Question about Fuji FinePix F470 Digital Camera
ZOOM ERROR When I switch my F470 on. I get a white bar across the centre of the viewing screen with ZOOM ERROR. I have switched it off and on again, charged the battery so full of charge, all to no avail any Ideas ?
  • Anonymous Nov 16, 2007
    My daughter has a Finepix A400 with exactly same problem. Can it be repaired , if so howmuch?
  • Anonymous Nov 28, 2007
    My Fugi FinePix F470 also just out of the blue started showing zoom error and I couldn't get the lense to close. After applying slight pressure to the telephoto scope it did shut and worked for awhile and then the same problem. I was able to get it to turn on again, so I kept turning it on and off to see if it was okay and as I did I could hear an abnormal click each time, like a piece of something had gotten in the lense/scope compartment somehow. Well now it will only turn on and go to a white screen and I have to remove the battery to get it to turn off and the lense/ scope will not close. Is this something repairable? If so please let me know.
I used to get that error all the time with a earlier Fuji FinePix with the slide-over lens cover. If the cover wasn't pushed back completely, the lens would extend only so far and then give an error. Make sure that there's nothing (dirt, hair) on any of the lens surfaces and make sure the lens is fully extending when you do turn the zoom on. Don't let anything touch or bump the zoom while it's moving, either.
Not sure if this will help, since you have a different model. This is what worked for me, though.
Posted on Nov 16, 2007
I bought FUJI FINEPIX AX650 6 months ago.Now After taking pics when i press play button to view , it shows READ ERROR.another problem after taking a snap, the LCD display shows blank (color black) for few...
when having a problem with your digital camera. switch it of, remove the battery and charge the battery. When you replace the battery, the error should be gone. If not, you should contact the service centre closest to you.
Jan 22, 2014 | Fuji FinePix AX650 16MP, 5X Optical Zoom...
Operating instructions for dsr pd177p sony video camera. I am not in postion to operate the camera, please guide how to operate the camera.
It is not very easy to say few lines to tutor ,but learn to use only by experience.Put the battery on for charging.Once fully charged slide the power switch to camera.Open the lens cap ,open the view finder display.Now you can see the picture on your screen.Set the camera to auto the camera to a white screen so as to white balance the camera.Now point at an object and do a trial Zooming using the auto zoom with your finger.The image will come closer and you can draw it to white screen.Having an object in view on the white screen,press the record button.Slowly move the zoom forward to get the right frame of the object.Press reccording button once again to stop.Repeat the process on different scenes.
Now shift the mode switch to play and rewind and play the reccorded portion.Practice.
Sep 02, 2010 | Sony Dvcam DSR-PD150 DV Digital Camcorder
Hi I have a fujifilm f470 finepix camera. One
Is it just the live view from the lens that you can't see ( totally blank screen), or are the icons visible?
If it still shows the icons but no live view then I suspect the shutter mechanism is stuck over the lens inside the camera.
Have a look at the lens and see if you can see the inner lens? You may have to adjust the zoom to bring the inner lens up to the end of the lens barrel.
If it is stuck then it will require removing and inspecting / cleaning.
Aug 26, 2009 | Fuji Rod Repair Kit
View screen is white (blank) with internal cracks
Look fo the switch that has two setting. one of them will say LCD and the other Migt EVF if you have a view through your view finder this is your problem.
Jun 28, 2009 | Samsung L200 Digital Camera
Lens stuck in out position, screen shows zoom error. How can I fix the problem?
just take out the battery ....charge it ...and put it back....switch off and switch on the camera once....should work fine
May 15, 2009 | Fuji FinePix A345 Digital Camera
When i take pictures, sometimes they come out with lines all over them.
shutter problem. put camera into full optical zoom, turn it to face you and angle it so that you can see into the lens without reflection. In full zoom the internal lens is right up to the outer lens so, even on a small lens such as this, when you press the picture button you should see the shutter close across fully. If it does not you will get either an over exposed or complete white out picture. Or lines across your pictures.
The shutter needs to be cleaned. There is grease in the camera for the moving parts and is probable that this is the cause for the error.
I have found this to be the case for fuji's E900, E550, F40fd, F470, F460, and a few samsung's as well.
Mar 08, 2009 | Fuji FinePix A400 Digital Camera
Zoom error
You lens are tilted? If so, they are out of track. Maybe you bumped or dropped the camera. Try straighten them up with your fingers, very gently.
Sep 05, 2008 | Fuji FinePix F470 Digital Camera
Zoom error
Hey MBB722,
What is most likely going on is there is something stuck in the lens obstructing its movement (i.e. sand). I don't know what you have tried and what you have not tried you can try placing the camera on a flat surface with the lens pointing upwards, and then press and hold the shutter button and while doing this turn the camera on. If this doesn't work you can try removing the batteries and waiting a minute or two and then reinserting. If these suggestions don't work you should have it looked at by an authorized service technician such as bringing the camera to a Geek Squad® precinct at a Best Buy™ store and they can send it out for service. I hope this helps!
Go Ahead. Use Us.
Jun 01, 2008 | Fuji FinePix F470 Digital Camera
White bar coming across my k800i's screen.
try changing the current theme of your phone and check if the white bar will still appear...
May 03, 2008 | Sony Ericsson K800i Cellular Phone
Fuji FinePix F470 Digital Camera Logo
241 people viewed this question
Top Fuji Cameras Experts
Greg Cann
Greg Cann
Are you a Fuji Camera Expert? Answer questions, earn points and help others
