to the type-A receptacle on the computer with an A to B USB cable.
  1. Disconnect one end of the cable and then reseat it ensuring the cable is firmly seated into the USB port. If the USB cable is plugged into a hub instead of directly into the computer, connect the USB cable directly into the computer.
  2. Repeat step one to reseat the cable on the other end.
    There shouldn't be any resistance when connecting the USB cable to the device. If the cable does not easily slide into the device's port, look at the end of the connector. The shape of the connector should match the port on the device.
    Note: All USB cables will have a USB icon on one side. The side of the cable where the icon is situated is different than the other three sides.
Icon on USB Cable
Shape of the USB Connector
  1. If there is still no communication, then it may be necessary to try a different USB cable or a different port on the computer.
  2. Make sure the correct USB cable type is being used.
Incorrect (A to A) USB Cable
Correct (A to B) USB Cable
Jan 04, 2011 | Canon PIXMA iX7000 Inkjet Business Photo...
HI Sir, My Samsung Corby F339 Mobule is not connect in my pc showing error 692 there was a hardware failure in the modem(or other connecting device) plz help me.....
This error usually comes when you use usb cable to connect the phone to pc . Please try to unplug the cable and plugin the USB cable to another port and try via pc suite to connect to internet. If still it is not working try to connect on another pc via same USB cable to phone. If you are getting the same error still then this means the USB cable is damaged then change the USB cable and you can connect to PC. If USB cable works with other pc then reinstall pc suite or try connecting by creating dial up connection.
May 24, 2010 | Lands Phones
Dont know if I have the right cords specifically what is the connection process.
If you go to the Canon support site here you can downlod easy setup instructions. This page has some other manuals and user guides that may also be of use.
Here are the basic usb cable instructions:
Connect the USB Cable Correctly (i70 / i80 / iP90) Instructions to connect the USB Cable Correctly to the printer (i70 / i80 / iP90). Before connecting the cable
After confirming the printer and computer are turned off, connect them using the USB cable (sold separately).
Note: Below is an example of what a standard 'A to B' USB Cable looks like.
How to connect the USB cable
  • Plug the flat connector of the cable into the USB port of the computer.
    Note: If there are two or more USB ports in the computer, any available port may be used.
  • Plug the squarish connector of the cable into the USB cable receptacle of the printer.
<1> Computer's USB Port
<2> Printer's USB Cable Receptacle
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Aug 20, 2009 | Canon PIXMA iP90 InkJet Printer
Network or usb cable
Look on the back of the printer. If it's possible, you'll see a USB connector that looks kind of like an arch or doorway. If so, use a USB A to B cable to connect it to your PC. Make sure you use the drivers for a USB connection when reinstalling it.
Jan 14, 2009 | Kyocera Office Equipment & Supplies
Hp all in one
Try the follwoing steps, i m sure that it will start working bcoz i tried the same steps and my printer started working:
  1. Turn the power to the computer off.
  2. Press the power button to turn off the product.
  3. Wait 10 seconds.
  4. Restart the computer.
  5. Press the power button to turn the product back on.
  6. When the computer restarts, try the scan again.
  • If the issue is not resolved , try some other troubleshooting:
  • Connect USB cable directly to the computer and then restart the product and try to scan again
  • If the product still does not work , try some other steps:
  • Connect the USB cable to a USB hub or a docking station for a laptop. 1. Restart the computer and the product and try to scan again.
  • If the product doesnot works after connecting the USB cable directly to the computer , follow these steps:
      1. Reconnect the USB cable.
      2. Try the scan again.
        • If the product worked when the USB cable was connected directly to the computer, but does not work after reconnecting the USB cable in the original configuration, there might be a problem with the hub or docking station. Either leave the USB cable connected directly to the computer, or contact the manufacturer of the hub or docking station for troubleshooting.
      If the product does not work after connecting the USB cable directly to the computer , follow these steps.
      1. Replace the USB cable.
        • If the product does not work with the new cable, continue to the next solution.
    Now, if this doesnot work, there is a conflicting USB device connected to the computer
    1. Disconnect all other USB devices from the computer except for the keyboard, the mouse, and the product.
      • The issue would be resolved now and teh answer is that the computer might not have sufficient power supplied to the USB ports to detect multiple USB devices. HP recommends installing a USB powered hub to connect multiple USB devices.
May 28, 2008 | HP DeskJet F380 All-In-One Printer
Connecting analong camcorder to computer
The only Analog camcorder that has a USB Connection for transferring pictures or video is the SC-L770. The SC-L770 can transfer video (live or recorded) and still photos through the USB connection. You can also transfer audio using the audio cable provided. After installing the driver and software, you can begin transferring data using the software provided. Connecting to a PC 1. Connect a USB cable to the USB port on the PC. 2. Connect the other end of the USB cable into the proper terminal on the camcorder. (USB jack) 3. Connect the audio cable to the Line input jack of the PC. If the PC has no Line input jack, connect the audio cable to the MIC input jack. In this case, however, a noise may be produced depending on the PC. Notes: * If you disconnect the USB cable from the PC or the camcorder while transferring, the data transmission will stop and the data may be damaged. * If you connect the USB cable to a PC via a USB HUB or simultaneously connect the USB cable along with other USB devices, the camcorder may not work properly. * In this case, remove the other USB devices from the PC and reconnect the camcorder. Some other Analog Camcorders have a snapshot mode which allows you to take a still photo with your camcorder. However, you cannot transfer these to a computer unless you purchase additional hardware such as a capture card. Some capture cards have analog a/v inputs which will allow you to use the a/v outputs on the camcorder to connect to your pc and transfer images and video. You can purchase a capture card at most computer and electronics stores. Samsung does not support capture cards.
Sep 06, 2005 | Samsung DouCam VP-D5000i Mini DV Digital...
Nokia N70 Cellular Phone Logo
41 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
