Question about Mitsubishi VS-50705 50" Rear Projection Television
Mitsubishi rear projection tv - picture does not come through
We can hear sound and we have reset the tv several times as well as turned off the tv by unplugging it and nothing seems to work. Instead we see the timer light continously blinking a green light very fast. Does anyone have any suggestions?
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 36 Answers
Finding information on the is particular brand was not an easy task. I had previously thought it may have been in need of a lamp replacement.
However doing some research on this particular model I found out it is an older CRT (Cathode Ray Tube). What the problem with your television is that a repair person would have to run a diagnostic with your TV. Which often can be quite expensive.
Your TV has 3 different imaging sources a Red, Blue, and Green. Anyone of these could be causes your TV to do this. It maybe just one, maybe 2 or even all 3. Replacement parts for this TV is not an easy find. I ended up finding similar parts on eBay.
Your best bet would to be call an TV repair person to diagnose the problem. Or buy a new LCD or DLP TV. I am sure it is not news you want to hear. But this is the only help I am able to give.
Posted on Jul 13, 2009
Mitsubishi 62 in 1080p turns on ,has sound but no picture
Your going to need to measure the various power supply voltages to see if its a bad main or power supply board
Nov 08, 2017 | Mitsubishi WS-65513 65" Rear Projection...
Mitsubishi VS-50603 Wont Turn on
The power supply will need to be changed. The capacitors inside the power supply are not sending the correct amount of power to tv and will need to be changed.
May 13, 2009 | Mitsubishi VS-50603 50" Rear Projection...
Mitsubishi VS-5004R No Picture and No Audio
not enough power, you may need to rebuilt or replaced the power board
Mar 31, 2009 | Mitsubishi VS-50605 50" Rear Projection...
52" mitsubishi rear projection tv model vs6051 sound no picture
Not exactly familiar with this model but sounds like the projector lamp is burned out. Hopefully it's a replaceable type. Try calling these people - http://www.purelandsupply.com
Mar 29, 2009 | Mitsubishi VS-60111 60" Rear Projection...
Just replaced the lamp inside of a misubishi dlp wd-52525 the tv will turn on then turn off after a couple of minutes. The tv has sound but no picture
1) make sure the lamp door is properly aligned
2) listen to hear the sound of the ballast board trying to ignite the lamp. It will buzz then pause then buzz, etc its a soft noise, so listen closely.
3) watch for the green LED on the TV's front panel. If it blinks continously, there's a major problem with capacitors on several circuit boards requiring an expensive and time consuming repair.
michtech
Feb 19, 2009 | Mitsubishi WT-42311 42" Rear Projection...
No picture
it sounds like the chassis is bad. there are several ways to take care of this.it just depends on you technical abilities
www.tv-techs.com
Dec 14, 2008 | Mitsubishi WD-52525 52" Rear Projection...
The screen doesn't come on. You can hear the tv turn on, but the picture is not there.
try resoldering the vertical output IC sounds like the CRTs are blanking due to vertical deflection. this model is famous for cold solder on the vertical output.
Mar 14, 2008 | Mitsubishi VS-50707 50" Rear Projection...
Mitsubishi VS-5041 50 Inch Rear Prorjection TV No image but there is sound!
After 11 years???? OMG This set is a tired pup and should be put to reast. My experience with older sets and your complains are all capacitor problems and is only gonna get worse as the first time around repair will take several capacitors to repair. This set has no user serviceable parts inside so you should not attempt a repair suchj as this on your own.. This repair if you decide to go through the first time will be About 300 to 600 bucks the first time and cost will continue to raise till the sets put to sleep. Good luck
Jun 01, 2006 | Mitsubishi VS-50605 50" Rear Projection...
Mitsubishi VS-50705 50" Rear Projection Television Logo
181 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
