Question about Canon Office Equipment & Supplies
Clicking sound and in use/memory light flashes. Canon PIXMA MX850
I changed the usb cable and changed the to 3 other usb ports, checked my cables and the power cable in place and power is on. wtf? please help
I had this problem and found that I had plugged the usb cable into the wrong plug hole. I had tried a reinstall of teh printer which failed when it tried to recognise that teh printer was on and connected. When I moved the usb cable to teh correcr socket (closest to teh side of teh printer) it was fine.
Brian
Posted on Nov 06, 2009
  • mgdown Jan 31, 2011
    I had the same problem and it turns out that I plugged the fax line in the wrong jack in the back of the Canon MX850.
  • Anonymous Apr 24, 2016
    me too... outside jack and all fine
As long as i have my usb cable hooked up to my printer and laptop it works but when i disconnect the cord its offline.what should i do?
It may not be configured to the correct port.The port selected could have been the USB port that's why when you disconnect the USB cable printer goes offline and would not print wireless. Follow the steps below if you are using a WINDOWS computer: For windows XP :
  • Click on start then go to printers and faxes.
  • right-click on the default printer canon pixma mx340 series
  • go down to properties
  • click the ports tab
  • check to see which box is checked.If the usb port box is checked,that answers the reason why printer goes offline and would not print wireless when USB cable is disconnected.
  • In the list of ports ,look for tcp/ip with the correct ip (192 number) address of the computer.
  • when you find it,tick the box,click on apply then ok.
  • if you do not see it anywhere on the list ,you need install the software.
For win vista
  • click on start,in the search box key in printer then hit enter on the keyboard
For win 7
  • click on start,in the search box put in devices and printers and hit enter
  • click on printer properties
Let me know if you need assistance in configuring wireless connection and installation.
Jul 17, 2011 | Canon PIXMA MX340 Wireless Office...
Printer has a clicking noise and the in use light flashes. Does not print.
Check to make sure that the USB cable is plugged into the USB port on the machine. The symptoms you describe can happen if you plug the USB cable into the telephone jack.
Feb 04, 2010 | Canon PIXMA MP780 All-In-One InkJet...
Computer says Orinter is Offline but is connected. Has the Fax button highlighted. Only have Copy, Fax, Scan, Memory Card to select from, which one should be highlighted for printing from connected PC
In order to print from PC you should choose COPY function. To check the connection between PC and your printer perform these steps:
  • Right click on printer driver name (Canon PIXMA MX 850 in this case)
  • Choose Properties
  • Click on Maintenance tab
  • Click View Printer Status: the status should ONLINE in order to print or scan
If still Offline,please recheck USB cable,reinstal it,or compare with another cable.
Source: Inkjet Forum
Oct 11, 2009 | Canon PIXMA MX850 Multifunction Printer
Cannot install Canon PIXMA MP190 printer
Thank you for your promptitude.
Today I solved my problem. Was a cable connection problem. Cable incompatibilit or all 3 cables used before are damaged. Tuday I buy an other new cable and SUCCESS!!!: my computer see de printer ("new hardware found" when attach usb cable) , create virtual usb port, install the drivers (I have the drivers downloaded from the Canon web site) and printer is working fine.
Anyway, thank yow again for your support!
Jul 09, 2009 | Canon PIXMA MP160 All-In-One InkJet...
Canon MP780 issue on Mac OS/X
I just noticed that I had the telephone cable connected to the "Telephone" port on the back of the Fax/Printer. When I switched it to the "Line" port, suddenly the clicking stopped and the Memory/In Use light went off. Now we will see if I can Fax something. Hope this works for you too!
Sep 28, 2008 | Canon PIXMA MP780 All-In-One InkJet...
My printer makes a clicking noisae and won't print
This solution is for webbie15. I have the same Canon PIXMA MP780 printer, and I got the same annyoing clicking sound after I moved it today, and whenever I tried to print, Windows said the printer was offline.
It turns out I accidentally plugged the square usb cable into one of the phone jacks (I was too lazy to look, I just felt my way back there). Amazing, but the usb cable FITS in a phone jack, and apparently shorted the printer into thinking it was on-hook, off-hook for a fax.
It's been months since you asked the question. Hopefully this will help others.
Apr 25, 2008 | Office Equipment & Supplies
Pixma 160
Chances are you reconnected the printer to a different USB port and your default is still set up for the other port...
Look at your printer settings and chances are it set up the printer again for the new port.
Either change your default printer or move the cable back to the original port.
Jan 18, 2008 | Canon PIXMA MP160 All-In-One InkJet...
In Use Memory is flashing and there is a clicking sound.
Okay, this is what happens when you put your USB cable into the external device jack next to the telephone line jack (instead of the USB port). Once you plug the stuff in correctly, the problem goes away.
Flauren (original Author on another w eb s ite)
Nov 02, 2007 | Canon PIXMA MP780 All-In-One InkJet...
The printer is offline.
Remove the usb cable from the telephone jack on the back of the printer, and plug it in the usb port.
Apr 16, 2007 | Canon PIXMA MP830 All-In-One InkJet...
1,288 people viewed this question
old marine
old marine
