Question about Garmin nuvi 250W GPS Receiver
Turns on for only a few seconds. Says loading maps and then shuts off. Does not show charging sign when being charged.
I had this problem with my nuvi 200w had to send it back as the battery is not working any more
Posted on Jan 20, 2011
Model PL81. Why does it zoom, beep, and shut down?
Are you positive that the battery is good? Turning on for a few seconds and then shutting down is a classic symptom of a battery that did not take a proper charge and as soon as the surface charge is used, unit will shut down. And what if your charger is not properly charging the battery?
If you have a battery eliminator try that in lieu of the battery to see what happens.
Mar 28, 2016 | Samsung Cameras
My garmin nuvi 255 turns on for a few seconds after the start up screen then shuts right off
It simply means the device is not properly charged, that is why it is not powering on beyond the start up screen.This problem only comes up when the battery is not properly charged, therefore not being able to power up the gps beyond the loading map page. Try to reset the unit by holding the power button for about 15 seconds, it will restart the unit, once it restarts it, check if it will get pass the loading map page. Then you try to back up the software on a computer, format it and restore the software back on the unit. If that does not help, then you carry out the following tests.
Try to charge the gps device for about 2 hours then try to turn it on. If it does not come on, then it means the battery did not get charged. That can be a problem from either the battery or the charger or the charging port.
First test the battery by fixing it in another gps and charging it for about 2 hours then turn it on. If it powers on the gps, then it means the battery is okay, but if it does not turn it on, then it means the battery is weak and cannot hold a charge and the solution is for you to replace the battery.
Next you test the charger by trying it out on another gps device, if it turns it on, then it means the charger is intact but if it does not turn it on, then the fault is from the charger.
Finally, test the gps itself by trying to charge in by connecting it to the computer using the USB cable, then you turn it on, if it does not come on, then it means there is a problem with the connection port or there is an internal problem or something with the unit.
Hope this advice was useful to you.
Jan 06, 2011 | Garmin nuvi 255W GPS Receiver
While plugged in, my Garmin c530 will shut down immediately after it says "loading maps". Why is this?
Jan 02, 2011 | Garmin StreetPilot c530 GPS Receiver
The gps automatically shuts off after few minutes
When you turn the unit on and get to the screen showing Where To?, View Map and Travel Kit look on the upper right hand corner of the display and make sure you see the battery icon all green. If it is not then the battery is not charged
Apr 04, 2010 | Garmin Nuvi 660 GPS Receiver
Tom tom won't turn off
if it does not proceed when the icon is selected, presume data corruption or in fact no data.
TomTom is renouned for this type of problem.
try rteinstalling the map data from the source.
try a reset first ( small pinhole on rear) put open paperclip end in and gently push the button inside) if this still fails then data installation is the go
Jun 23, 2009 | Tomtom GO 720 GPS Receiver
CREATIVE ZEN - NOT CHARGING
Go into your lab top and click on remove hardware safety.Find your zen the click remove..Next do not unplug it,shut off your zen then you should see instantly on the zen its charging...
Mar 31, 2009 | Creative Labs Zen V MP3 Player
Garmin Nuvi 260W shuts off before it fully loads maps
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} If your GPS unit powers down before it can fully boot up, the battery will need to be charged. Please charge the unit with the vehicle power cable or on a computer for at least three hours. After charging the unit, it should power on and function normally. If the unit will not charge in the vehicle, check the fuse in the power cable for the unit and the power outlet in the vehicle.
The nuvi 200 series, 300 series, 600 series, 700 series, 1000 series and the StreetPilot C300 and C500 series do not have user replaceable batteries. These units must be sent in to a Garmin approved repair facilities if a battery issue arises. Garmin and Raytech are the only Garmin approved repair facilities. Raytech is a repair facility for Canadian customers. To repair your device please contact the specific repair facility for your region. If your device is not still under the 1 year warranty, there will be a cost associated with the repair of your device.
Mar 19, 2009 | Garmin nuvi 260W GPS Receiver
Unit turns on for 5 seconds then shuts off.
I charged the unit and now it works fine. Plug into computer and charge for a while and the unit should work fine.
Mar 02, 2008 | Garmin StreetPilot c550 GPS Receiver
Garmin Street Pilot 7200 will not load maps
I had the same problem on my StreetPilot 7200 after many edits of many routes. Suspect a scratchpad memory heap getting used up or fragmented had to hold the power button in for 15 seconds or until a message that says press yes to clear all data appears then quickly press yes before unit shuts down
This corrected the problem until the next time the heap gets fragmented but loss of all waypoints is the downside
Jan 11, 2008 | GPS
Garmin nuvi 250W GPS Receiver Logo
182 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
