Question about Instant Cameras
Want to remove top plate of nikon fe
I want to remove the top plate of my nikon fe but don't know how
  • 3 Answers
Re: want to remove top plate of nikon fe
It's not very easy- you have to remove the rewind knob and dials at the left end of the cover and the speed dial and winder arm at the right side. Then the 5 small screws around the cover.
It is a delicate task because under the cover there are some very sensitive electronics. If you are determined to go ahead with it then your best bet might be to get a service manual.
Posted on Sep 05, 2010
0 characters
3 Points
How to get the Nikon fm10 shutter release button to work
C-o-c-k the shutter by advancing the film. You need to do this even if you don't have any film loaded.
Sorry about the first word. FixYa thinks it's a dirty word and will censor it out if I don't do something about it.
Mar 13, 2012 | Nikon Instant Cameras
I've got Nikon F65. I cannot load film. The motor which load up the film doesn't move at all. Please help!
I don't know this model but you can try this.Drop the film canister in and pull the film strip out and place on the film advance sprocket.Rotate the sprocket by hand/thumb until film is seated (1 turn). If the auto feed is working you will be OK. 2 other things ,1 of course load film in dark area, 2 check the batteries on the camera first, if they are week your film advance wont work ,Good Luck.
Jul 29, 2011 | Nikon Instant Cameras
Removing Nikon FM2N top plate
Unscrew the rewind knob and remove a circlip under it (You may need to grind the tips of a pair of round-nose pliers for this). Remove the disk and pull the rewind shaft stop off the hub (a spring and flat plate). Remove the two screws. You'll need a special tool to remove the little stud the shaft stop was pivoting on. Take a 1/8 inch screwdriver and grind a slot in the blade. Use this tool to remove the stud, then remove the three screws from the plastic cover ring.
Do not remove the center screw from the shutter speed dial. Remove three screws from the side of the dial and pull off the grip ring.
Jul 08, 2010 | Nikon Instant Cameras
Nikkormat 35mm SLR light meter not working!
1) Clean the battery contacts and put fresh battery.
2) Open the top cover and clean the meter switch ( located and the wind cam )
3) Meter needle maybe stuck at the rest position. Remove the stopper and replace or clean.
4) If none of these help, check the meter cells and resistor band under the shutter dial behind the lens mount ( hard to do.)
Jun 14, 2010 | Nikon Instant Cameras
Parts for Nikon FM Camera.
The bottom will fit, but the top cover for an FE2 is quite different than an FM.
Jan 28, 2010 | Nikon Instant Cameras
My Nikon FE film advance lever is stuck. It does not move at all, there is no film in the camera. The repair shop wants $100 to fix it which is more than the camera is worth I think. I would like to do...
Have you tried fresh batteries and setting the shutter speed dial to M90 or m250 whichever you have? If this does'nt work you can remove the camera bottom plate and gently pull a lever away from the advance cog. Some times things get out of sync in there. Sorry I can't be more specific but I did this many years ago. Good Luck.
Dec 12, 2009 | Nikon Instant Cameras
Camera disassembly - removing knob
A/M knob can be removed by removing circular trimplate on the knob and remove the screw securing the knob. hope this helps. Let me know if you need more infor. james
Mar 25, 2009 | Nikon Instant Cameras
How do I remove the film door on my Nikon N90
You should not have removed the screw. It sticks out for a reason. You push it down to release the top hinge of the door.
May 03, 2008 | Instant Cameras
Nikon n4004 top cover
There are two screws on the right side that are hard to find. One is inside the battery chamber and the other is under the small cover surrounding the shutter release button. The cover is held in place by 2 sided tape. Pry it up carefully starting near the strap lug
Dec 17, 2007 | Instant Cameras
Super Ikonta 530/2 B Speed setting not working. ClAing camera.
If you want a manual you can get it here
Read this and since its a simple problem you will get all you want to know!
Oct 03, 2007 | Instant Cameras
Open Questions:
Instant Cameras Logo
423 people viewed this question
Top Instant Cameras Experts
Steven Wander
Steven Wander
Are you an Instant Camera Expert? Answer questions, earn points and help others
