Question about Directv Plus DVR DTV Receiver / 100-Hours Video Recorder
DirectTV Dvr Playback of Recording skipping and locking up reciever forcing Resetof reciever.
Hi, my Direct TV Dvr Playback of Recording is skipping and locking up receiver forcing me to Reset the receiver. and then it still does not work. I have 33 % of my hard drive space still left. do you have any advice for me?
Thanks in advnace, MC
  • 38 Answers
Re: DirectTV Dvr Playback of Recording skipping and...
Have either of your tried unhooking the HDMI connector if you are using it and try component?
What software are you running on the unit. The HR20-700 and HR20-100 just got a software update that was going to fix this problem w/ the unplayable recordings.
If it is erasing your content that is a good sign of a defective hard drive. These units when they boot up (after a software update) check the hard drive. If they run into a problem (bad sector) they will foolishly erase the hard drive, thus erasing everything you have recorded. If this is your 4th unit, you may want to look at your environment as well (well ventilated, good connections, etc) I'm not saying it couldn't be the unit. It took directv 14 units to get 3 working, and since I've had 2 HR20-700 refurbs that were unstable and were quickly replaced.
It might be in your best interest to invest in an external drive solution for the HR20. I, however, would be calling customer retention and having a calm, but stern chat with them about this.
Posted on Nov 21, 2007
0 characters
3 Points
I have dish network and they tell me that if I put my dvr recording's on an external hard drive I can only playback on dish network reciever, but they mentioned netgear and did not explain?
FYI...just know that when you get NETGEAR product...DISH no longer is responsible for the activation and troubleshooting...and NETGEAR starting activation is 40.00 and they keeping adding money for any further problems..till you get to 200.00 whole house
May 22, 2012 | DISH Network ViP722 DTV Receiver /...
DVR-625 deleted almost all timers, stopped recording shows
Unfortunately the hard drive is failing and you will need a new one.
Thanks for using Fix Ya.
Jan 16, 2010 | DISH Network DVR-625 DTV Receiver /...
Dvr wont record correctly. skips every so often saying "dish couldn't play due to loss of signal"
This message will populate when you had signal loss during a recording in progress. If you have great signal and still continue to see these msgs then your reciever will need to be replaced.
Nov 30, 2009 | DISH Network TV Receivers & DVRs
Dvr recording pauses occasionally (for about 30 seconds) and freezes (which requires a reset or unplug).
Hi! I will be more than glad to assist you in this concern. If your directtv hdtv receiver occasionaly pauses for 30 seconds and freeze and the only troublshooting steps that you do is to press the power button for 10secs or unplug the power-hard reset for 15secs. please do this steps
1. check if the software version of your receiver is updated, how to? got to the sysinfo of your receiver by pressing the sysinfo button on your remote or front panel of the hd receiver, write down on a piece of paper the version, then exit the sysinfo, run a check switch test, you need to access the menu of your receiver, once your done with the check switch and test.. turn off the power of your receiver by pressing the power button on the remote, make sure that there are no lights lit so that the satelite will automatically download the software if its outdated and if nothing happen it means that your software is updated. after all the steps that you did, by running the check switch and test.. still problem exist.. call the directtv tech support for the replacement of your hd dvr receiver, this is a dvr lost of function. I have experience that symptoms on my hd dvr receiver as well with one of the sat provider..
note: if you cant run the check switch and test, please call the direct tv tech support for assistance.
please feel free to get in touch if you have any query..
Aug 30, 2009 | Directv HDTV Receiver
Recording on my Dish 625 dvr
Okay, we can do this. Go to the menu on the satellite at either TV locations. and press 8 then 5. You are now at the Record Plus screen. Move the highlight to the record preferenceand toggle up or down to the desired record preference.After this ensure that you select enable on the activation side of the screen. You will then need to select done. Now you are in business! Thanks ffor using Fix Ya.
Mar 23, 2009 | DISH Network DVR-625 DTV Receiver /...
Dish Network DVR 625 Problem with playback of recorded shows
It sounds as though the hard drive is about to go south on you soon and the receiver is going to need to be replaced however, in the interim you can change the options of the recordings and make it a default so that the recording continues past the end of the show. It is possible that extending this time will allow you to view the portion you want before it skips to the end. In order to do this press the guide button and select a program in the future. On the create timer screen select the option icon. You will now be at the timer options screen you can extend the time the recording will last after the end of the show and when it will begin recording prior to the show. I would also set this as your systems default so that it performs the same way regardless of what you are recording. According to the latest known receiver issues this is not identified as it is a common indication that the hard drive has an error internally. If this works I suggest that you have a replacement sent to you so that you do not lose the use of your DVR un-expectantly.Remember to watch all recorded events prior to replacement as you will lose that info when the receiver is swapped. Thanks for using Fix Ya.
Mar 09, 2009 | DISH Network DVR-625 DTV Receiver /...
Dvr recording skip sound
probably a dying hard drive, but could just be corruption, delete all effected recordings, monitor, if issue continues delete all recordings unplug receiver for 10 minutes, monitor new recordings if continues receiver may need to be replaced
Jun 25, 2008 | Directv Plus DVR DTV Receiver / 100-Hours...
Direct TV DVR Recording Problem
call tech support & ask them to hit your box to reset it, in the meanwhile unplug it for 15 seconds
Apr 22, 2008 | Directv (R10) DTV Receiver / 70-Hours...
Direct TV DVR "skipping" like a dvd
You have an internal hard drive error. You will need a new box.
Jan 22, 2008 | Directv Plus DVR DTV Receiver / 100-Hours...
Directv Plus DVR DTV Receiver / 100-Hours Video Recorder Logo
3,925 people viewed this question
Top Directv TV Receivers & DVRs Experts
Andy Fraser
Andy Fraser
David Payne
David Payne
Are you a Directv TV Receiver and DVR Expert? Answer questions, earn points and help others
