Question about Kodak EASYSHARE M1063 Digital Camera
My camera turns on and then right back off. wen u press the power bottom the screen comes on and shows the Kodak label like its turning on and the lense begins to open but immideatly closes and the camera turns back off. i charged my camera all night but the problem persisted. the only thing i can think of is tht the day this happened i took my camera with me to the beach and it was warm but not extremely hot.
I had the same problem. This is how I fixed mine! Turn on camera grab the lens with two fingers before it can re-tract back into the camera and shut it self down. Use compressed air around the lens housing no more the 80 PSI. Hopefully this will remove any dirt.
It worked for me!
Posted on Jul 28, 2009
    Problem Solver:
  • 8 Answers
Try cleaning the contacts from the battery and the battery compartment of the camera. I had the same problem, used a cotton swab to clean and this fixed it, it seems to be a common problem.
Posted on Aug 15, 2009
I have the same problem..
I looked online and many people have the same problem but nobody knows how to fix it
i believe what happened is that sand somehow got into the lens and as the camera turns on the inside lens area cannot work properly because the sand is in the way...and lens error makes the camera shut off
kodak will not fix the camera if the reason why it is not working is because of sand,,
my best suggestion is to learn how to take a camera lens apart, and clean the sand with a q tìp
Posted on Jul 14, 2009
I had the same problem with my camera when I dropped the camera and the lens was bent just a little bit so I straighten it out and now it works.
Posted on Jul 21, 2009
How do I do a hard reset for my motorola blurr? I'm having problems with the touch screen sensitivity. It selects things that I don't touch, and doesn't select what I do touch, please help!!
  • If the device is responsive, back up all necessary data.
  • Power off the phone
  • While the phone is off, press and hold the Camera key, then turn the phone back on using the Lock/Power key
    • Note: Continue to hold down the Camera key while the phone boots up
  • When prompted, release the Camera key
  • On the USB FastBoot/BOOTLOADR MENU screen, press and release the Volume down key to enter the Recovery Mode
    • If done correctly, you will see VOLUME DOWN KEY PRESSED appear on the screen
    • IMPORTANT: You only have 10 seconds to complete this step before the device powers back on. If that occurs, you will need to start back at Step 1
  • When the "Triangle!" screen appears, tap the bottom right corner of the display to access the Motorola system recovery screen .
    • Note: If this doesnt work, Touch the bottom right corner and make a small circle gesture to access the recovery screen.
  • Highlight the row labeled wipe data/factory reset [Alt+W]
    • Note: You can use the touch display, volume up/down keys, or the Tinytouch pad to highlight the row
  • Tap Ok to begin the wipe/factory reset
  • When the wipe is complete and the device returns to the Motorola system recover page, highlight the row labeled reboot system now [Menu+Back]
  • Tap Ok to begin the reboot
  • When the device powers back up, you will see the MOTOBLUR setup screen and have the option to create or sign into an existing BLUR account
  • May 28, 2012 | Motorola Cell Phones
    Hello, i have a sony cybershot DSC-S650. Expert, my problem is that when i turn my Sony Cybershot on the lens won't look at nothing, it's ust a blackscreen. Can you please help me. Thank you, My...
    Make sure that the batteries in the camera are good and turn it on. Is there a light that comes on to let you know that the camera has power and is ready when you press the power button? Does that light come on and what color is it?
    If the light ends up green, then you know the batteries are good and the camera is functioning properly and is ready to take a picture. If this is the case, then after you turn it on - look on the back of the camera for the focus zoom in and out buttons. Sometimes they look like a switch that you can rock right or left. Press the switch and look through the lens. Does press the switch or arrows in either direction clear up your view and allow you to see anything? Are you looking through the lens hole or are you using a small screen to view on the back of the camera? If you are looking at a screen on the back of the camera and that screen is black - it means that you dont have the exterior view option turned on in the cameras settings. Sometimes there is a button labeled "view" on the back of the camera to alternate from the exterior view screen on the back of the camera and using the lens hole view at the top. Press that key to make the view screen turn on. If this option is not turned on yet, press the menu key on the camera and use the arrow keys to scroll through the option choices until you find the image preview choices and turn this option on. Then save this choice and close the menu features to see if it comes on.
    If you are not getting a power indicator light when you turn the camera on, then replace the batteries. If the light comes on and its something other then green and steady - (like red and flashing) check your camera manual to see what this indicator means. Some cameras show a red light that is flashing when you turn them on to indicate that the memory card is full. Some camera have a red light that is steady to indicate that the battiers are almost out of power and they will show a picture on the digital to indicate how much power you have left before they shut down. Each model camera is different according to the options it came with.
    Jul 06, 2011 | Sony Cyber-shot DSC-W80 Digital Camera
    My Kodak V1233 shows a lighted screen but I can
    If it makes you feel any better, the airport screener cannot damage your camera in any way.
    Jul 08, 2010 | Kodak Easyshare V1233 12.1MP Digital...
    Lcd screen does not show what your taking picture of
    Turn the camera on. Press the display button (second button down right next to the LCD (Labeled LCD/info) to turn on the LCD. Make sure you are not in review mode. Here is a link I am sure you will find helpful (its what I used to solve this problem)
    http://www.kodak.com/global/en/service/publications/urg00714toc.jhtml
    Let me know if this works
    Cheers
    Jer
    Jan 16, 2010 | Kodak EasyShare Z885 Digital Camera
    Camera Won't Stay On.
    hi try to reset ur camera...To do such reset, turn on the camera and hold the menu button down for longer than 5 seconds. A message should hopefully come up on your LCD asking if you want to reset the camera. Select Yes....
    thank u
    rate me
    Jun 01, 2009 | Kodak EASYSHARE M1063 Digital Camera
    Battery level
    As Suzaku explained:
    A battery icon will show up on the LCD screen of your camera when it is already low and needs recharging. It can be found at the lower right side of your LCD screen. The ready light of your camera will also blink red and your camera will turn off if the battery is exhausted.
    NOTE:
    The icon will not appear if the batery is sufficient and there is no TECH way of making the icon show until the batt needs charging.
    Jan 04, 2009 | Kodak EASYSHARE M763 Digital Camera
    Camera goes off
    I may be able to help with your Kodak EasyShare Z740 that turns itself off.
    It may be a 'lens extending' problem, or it might be fixed with a combination of button presses to reset it while turning it on.
    Try these steps to fix your camera.
    I hope that helps.
    _____________________________________________
    Kodak EasyShare Z740 Turns Off Fix
    Kodak EasyShare Z740 Manual Download
    Oct 15, 2008 | Kodak EasyShare Z740 Digital Camera
    KODAK eASYSHARE c530 BLACK SCREEN DOES NOT TAKE PICTURE
    You may still be able to take pictures with your black screened Kodak camera. This problem occurs in the line of Kodak EasyShare digital camera models.
    When you turn on your Kodak EasyShare digital camera, turn off the LiveView function. Take a picture using the small-windowed viewfinder (this is not the LCD screen). Also, try zooming in and out.
    After taking a picture, review the picture to see if the picture has been taken. Then turn on LiveView and occasionally the LCD screen should no longer be showing a black screen.
    Aug 31, 2008 | Kodak EasyShare C315 Digital Camera
    Camera V603
    the camera should be brought to a repair shop since it might be a mechanical problem or parts may need to be replaced already.
    Aug 25, 2008 | Kodak EasyShare V603 Digital Camera
    SPH-P207 Camera Problems
    when it "freezes" it's usually just taken a picture (easy to accidentally press the shutter) and is showing it to you--press save (left function) or erase (right) then is ready for another--can tell because the picture is moving as you move the phone
    May 03, 2008 | Samsung SGH-p207
    Kodak EASYSHARE M1063 Digital Camera Logo
    1,333 people viewed this question
    Top Kodak Cameras Experts
    Tony
    Greg Cann
    Greg Cann
    Are you a Kodak Camera Expert? Answer questions, earn points and help others
