Question about Toshiba DP2570 Printer
Hello? I have used toner and i am trying to find a
Hello? I have used toner cartridges and I am trying to find a place that buys them. I know places that buy HPO used toner packs but I can't seem to find a place that will buy Toshiba's. Can you tell me one in South Florida?
  • 134 Answers
Try www.tonerbuyer.com, it is in Alabama but they pay shipping.
Posted on Aug 05, 2009
OKI C3530N
Take cartridges out of the printer.
Close cover.
Unplug printer for 30 minutes.
Reconnect printer to power.
Printer demands cartridges.
Reinsert cartridges as demanded.
Oct 31, 2008 | OKI C3530N Color MFP Printer
Printed photos grass and other colours come up lilac
Try re-seating the toner cartridges by removing them and carefully placing them back in correctly. If this does not work, you may have to buy new toner cartridges.
May 08, 2011 | Office Equipment & Supplies
Hello there! When I print, all documents have a grey streak across it. its very slight but it also looks bad to customers so Im wondering if someone can help me Thank you in advance
Either the toner cartridges, the fuser, or the photodeveloper cartridge are defective, or toner has accumulated in front of the printhead or on the printhead lens.
Replace the color toner cartridge causing the
line. If you still have the problem, replace the fuser and the photodeveloper cartridge. Clean any spilled toner you see in the printer housing near the printhead using a soft, clean
lint-free cloth. Clean the printhead lens.
Clean the printhead lens when you see print quality problems :
1 Turn the printer off.
2 Pull the front door release latch forward and gently lower the front door.
3 Remove all of the toner cartridges one at a time.
4 Open the top door.
5 Remove the photodeveloper cartridge.
6 Pull on the tabs to lift the lens cover.
7 Gently wipe the printhead lens in one direction using a clean, dry lint-free cloth.
8 Push the lens cover down.
9 Align the photodeveloper cartridge with its opening. Gently lower it into place.
10 Push the latches away from each other to lock the photodeveloper cartridge into place.
11 Close the top door.
12 Install all of the toner cartridges.
13 Close the front door.
14 Turn the printer on.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
Jan 26, 2011 | Lexmark C510 Laser Printer
Is there any way to refill an empty cartridge.
Hello thanks for using Fixya
In HP Laser Jet 2420 replace the cartridge is not difficult, but it is important to use the appropriate technique. The things you need is "Toner Cartridge" & "Recycling label"
Now follow this procedure
  • See the small latch on the front door of the printer. Pull the latch to open the door and catch to the toner cartridge
  • Now pick up the used toner cartridge by the handle and carefully lift it out of the printer. Set the toner cartridge aside for recycling.
  • After it open the box containing the new toner cartridge and remove any packing materials which is on the box, Grasp the toner cartridge by the handle and lower it into the printer until it locks into place now close the front door of the printer.The front door will not close if the toner cartridge is not properly inserted
  • Place the used toner cartridge in the box, Affix the prepaid shipping label that came with the new toner, and use it to send the used cartridge back for recycling.
You must do care by doing this. Otherwise go to any HP service center and give them your empty cartridge they will surely refill it.
I hope this solution will helpful 4 u
Please don't forget to click on Four thumbs which are given below & then write testimonial for my appreciation if it is helpful
THANKS & Keep Using fixya
Jan 25, 2011 | HP LaserJet 2420 Printer
Error code"toner exhausted" what to do?in samsung scx 4300
toner exhausted = the toner has been used all up, buy a new one.
It's something like
http://www.tronix.ro/toner-samsung-scx4300-p-9783.html
May 27, 2010 | Samsung SCX-4300 Monochrome Laser...
Get code 004 332 restart printer. have removed the four toner cartridges and replaced the drum cartridge and the same code appears
Hello,reseat and clean the four toner cartridges, verify the orange plastic covers have been removed, and verify the cartridges are fully locked into place, .This is the procedure:
1. Press the Menu button and press the down arrow until Replace Toner appears, and then press the "ENTER" button.
2. Press the down arrow to choose the appropriate color toner cartridge and press the "ENTER" button.
Note:If the Menu button is inaccessible, begin replacing the toner cartridges with step number 3.
3. Open the front cover.
4. Lift the handle of the appropriate colored toner cartridge and remove the toner cartridge.
5. Gently rock the toner cartridge from side to side.
Note:Rock the toner cartridge over newspaper as there may be some toner leakage.
6. Gently wipe the exterior of the toner cartridge with a dry cloth.
7. Verify the mag roller has been removed.
Note:Grasp the orange strap, peel the tape away from you, and then, with the tape free, pull the blue strap toward you.
8. To reinstall the toner cartridge, align the arrows on the cartridge with the corresponding arrows on the printer, guide the cartridge in until it snaps into place, and then push down the right lever to lock the cartridge in place.
Note:Ensure each cartridge lever is fully pressed down into the locked postion.
9. Close the front cover.
10. Repeat steps 1 through 8 until all toner cartridges have been reseated.
Good luck
Feb 05, 2010 | Dell 3100cn Laser Printer
CLP 300 toner cartridges invalid toner
the drum has chips encoded,need cartridges with chips.
May 29, 2009 | Samsung CLP 300 Laser Printer
Best place to buy toner
ebay 1st i can alsosuggest southeastern wholesale when they have some ask for darryl 931-268-6601
Dec 31, 2008 | Canon imageRUNNER C3200 Copier
Low toner/toner empty
Toner cartridges have more then just "toner ink" they also have developer and sometimes a chip that says how many times the cartridge has been used.
Also some refill places can be a bit dodgy so I know it might not seem like the best thing right now but try buying a real replacement cartridge and if that doesn't do it beg and plead to return it saying it was the wrong model.
If it does fix it then you might have a bad cartridge that either has the "chip" or the cartridge itself is simply worn out and in need of developer as well.
Apr 16, 2008 | Brother MFC-8440 All-In-One Laser Printer
Toshiba DP2570 Printer Logo
93 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
